{"name":"La Traction Universelle","description":"Un club enti\u00e8rement d\u00e9di\u00e9 \u00e0 la Traction","url":"https:\/\/www.la-traction-universelle.org","home":"https:\/\/www.la-traction-universelle.org","gmt_offset":2,"timezone_string":"Europe\/Paris","page_for_posts":0,"page_on_front":68,"show_on_front":"page","namespaces":["oembed\/1.0","contact-form-7\/v1","redirection\/v1","wc\/v3","wc\/v1","wc\/pos\/v1\/catalog","yoast\/v1","jetpack\/v4","complianz\/v1","wc-admin","wc-analytics","wc\/store","wc\/store\/v1","wc\/private","wc\/v2","aios\/v1\/onboarding","wc-admin-email","wc-telemetry","wccom-site\/v3","wp-abilities\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/www.la-traction-universelle.org\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"L\u2019URL de la ressource \u00e0 parcourir pour obtenir les donn\u00e9es oEmbed.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"L\u2019URL de la ressource \u00e0 parcourir pour obtenir les donn\u00e9es oEmbed.","type":"string","format":"uri","required":true},"format":{"description":"Le format oEmbed \u00e0 utiliser.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"La largeur maximale du contenu embarqu\u00e9 en pixels.","type":"integer","default":600,"required":false},"maxheight":{"description":"La hauteur maximale du contenu embarqu\u00e9 oEmbed en pixels.","type":"integer","required":false},"discover":{"description":"D\u00e9termine s\u2019il faut ou non effectuer une requ\u00eate de d\u00e9couverte oEmbed vers d\u2019autres fournisseurs non autoris\u00e9s.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/oembed\/1.0\/proxy"}]}},"\/contact-form-7\/v1":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"contact-form-7\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/contact-form-7\/v1"}]}},"\/contact-form-7\/v1\/contact-forms":{"namespace":"contact-form-7\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/contact-form-7\/v1\/contact-forms"}]}},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)":{"namespace":"contact-form-7\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback":{"namespace":"contact-form-7\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback\/schema":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/refill":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/redirection\/v1":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"redirection\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1"}]}},"\/redirection\/v1\/redirect":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1\/redirect"}]}},"\/redirection\/v1\/redirect\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/redirection\/v1\/redirect\/post":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"text":{"description":"Text to match","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1\/redirect\/post"}]}},"\/redirection\/v1\/bulk\/redirect\/(?P<bulk>delete|enable|disable|reset)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"global":{"description":"Apply bulk action globally, as per filters","type":"boolean","required":false},"items":{"description":"Array of IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false}}}]},"\/redirection\/v1\/group":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true},"status":{"description":"Status of the group","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1\/group"}]}},"\/redirection\/v1\/group\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true},"status":{"description":"Status of the group","required":false}}}]},"\/redirection\/v1\/bulk\/group\/(?P<bulk>delete|enable|disable)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false}}}]},"\/redirection\/v1\/log":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1\/log"}]}},"\/redirection\/v1\/bulk\/log\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false}}}]},"\/redirection\/v1\/404":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1\/404"}]}},"\/redirection\/v1\/bulk\/404\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false}}}]},"\/redirection\/v1\/setting":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1\/setting"}]}},"\/redirection\/v1\/plugin":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Name","type":"string","required":false},"value":{"description":"Value","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1\/plugin"}]}},"\/redirection\/v1\/plugin\/delete":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1\/plugin\/delete"}]}},"\/redirection\/v1\/plugin\/test":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1\/plugin\/test"}]}},"\/redirection\/v1\/plugin\/data":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"upgrade":{"description":"Upgrade parameter","type":"string","enum":["stop","skip","retry"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1\/plugin\/data"}]}},"\/redirection\/v1\/plugin\/finish":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1\/plugin\/finish"}]}},"\/redirection\/v1\/plugin\/fix":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"reason":{"description":"Reason for fix","type":"string","required":true},"current":{"description":"Current version","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1\/plugin\/fix"}]}},"\/redirection\/v1\/import\/file\/(?P<group_id>\\d+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/redirection\/v1\/import\/plugin":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/redirection\/v1\/import\/plugin"}]}},"\/redirection\/v1\/export\/(?P<module>1|2|3|all)\/(?P<format>csv|apache|nginx|json)":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/wc\/v3":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/v3","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3"}]}},"\/wc\/v3\/marketplace\/featured":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/marketplace\/featured"}]}},"\/wc\/v1":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1"}]}},"\/wc\/v1\/marketplace\/product-preview":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/marketplace\/product-preview"}]}},"\/wc\/v3\/marketplace\/refresh":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/marketplace\/refresh"}]}},"\/wc\/v3\/marketplace\/subscriptions":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/marketplace\/subscriptions"}]}},"\/wc\/v3\/marketplace\/subscriptions\/connect":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/marketplace\/subscriptions\/connect"}]}},"\/wc\/v3\/marketplace\/subscriptions\/activate-plugin":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/marketplace\/subscriptions\/activate-plugin"}]}},"\/wc\/v3\/marketplace\/subscriptions\/disconnect":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/marketplace\/subscriptions\/disconnect"}]}},"\/wc\/v3\/marketplace\/subscriptions\/activate":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/marketplace\/subscriptions\/activate"}]}},"\/wc\/v3\/marketplace\/subscriptions\/install-url":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"product_key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/marketplace\/subscriptions\/install-url"}]}},"\/wc\/v3\/marketplace\/create-order":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/marketplace\/create-order"}]}},"\/wc\/pos\/v1\/catalog":{"namespace":"wc\/pos\/v1\/catalog","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/pos\/v1\/catalog","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/pos\/v1\/catalog"}]}},"\/wc\/pos\/v1\/catalog\/create":{"namespace":"wc\/pos\/v1\/catalog","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"force":{"type":"boolean","default":false,"description":"Force regeneration of the feed. NOOP if generation is in progress.","required":false},"_product_fields":{"type":"string","description":"Comma-separated list of fields to include for non-variable products.","required":false},"_variation_fields":{"type":"string","description":"Comma-separated list of fields to include for variations.","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/pos\/v1\/catalog\/create"}]}},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/ai_generator\/callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/ai_generator\/callback"}]}},"\/yoast\/v1\/ai_generator\/refresh_callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/ai_generator\/refresh_callback"}]}},"\/yoast\/v1\/ai_generator\/consent":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"consent":{"type":"boolean","description":"Whether the consent to use AI-based services has been given by the user.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/ai_generator\/consent"}]}},"\/yoast\/v1\/ai\/free_sparks":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/ai\/free_sparks"}]}},"\/yoast\/v1\/ai_generator\/bust_subscription_cache":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/ai_generator\/bust_subscription_cache"}]}},"\/yoast\/v1\/ai_generator\/get_suggestions":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["seo-title","meta-description","product-seo-title","product-meta-description","product-taxonomy-seo-title","product-taxonomy-meta-description","taxonomy-seo-title","taxonomy-meta-description"],"description":"The type of suggestion requested.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"platform":{"type":"string","enum":["Google","Facebook","Twitter"],"description":"The platform the post is intended for.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/ai_generator\/get_suggestions"}]}},"\/yoast\/v1\/ai_generator\/get_usage":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_woo_product_entity":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/ai_generator\/get_usage"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/site_kit_configuration_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/site_kit_configuration_permanent_dismissal"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/setup_steps_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"setup_widget_loaded":{"type":"string","enum":["yes","no"],"required":false},"first_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"last_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"setup_widget_temporarily_dismissed":{"type":"string","enum":["yes","no"],"required":false},"setup_widget_permanently_dismissed":{"type":"string","enum":["yes","no"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/setup_steps_tracking"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/available_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"type":"string","default":"","required":false},"postType":{"type":"string","default":"page","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/available_posts"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/wincher\/authorization-url":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/wincher\/authorization-url"}]}},"\/yoast\/v1\/wincher\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true},"websiteId":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/wincher\/authenticate"}]}},"\/yoast\/v1\/wincher\/keyphrases\/track":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/wincher\/keyphrases\/track"}]}},"\/yoast\/v1\/wincher\/keyphrases":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":false},"permalink":{"required":false},"startAt":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/wincher\/keyphrases"}]}},"\/yoast\/v1\/wincher\/keyphrases\/untrack":{"namespace":"yoast\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/wincher\/keyphrases\/untrack"}]}},"\/yoast\/v1\/wincher\/account\/limit":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/wincher\/account\/limit"}]}},"\/yoast\/v1\/wincher\/account\/upgrade-campaign":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/wincher\/account\/upgrade-campaign"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/workouts"}]}},"\/yoast\/v1\/complete_task":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"options":{"type":"object","properties":{"task":{"type":"string","required":true,"sanitize_callback":"sanitize_text_field"}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/complete_task"}]}},"\/yoast\/v1\/get_tasks":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"options":{"type":"object","properties":{"filter":{"type":"string","required":false,"sanitize_callback":"sanitize_text_field"},"limit":{"type":"int","required":false,"sanitize_callback":"absint"}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/get_tasks"}]}},"\/yoast\/v1\/action_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/yoast\/v1\/action_tracking"}]}},"\/jetpack\/v4":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4"}]}},"\/jetpack\/v4\/verify_xmlrpc_error":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"nonce":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/verify_xmlrpc_error"}]}},"\/jetpack\/v4\/heartbeat\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"prefix":{"description":"Prefix to add before the stats identifiers.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/heartbeat\/data"}]}},"\/complianz\/v1":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"complianz\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/complianz\/v1"}]}},"\/complianz\/v1\/documents":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/complianz\/v1\/documents"}]}},"\/complianz\/v1\/banner":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/complianz\/v1\/banner"}]}},"\/complianz\/v1\/track":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/complianz\/v1\/track"}]}},"\/complianz\/v1\/manage_consent_html":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/complianz\/v1\/manage_consent_html"}]}},"\/complianz\/v1\/store_cookies":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/complianz\/v1\/store_cookies"}]}},"\/complianz\/v1\/consent-area\/(?P<post_id>([0-9]+))\/(?P<block_id>([a-z0-9-_]+))":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/complianz\/v1\/datarequests":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/complianz\/v1\/datarequests"}]}},"\/complianz\/v1\/cookie_data":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/complianz\/v1\/cookie_data"}]}},"\/complianz\/v1\/wsc-scan":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/complianz\/v1\/wsc-scan"}]}},"\/complianz\/v1\/wsc-checks":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/complianz\/v1\/wsc-checks"}]}},"\/wc-admin":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-admin","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin"}]}},"\/wc-admin\/notice\/dismiss":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/notice\/dismiss"}]}},"\/wc-admin\/features":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/features"}]}},"\/wc-admin\/experiments\/assignment":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/experiments\/assignment"}]}},"\/wc-admin\/marketing\/recommended":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/marketing\/recommended"}]}},"\/wc-admin\/marketing\/knowledge-base":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/marketing\/knowledge-base"}]}},"\/wc-admin\/marketing\/misc-recommendations":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/marketing\/misc-recommendations"}]}},"\/wc-admin\/marketing\/overview\/activate-plugin":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/marketing\/overview\/activate-plugin"}]}},"\/wc-admin\/marketing\/overview\/installed-plugins":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/marketing\/overview\/installed-plugins"}]}},"\/wc-admin\/marketing\/recommendations":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"category":{"type":"string","enum":["channels","extensions"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/marketing\/recommendations"}]}},"\/wc-admin\/marketing\/channels":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/marketing\/channels"}]}},"\/wc-admin\/marketing\/campaigns":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/marketing\/campaigns"}]}},"\/wc-admin\/marketing\/campaign-types":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/marketing\/campaign-types"}]}},"\/wc-admin\/options":{"namespace":"wc-admin","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/options"}]}},"\/wc-admin\/legacy-settings":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"schema":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/legacy-settings"}]}},"\/wc-admin\/payment-gateway-suggestions":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"force_default_suggestions":{"type":"boolean","description":"Retourner au sugestion de paiements par d\u00e9faut lorsque les options woocommerce_show_marketplace_suggestions et woocommerce_setting_payments_recommendations_hidden sont fix\u00e9es sur NON","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/payment-gateway-suggestions"}]}},"\/wc-admin\/payment-gateway-suggestions\/dismiss":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/payment-gateway-suggestions\/dismiss"}]}},"\/wc-admin\/themes":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"pluginzip":{"description":"Fichier zip du th\u00e8me a mettre en ligne.","type":"file","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/themes"}]}},"\/wc-admin\/plugins\/install":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/plugins\/install"}]}},"\/wc-admin\/plugins\/install\/status":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/plugins\/install\/status"}]}},"\/wc-admin\/plugins\/install\/status\/(?P<job_id>[a-z0-9_\\-]+)":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/wc-admin\/plugins\/active":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/plugins\/active"}]}},"\/wc-admin\/plugins\/installed":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/plugins\/installed"}]}},"\/wc-admin\/plugins\/activate":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/plugins\/activate"}]}},"\/wc-admin\/plugins\/activate\/status":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/plugins\/activate\/status"}]}},"\/wc-admin\/plugins\/activate\/status\/(?P<job_id>[a-z0-9_\\-]+)":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/wc-admin\/plugins\/connect-jetpack":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/plugins\/connect-jetpack"}]}},"\/wc-admin\/plugins\/request-wccom-connect":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/plugins\/request-wccom-connect"}]}},"\/wc-admin\/plugins\/finish-wccom-connect":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/plugins\/finish-wccom-connect"}]}},"\/wc-admin\/plugins\/connect-wcpay":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/plugins\/connect-wcpay"}]}},"\/wc-admin\/plugins\/connect-square":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/plugins\/connect-square"}]}},"\/wc-admin\/onboarding\/free-extensions":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/free-extensions"}]}},"\/wc-admin\/onboarding\/product-types":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/product-types"}]}},"\/wc-admin\/onboarding\/profile":{"namespace":"wc-admin","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"completed":{"type":"boolean","description":"Indique si oui ou non le profil a \u00e9t\u00e9 compl\u00e9t\u00e9.","required":false},"skipped":{"type":"boolean","description":"Indique si oui ou non le profil a \u00e9t\u00e9 ignor\u00e9.","required":false},"industry":{"type":"array","description":"Industrie.","items":{"type":"string"},"required":false},"business_extensions":{"type":"array","description":"Extensions professionnelles suppl\u00e9mentaires \u00e0 installer.","items":{"type":"string"},"required":false},"is_agree_marketing":{"type":"boolean","description":"Indique si cette boutique a accept\u00e9 de recevoir des communications marketing de la part de WooCommerce.com.","required":false},"store_email":{"type":"string","description":"Adresse e-mail de la boutique.","required":false},"is_store_country_set":{"type":"boolean","description":"Si le pays de cette boutique est d\u00e9fini ou non via le profileur d\u2019int\u00e9gration.","required":false},"is_plugins_page_skipped":{"type":"boolean","description":"Si l\u2019\u00e9tape des extensions dans le core profiler a \u00e9t\u00e9 pass\u00e9e ou non.","required":false},"business_choice":{"type":"string","description":"Choix d\u2019entreprise.","required":false},"selling_online_answer":{"type":"string","description":"R\u00e9ponse Vente en ligne.","required":false},"selling_platforms":{"type":["array","null"],"description":"Plateformes de vente.","items":{"type":["string","null"]},"required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/profile"}]}},"\/wc-admin\/onboarding\/profile\/experimental_get_email_prefill":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/profile\/experimental_get_email_prefill"}]}},"\/wc-admin\/onboarding\/profile\/progress":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/profile\/progress"}]}},"\/wc-admin\/onboarding\/profile\/progress\/core-profiler\/complete":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"step":{"type":"string","description":"L\u2019\u00e9tape du core profiler \u00e0 marquer comme termin\u00e9e.","enum":["intro-opt-in","skip-guided-setup","user-profile","business-info","plugins","intro-builder","skip-guided-setup"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/profile\/progress\/core-profiler\/complete"}]}},"\/wc-admin\/onboarding\/profile\/update-store-currency-and-measurement-units":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"description":"Code pays.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/profile\/update-store-currency-and-measurement-units"}]}},"\/wc-admin\/onboarding\/tasks\/import_sample_products":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/tasks\/import_sample_products"}]}},"\/wc-admin\/onboarding\/tasks\/create_homepage":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/tasks\/create_homepage"}]}},"\/wc-admin\/onboarding\/tasks\/create_product_from_template":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"template_name":{"type":"string","description":"Nom du mod\u00e8le de produit.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/tasks\/create_product_from_template"}]}},"\/wc-admin\/onboarding\/tasks":{"namespace":"wc-admin","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"ids":{"description":"Param\u00e8tre facultatif pour obtenir uniquement des listes de t\u00e2ches sp\u00e9cifiques par ID.","type":"array","items":{"enum":[],"type":"string"},"required":false}}},{"methods":["POST"],"args":{"ids":{"description":"Param\u00e8tre facultatif pour obtenir uniquement des listes de t\u00e2ches sp\u00e9cifiques par ID.","type":"array","items":{"enum":[],"type":"string"},"required":false},"extended_tasks":{"description":"Liste des t\u00e2ches obsol\u00e8tes \u00e9tendues obtenue \u00e0 partir du filtre du client.","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/tasks"}]}},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/hide":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/unhide":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/dismiss":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/undo_dismiss":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_-]+)\/snooze":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"duration":{"description":"P\u00e9riode pour mettre en pause la t\u00e2che.","type":"string","required":false},"task_list_id":{"description":"Param\u00e8tre facultatif pour effectuer une requ\u00eate sur une liste de t\u00e2che pr\u00e9cise.","type":"string","required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/action":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/undo_snooze":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/onboarding\/themes\/install":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/themes\/install"}]}},"\/wc-admin\/onboarding\/themes\/activate":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/themes\/activate"}]}},"\/wc-admin\/onboarding\/plugins\/install-and-activate-async":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugins":{"description":"A list of plugins to install","type":"array","items":"string","required":true},"source":{"description":"The source of the request","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/plugins\/install-and-activate-async"}]}},"\/wc-admin\/onboarding\/plugins\/install-and-activate":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/plugins\/install-and-activate"}]}},"\/wc-admin\/onboarding\/plugins\/scheduled-installs\/(?P<job_id>\\w+)":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/wc-admin\/onboarding\/plugins\/jetpack-authorization-url":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_url":{"description":"The URL to redirect to after authorization","type":"string","required":true},"from":{"description":"from value for the jetpack authorization page","type":"string","default":"woocommerce-onboarding","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/plugins\/jetpack-authorization-url"}]}},"\/wc-admin\/onboarding\/products":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/onboarding\/products"}]}},"\/wc-admin\/mobile-app\/send-magic-link":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/mobile-app\/send-magic-link"}]}},"\/wc-admin\/mobile-app":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/mobile-app"}]}},"\/wc-admin\/shipping-partner-suggestions":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"force_default_suggestions":{"type":"boolean","description":"Renvoie les suggestions de partenaires d\u2019exp\u00e9dition par d\u00e9faut lorsque l\u2019option woocommerce_show_marketplace_suggestions est d\u00e9finie sur non","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/shipping-partner-suggestions"}]}},"\/wc-analytics":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-analytics","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics"}]}},"\/wc-analytics\/customers":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date_registered","enum":["username","name","first_name","last_name","email","location","country","city","state","postcode","date_registered","date_last_active","orders_count","total_spend","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"registered_before":{"description":"Limiter la r\u00e9ponse aux objets enregistr\u00e9s avant (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Limiter la r\u00e9ponse aux objets enregistr\u00e9s apr\u00e8s (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"match":{"description":"Indique si toutes les conditions doivent \u00eatre vraies pour le jeu de r\u00e9sultats ou si seule une condition suffit. La correspondance affecte les param\u00e8tres suivants\u00a0: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Limiter la r\u00e9ponse aux objets poss\u00e9dant un champ client contenant le terme recherch\u00e9. Recherche le champ fournit par \u00ab\u00a0searchby\u00a0\u00bb.","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des noms sp\u00e9cifiques.","type":"string","required":false},"name_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des noms sp\u00e9cifiques.","type":"string","required":false},"username_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des noms d\u2019utilisateur sp\u00e9cifiques.","type":"string","required":false},"username_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des noms d\u2019utilisateur sp\u00e9cifiques.","type":"string","required":false},"email_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des adresses e-mail.","type":"string","required":false},"email_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des adresses e-mail.","type":"string","required":false},"country_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des pays sp\u00e9cifiques.","type":"string","required":false},"country_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des pays sp\u00e9cifiques.","type":"string","required":false},"last_active_before":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient avant (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient apr\u00e8s (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient entre deux dates conformes ISO8601 donn\u00e9es.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient entre deux dates conformes ISO8601 donn\u00e9es.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Limiter la r\u00e9ponse aux objets dont le nombre de commandes est sup\u00e9rieur ou \u00e9gal \u00e0 la valeur enti\u00e8re donn\u00e9e.","type":"integer","required":false},"orders_count_max":{"description":"Limiter la r\u00e9ponse aux objets dont le nombre de commandes est inf\u00e9rieur ou \u00e9gal \u00e0 la valeur enti\u00e8re donn\u00e9e.","type":"integer","required":false},"orders_count_between":{"description":"Limiter la r\u00e9ponse aux objets dont le nombre de commandes est compris entre deux valeurs enti\u00e8res donn\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande totale est sup\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"total_spend_max":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande totale est inf\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"total_spend_between":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande totale est comprise entre deux valeurs donn\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande moyenne est sup\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"avg_order_value_max":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande moyenne est inf\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"avg_order_value_between":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande moyenne est comprise entre deux valeurs donn\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re commande intervient avant (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re commande intervient apr\u00e8s (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"users":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant les ID utilisateur sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"filter_empty":{"description":"Filtrer les r\u00e9sultats pour lesquels l\u2019un des champs saisis est vide","type":"array","items":{"type":"string","enum":["email","name","country","city","state","postcode"]},"required":false},"user_type":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant le type d\u2019utilisateur sp\u00e9cifi\u00e9.","type":"string","default":"all","enum":["all","registered","guest"],"required":false},"location_includes":{"description":"Inclut les clients par emplacement (\u00c9tat, pays). Fournissez une liste d\u2019emplacements s\u00e9parant les valeurs par des virgules. Chaque emplacement peut \u00eatre un code pays (p.\u00a0ex. GB) ou une combinaison d\u2019un pays et d\u2019un \u00c9tat (p.\u00a0ex. US:CA).","type":"string","required":false},"location_excludes":{"description":"Exclut les clients par emplacement (\u00c9tat, pays). Fournissez une liste d\u2019emplacements s\u00e9parant les valeurs par des virgules. Chaque emplacement peut \u00eatre un code pays (p.\u00a0ex. GB) ou une combinaison d\u2019un pays et d\u2019un \u00c9tat (p.\u00a0ex. US:CA).","type":"string","required":false},"include":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant les ID client sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/customers"}]}},"\/wc-analytics\/customers\/(?P<id>[\\d-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date_registered","enum":["username","name","first_name","last_name","email","location","country","city","state","postcode","date_registered","date_last_active","orders_count","total_spend","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"registered_before":{"description":"Limiter la r\u00e9ponse aux objets enregistr\u00e9s avant (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Limiter la r\u00e9ponse aux objets enregistr\u00e9s apr\u00e8s (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"match":{"description":"Indique si toutes les conditions doivent \u00eatre vraies pour le jeu de r\u00e9sultats ou si seule une condition suffit. La correspondance affecte les param\u00e8tres suivants\u00a0: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Limiter la r\u00e9ponse aux objets poss\u00e9dant un champ client contenant le terme recherch\u00e9. Recherche le champ fournit par \u00ab\u00a0searchby\u00a0\u00bb.","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des noms sp\u00e9cifiques.","type":"string","required":false},"name_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des noms sp\u00e9cifiques.","type":"string","required":false},"username_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des noms d\u2019utilisateur sp\u00e9cifiques.","type":"string","required":false},"username_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des noms d\u2019utilisateur sp\u00e9cifiques.","type":"string","required":false},"email_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des adresses e-mail.","type":"string","required":false},"email_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des adresses e-mail.","type":"string","required":false},"country_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des pays sp\u00e9cifiques.","type":"string","required":false},"country_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des pays sp\u00e9cifiques.","type":"string","required":false},"last_active_before":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient avant (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient apr\u00e8s (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient entre deux dates conformes ISO8601 donn\u00e9es.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient entre deux dates conformes ISO8601 donn\u00e9es.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Limiter la r\u00e9ponse aux objets dont le nombre de commandes est sup\u00e9rieur ou \u00e9gal \u00e0 la valeur enti\u00e8re donn\u00e9e.","type":"integer","required":false},"orders_count_max":{"description":"Limiter la r\u00e9ponse aux objets dont le nombre de commandes est inf\u00e9rieur ou \u00e9gal \u00e0 la valeur enti\u00e8re donn\u00e9e.","type":"integer","required":false},"orders_count_between":{"description":"Limiter la r\u00e9ponse aux objets dont le nombre de commandes est compris entre deux valeurs enti\u00e8res donn\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande totale est sup\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"total_spend_max":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande totale est inf\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"total_spend_between":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande totale est comprise entre deux valeurs donn\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande moyenne est sup\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"avg_order_value_max":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande moyenne est inf\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"avg_order_value_between":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande moyenne est comprise entre deux valeurs donn\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re commande intervient avant (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re commande intervient apr\u00e8s (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"users":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant les ID utilisateur sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"filter_empty":{"description":"Filtrer les r\u00e9sultats pour lesquels l\u2019un des champs saisis est vide","type":"array","items":{"type":"string","enum":["email","name","country","city","state","postcode"]},"required":false},"user_type":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant le type d\u2019utilisateur sp\u00e9cifi\u00e9.","type":"string","default":"all","enum":["all","registered","guest"],"required":false},"location_includes":{"description":"Inclut les clients par emplacement (\u00c9tat, pays). Fournissez une liste d\u2019emplacements s\u00e9parant les valeurs par des virgules. Chaque emplacement peut \u00eatre un code pays (p.\u00a0ex. GB) ou une combinaison d\u2019un pays et d\u2019un \u00c9tat (p.\u00a0ex. US:CA).","type":"string","required":false},"location_excludes":{"description":"Exclut les clients par emplacement (\u00c9tat, pays). Fournissez une liste d\u2019emplacements s\u00e9parant les valeurs par des virgules. Chaque emplacement peut \u00eatre un code pays (p.\u00a0ex. GB) ou une combinaison d\u2019un pays et d\u2019un \u00c9tat (p.\u00a0ex. US:CA).","type":"string","required":false},"include":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant les ID client sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wc-analytics\/leaderboards":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":5,"minimum":1,"maximum":20,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"persisted_query":{"description":"Requ\u00eate URL persistante \u00e0 travers les liens.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/leaderboards"}]}},"\/wc-analytics\/leaderboards\/allowed":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/leaderboards\/allowed"}]}},"\/wc-analytics\/leaderboards\/(?P<leaderboard>\\w+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"leaderboard":{"type":"string","enum":["customers","coupons","categories","products"],"required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":5,"minimum":1,"maximum":20,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"persisted_query":{"description":"Requ\u00eate URL persistante \u00e0 travers les liens.","type":"string","required":false}}}]},"\/wc-analytics\/reports":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports"}]}},"\/wc-analytics\/reports\/import":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"days":{"description":"Nombre de jours d\u2019importation.","type":"integer","minimum":0,"required":false},"skip_existing":{"description":"Ignorer l\u2019importation des donn\u00e9es de commande existantes.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/import"}]}},"\/wc-analytics\/reports\/import\/cancel":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/import\/cancel"}]}},"\/wc-analytics\/reports\/import\/delete":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/import\/delete"}]}},"\/wc-analytics\/reports\/import\/status":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/import\/status"}]}},"\/wc-analytics\/reports\/import\/totals":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"days":{"description":"Nombre de jours d\u2019importation.","type":"integer","minimum":0,"required":false},"skip_existing":{"description":"Ignorer l\u2019importation des donn\u00e9es de commande existantes.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/import\/totals"}]}},"\/wc-analytics\/reports\/(?P<type>[a-z]+)\/export":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"report_args":{"description":"Param\u00e8tres de validation du rapport export\u00e9.","type":"object","required":false},"email":{"description":"Lorsque la valeur est vraie, un lien de t\u00e9l\u00e9chargement de l\u2019exportation est envoy\u00e9 par e-mail au demandeur.","type":"boolean","required":false}}}]},"\/wc-analytics\/reports\/(?P<type>[a-z]+)\/export\/(?P<export_id>[a-z0-9]+)\/status":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/wc-analytics\/reports\/products":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","net_revenue","orders_count","items_sold","product_name","variations","sku"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"categories":{"description":"Limiter le r\u00e9sultat aux articles appartenant aux cat\u00e9gories sp\u00e9cifi\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"match":{"description":"Indique si toutes les conditions doivent \u00eatre vraies pour le jeu de r\u00e9sultats ou si seule une condition suffit. La correspondance affecte les param\u00e8tres suivants\u00a0: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"products":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant les ID produit sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"Ajouter une information suppl\u00e9mentaire sur chaque produit au rapport.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/products"}]}},"\/wc-analytics\/reports\/variations":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","net_revenue","orders_count","items_sold","sku"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"match":{"description":"Indique si toutes les conditions doivent \u00eatre vraies pour le jeu de r\u00e9sultats ou si seule une condition suffit. La correspondance affecte les param\u00e8tres suivants\u00a0: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"product_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles qui incluent le ou les produits parents sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles qui n\u2019incluent pas le ou les produits parents sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variations":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant les ID de variation sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"Ajouter une information suppl\u00e9mentaire sur chaque variation au rapport.","type":"boolean","default":false,"required":false},"attribute_is":{"description":"Limiter le jeu de r\u00e9sultats aux variations qui incluent les attributs sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limiter le jeu de r\u00e9sultats aux variations qui n\u2019incluent pas les attributs sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"array"},"default":[],"required":false},"category_includes":{"description":"Limiter le jeu de r\u00e9sultats aux variations appartenant aux cat\u00e9gories sp\u00e9cifi\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"category_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux variations n\u2019appartenant pas aux cat\u00e9gories sp\u00e9cifi\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"products":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant les ID produit sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/variations"}]}},"\/wc-analytics\/reports\/products\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","net_revenue","coupons","refunds","shipping","taxes","net_revenue","orders_count","items_sold"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"fields":{"description":"Limiter les champs relatifs aux statistiques aux \u00e9l\u00e9ments sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Intervalle de temps \u00e0 appliquer aux compartiments dans les donn\u00e9es retourn\u00e9es.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"categories":{"description":"Limiter le r\u00e9sultat aux articles appartenant aux cat\u00e9gories sp\u00e9cifi\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"products":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant les ID produit sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"variations":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant les ID de variation sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Segmenter la r\u00e9ponse par une contrainte suppl\u00e9mentaire.","type":"string","enum":["product","category","variation"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/products\/stats"}]}},"\/wc-analytics\/reports\/variations\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","net_revenue","coupons","refunds","shipping","taxes","net_revenue","orders_count","items_sold"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"fields":{"description":"Limiter les champs relatifs aux statistiques aux \u00e9l\u00e9ments sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Intervalle de temps \u00e0 appliquer aux compartiments dans les donn\u00e9es retourn\u00e9es.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"match":{"description":"Indique si toutes les conditions doivent \u00eatre vraies pour le jeu de r\u00e9sultats ou si seule une condition suffit. La correspondance affecte les param\u00e8tres suivants\u00a0: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"category_includes":{"description":"Limiter le r\u00e9sultat aux articles appartenant aux cat\u00e9gories sp\u00e9cifi\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"category_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux variations n\u2019appartenant pas aux cat\u00e9gories sp\u00e9cifi\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"product_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles qui incluent le ou les produits parents sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles qui n\u2019incluent pas le ou les produits parents sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variations":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant les ID de variation sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Segmenter la r\u00e9ponse par une contrainte suppl\u00e9mentaire.","type":"string","enum":["product","category","variation"],"required":false},"attribute_is":{"description":"Limiter les r\u00e9sultats aux commandes qui incluent les produits avec les attributs sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limiter les r\u00e9sultats aux commandes qui n\u2019incluent pas les produits avec les attributs sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"array"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/variations\/stats"}]}},"\/wc-analytics\/reports\/revenue\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","total_sales","coupons","refunds","shipping","taxes","net_revenue","orders_count","items_sold","gross_sales"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"interval":{"description":"Intervalle de temps \u00e0 appliquer aux compartiments dans les donn\u00e9es retourn\u00e9es.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"segmentby":{"description":"Segmenter la r\u00e9ponse par une contrainte suppl\u00e9mentaire.","type":"string","enum":["product","category","variation","coupon","customer_type"],"required":false},"date_type":{"description":"Contournez l\u2019option \u00ab\u00a0woocommerce_date_type\u00a0\u00bb qui est utilis\u00e9e pour le champ date de la base de donn\u00e9es envisag\u00e9e pour les rapports de recettes.","type":"string","enum":["date_paid","date_created","date_completed"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/revenue\/stats"}]}},"\/wc-analytics\/reports\/orders":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":0,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","num_items_sold","net_total"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"product_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les produits sp\u00e9cifi\u00e9s sont assign\u00e9s","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les produits sp\u00e9cifi\u00e9s ne sont pas assign\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels la ou les variations sp\u00e9cifi\u00e9es sont assign\u00e9es.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels la ou les variations sp\u00e9cifi\u00e9es ne sont pas assign\u00e9es.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les codes promo sp\u00e9cifi\u00e9s sont assign\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les codes promo sp\u00e9cifi\u00e9s ne sont pas assign\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les taux de taxe sp\u00e9cifi\u00e9s sont assign\u00e9s","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les taux de taxe sp\u00e9cifi\u00e9s ne sont pas assign\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status_is":{"description":"Limiter le jeu de r\u00e9sultats aux articles poss\u00e9dant le statut de commande sp\u00e9cifi\u00e9.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"status_is_not":{"description":"Limiter le jeu de r\u00e9sultats aux articles ne poss\u00e9dant pas le statut de commande sp\u00e9cifi\u00e9.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"customer_type":{"description":"Limiter le jeu de r\u00e9sultats aux clients nouveaux ou existants.","type":"string","default":"","enum":["","returning","new"],"required":false},"refunds":{"description":"Limiter le jeu de r\u00e9sultats aux types sp\u00e9cifiques de remboursements.","type":"string","default":"","enum":["","all","partial","full","none"],"required":false},"extended_info":{"description":"Ajouter une information suppl\u00e9mentaire sur chaque code promo au rapport.","type":"boolean","default":false,"required":false},"order_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles poss\u00e9dant les ID de commande sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"order_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles ne poss\u00e9dant pas les ID de commande sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"attribute_is":{"description":"Limiter les r\u00e9sultats aux commandes qui incluent les produits avec les attributs sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limiter les r\u00e9sultats aux commandes qui n\u2019incluent pas les produits avec les attributs sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"array"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/orders"}]}},"\/wc-analytics\/reports\/orders\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","net_revenue","orders_count","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"interval":{"description":"Intervalle de temps \u00e0 appliquer aux compartiments dans les donn\u00e9es retourn\u00e9es.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"match":{"description":"Indique si toutes les conditions doivent \u00eatre vraies pour le jeu de r\u00e9sultats ou si seule une condition suffit. La correspondance affecte les param\u00e8tres suivants\u00a0: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"status_is":{"description":"Limiter le jeu de r\u00e9sultats aux articles poss\u00e9dant le statut de commande sp\u00e9cifi\u00e9.","type":"array","default":null,"items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"status_is_not":{"description":"Limiter le jeu de r\u00e9sultats aux articles ne poss\u00e9dant pas le statut de commande sp\u00e9cifi\u00e9.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"product_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les produits sp\u00e9cifi\u00e9s sont assign\u00e9s","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les produits sp\u00e9cifi\u00e9s ne sont pas assign\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels la ou les variations sp\u00e9cifi\u00e9es sont assign\u00e9es.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels la ou les variations sp\u00e9cifi\u00e9es ne sont pas assign\u00e9es.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les codes promo sp\u00e9cifi\u00e9s sont assign\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les codes promo sp\u00e9cifi\u00e9s ne sont pas assign\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les taux de taxe sp\u00e9cifi\u00e9s sont assign\u00e9s","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les taux de taxe sp\u00e9cifi\u00e9s ne sont pas assign\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"customer":{"description":"Alias de customer_type (obsol\u00e8te).","type":"string","enum":["new","returning"],"required":false},"customer_type":{"description":"Limiter le jeu de commandes aux articles poss\u00e9dant le customer_type sp\u00e9cifi\u00e9.","type":"string","enum":["new","returning"],"required":false},"refunds":{"description":"Limiter le jeu de r\u00e9sultats aux types sp\u00e9cifiques de remboursements.","type":"string","default":"","enum":["","all","partial","full","none"],"required":false},"attribute_is":{"description":"Limiter les r\u00e9sultats aux commandes qui incluent les produits avec les attributs sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limiter les r\u00e9sultats aux commandes qui n\u2019incluent pas les produits avec les attributs sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"array"},"default":[],"required":false},"segmentby":{"description":"Segmenter la r\u00e9ponse par une contrainte suppl\u00e9mentaire.","type":"string","enum":["product","category","variation","coupon","customer_type"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/orders\/stats"}]}},"\/wc-analytics\/reports\/categories":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"category_id","enum":["category_id","items_sold","net_revenue","orders_count","products_count","category"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"interval":{"description":"Intervalle de temps \u00e0 appliquer aux compartiments dans les donn\u00e9es retourn\u00e9es.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"status_is":{"description":"Limiter le jeu de r\u00e9sultats aux articles poss\u00e9dant le statut de commande sp\u00e9cifi\u00e9.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"status_is_not":{"description":"Limiter le jeu de r\u00e9sultats aux articles ne poss\u00e9dant pas le statut de commande sp\u00e9cifi\u00e9.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles dont le terme sp\u00e9cifi\u00e9 est assign\u00e9 dans la taxonomie des cat\u00e9gories.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"Ajouter une information suppl\u00e9mentaire sur chaque cat\u00e9gorie au rapport.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/categories"}]}},"\/wc-analytics\/reports\/taxes":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"tax_rate_id","enum":["name","tax_rate_id","tax_code","rate","order_tax","total_tax","shipping_tax","orders_count"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"taxes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels une ou plusieurs taxes sont assign\u00e9es.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/taxes"}]}},"\/wc-analytics\/reports\/taxes\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","items_sold","total_sales","orders_count","products_count"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"fields":{"description":"Limiter les champs relatifs aux statistiques aux \u00e9l\u00e9ments sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Intervalle de temps \u00e0 appliquer aux compartiments dans les donn\u00e9es retourn\u00e9es.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"taxes":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles dont le terme sp\u00e9cifi\u00e9 est assign\u00e9 dans la taxonomie des taxes.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Segmenter la r\u00e9ponse par une contrainte suppl\u00e9mentaire.","type":"string","enum":["tax_rate_id"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/taxes\/stats"}]}},"\/wc-analytics\/reports\/coupons":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"coupon_id","enum":["coupon_id","code","amount","orders_count"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"coupons":{"description":"Limiter le jeu de r\u00e9sultats aux codes promo assign\u00e9s \u00e0 des ID de codes promo sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"Ajouter une information suppl\u00e9mentaire sur chaque code promo au rapport.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/coupons"}]}},"\/wc-analytics\/reports\/coupons\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","amount","coupons_count","orders_count"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"fields":{"description":"Limiter les champs relatifs aux statistiques aux \u00e9l\u00e9ments sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Intervalle de temps \u00e0 appliquer aux compartiments dans les donn\u00e9es retourn\u00e9es.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"coupons":{"description":"Limiter le jeu de r\u00e9sultats aux codes promo assign\u00e9s \u00e0 des ID de codes promo sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Segmenter la r\u00e9ponse par une contrainte suppl\u00e9mentaire.","type":"string","enum":["product","variation","category","coupon"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/coupons\/stats"}]}},"\/wc-analytics\/reports\/stock":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"stock_status","enum":["stock_status","stock_quantity","date","id","include","title","sku"],"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels un type de rapport de stock est assign\u00e9.","type":"string","default":"all","enum":["all","lowstock","instock","outofstock","onbackorder"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/stock"}]}},"\/wc-analytics\/reports\/stock\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/stock\/stats"}]}},"\/wc-analytics\/reports\/downloads":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","product"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"match":{"description":"Indique si toutes les conditions doivent \u00eatre vraies pour le jeu de r\u00e9sultats ou si seule une condition suffit. La correspondance affecte les param\u00e8tres suivants\u00a0: products, orders, username, ip_address.","type":"string","default":"all","enum":["all","any"],"required":false},"product_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les produits sp\u00e9cifi\u00e9s sont assign\u00e9s","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les produits sp\u00e9cifi\u00e9s ne sont pas assign\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles poss\u00e9dant les ID de commande sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"order_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles ne poss\u00e9dant pas les ID de commande sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"customer_includes":{"description":"Limiter la r\u00e9ponse aux objets poss\u00e9dant les ID utilisateur sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"customer_excludes":{"description":"Limiter la r\u00e9ponse aux objets ne poss\u00e9dant pas les ID utilisateur sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"ip_address_includes":{"description":"Limiter la r\u00e9ponse aux objets poss\u00e9dant une adresse IP sp\u00e9cifi\u00e9e.","type":"array","items":{"type":"string"},"required":false},"ip_address_excludes":{"description":"Limiter la r\u00e9ponse aux objets ne poss\u00e9dant pas une adresse IP sp\u00e9cifi\u00e9e.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/downloads"}]}},"\/wc-analytics\/reports\/downloads\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","download_count"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"fields":{"description":"Limiter les champs relatifs aux statistiques aux \u00e9l\u00e9ments sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Intervalle de temps \u00e0 appliquer aux compartiments dans les donn\u00e9es retourn\u00e9es.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"match":{"description":"Indique si toutes les conditions doivent \u00eatre vraies pour le jeu de r\u00e9sultats ou si seule une condition suffit. La correspondance affecte les param\u00e8tres suivants\u00a0: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"product_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les produits sp\u00e9cifi\u00e9s sont assign\u00e9s","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles auxquels le ou les produits sp\u00e9cifi\u00e9s ne sont pas assign\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order_includes":{"description":"Limiter le jeu de r\u00e9sultats aux articles poss\u00e9dant les ID de commande sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"order_excludes":{"description":"Limiter le jeu de r\u00e9sultats aux articles ne poss\u00e9dant pas les ID de commande sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"customer_includes":{"description":"Limiter la r\u00e9ponse aux objets poss\u00e9dant les ID client sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"customer_excludes":{"description":"Limiter la r\u00e9ponse aux objets ne poss\u00e9dant pas les ID client sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"ip_address_includes":{"description":"Limiter la r\u00e9ponse aux objets poss\u00e9dant une adresse IP sp\u00e9cifi\u00e9e.","type":"array","items":{"type":"string"},"required":false},"ip_address_excludes":{"description":"Limiter la r\u00e9ponse aux objets ne poss\u00e9dant pas une adresse IP sp\u00e9cifi\u00e9e.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/downloads\/stats"}]}},"\/wc-analytics\/reports\/customers":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date_registered","enum":["username","name","first_name","last_name","email","location","country","city","state","postcode","date_registered","date_last_active","orders_count","total_spend","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false},"registered_before":{"description":"Limiter la r\u00e9ponse aux objets enregistr\u00e9s avant (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Limiter la r\u00e9ponse aux objets enregistr\u00e9s apr\u00e8s (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"match":{"description":"Indique si toutes les conditions doivent \u00eatre vraies pour le jeu de r\u00e9sultats ou si seule une condition suffit. La correspondance affecte les param\u00e8tres suivants\u00a0: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Limiter la r\u00e9ponse aux objets poss\u00e9dant un champ client contenant le terme recherch\u00e9. Recherche le champ fournit par \u00ab\u00a0searchby\u00a0\u00bb.","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des noms sp\u00e9cifiques.","type":"string","required":false},"name_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des noms sp\u00e9cifiques.","type":"string","required":false},"username_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des noms d\u2019utilisateur sp\u00e9cifiques.","type":"string","required":false},"username_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des noms d\u2019utilisateur sp\u00e9cifiques.","type":"string","required":false},"email_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des adresses e-mail.","type":"string","required":false},"email_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des adresses e-mail.","type":"string","required":false},"country_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des pays sp\u00e9cifiques.","type":"string","required":false},"country_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des pays sp\u00e9cifiques.","type":"string","required":false},"last_active_before":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient avant (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient apr\u00e8s (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient entre deux dates conformes ISO8601 donn\u00e9es.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient entre deux dates conformes ISO8601 donn\u00e9es.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Limiter la r\u00e9ponse aux objets dont le nombre de commandes est sup\u00e9rieur ou \u00e9gal \u00e0 la valeur enti\u00e8re donn\u00e9e.","type":"integer","required":false},"orders_count_max":{"description":"Limiter la r\u00e9ponse aux objets dont le nombre de commandes est inf\u00e9rieur ou \u00e9gal \u00e0 la valeur enti\u00e8re donn\u00e9e.","type":"integer","required":false},"orders_count_between":{"description":"Limiter la r\u00e9ponse aux objets dont le nombre de commandes est compris entre deux valeurs enti\u00e8res donn\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande totale est sup\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"total_spend_max":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande totale est inf\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"total_spend_between":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande totale est comprise entre deux valeurs donn\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande moyenne est sup\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"avg_order_value_max":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande moyenne est inf\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"avg_order_value_between":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande moyenne est comprise entre deux valeurs donn\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re commande intervient avant (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re commande intervient apr\u00e8s (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"customers":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant les ID client sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"users":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant les ID utilisateur sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"filter_empty":{"description":"Filtrer les r\u00e9sultats pour lesquels l\u2019un des champs saisis est vide","type":"array","items":{"type":"string","enum":["email","name","country","city","state","postcode"]},"required":false},"user_type":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant le type d\u2019utilisateur sp\u00e9cifi\u00e9.","type":"string","default":"all","enum":["all","registered","guest"],"required":false},"location_includes":{"description":"Inclut les clients par emplacement (\u00c9tat, pays). Fournissez une liste d\u2019emplacements s\u00e9parant les valeurs par des virgules. Chaque emplacement peut \u00eatre un code pays (p.\u00a0ex. GB) ou une combinaison d\u2019un pays et d\u2019un \u00c9tat (p.\u00a0ex. US:CA).","type":"string","required":false},"location_excludes":{"description":"Exclut les clients par emplacement (\u00c9tat, pays). Fournissez une liste d\u2019emplacements s\u00e9parant les valeurs par des virgules. Chaque emplacement peut \u00eatre un code pays (p.\u00a0ex. GB) ou une combinaison d\u2019un pays et d\u2019un \u00c9tat (p.\u00a0ex. US:CA).","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/customers"}]}},"\/wc-analytics\/reports\/customers\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"registered_before":{"description":"Limiter la r\u00e9ponse aux objets enregistr\u00e9s avant (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Limiter la r\u00e9ponse aux objets enregistr\u00e9s apr\u00e8s (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"match":{"description":"Indique si toutes les conditions doivent \u00eatre vraies pour le jeu de r\u00e9sultats ou si seule une condition suffit. La correspondance affecte les param\u00e8tres suivants\u00a0: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Limiter la r\u00e9ponse aux objets poss\u00e9dant un champ client contenant le terme recherch\u00e9. Recherche le champ fournit par \u00ab\u00a0searchby\u00a0\u00bb.","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des noms sp\u00e9cifiques.","type":"string","required":false},"name_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des noms sp\u00e9cifiques.","type":"string","required":false},"username_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des noms d\u2019utilisateur sp\u00e9cifiques.","type":"string","required":false},"username_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des noms d\u2019utilisateur sp\u00e9cifiques.","type":"string","required":false},"email_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des adresses e-mail.","type":"string","required":false},"email_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des adresses e-mail.","type":"string","required":false},"country_includes":{"description":"Limiter la r\u00e9ponse aux objets int\u00e9grant des pays sp\u00e9cifiques.","type":"string","required":false},"country_excludes":{"description":"Limiter la r\u00e9ponse aux objets excluant des pays sp\u00e9cifiques.","type":"string","required":false},"last_active_before":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient avant (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient apr\u00e8s (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient entre deux dates conformes ISO8601 donn\u00e9es.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re activit\u00e9 intervient entre deux dates conformes ISO8601 donn\u00e9es.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Limiter la r\u00e9ponse aux objets dont le nombre de commandes est sup\u00e9rieur ou \u00e9gal \u00e0 la valeur enti\u00e8re donn\u00e9e.","type":"integer","required":false},"orders_count_max":{"description":"Limiter la r\u00e9ponse aux objets dont le nombre de commandes est inf\u00e9rieur ou \u00e9gal \u00e0 la valeur enti\u00e8re donn\u00e9e.","type":"integer","required":false},"orders_count_between":{"description":"Limiter la r\u00e9ponse aux objets dont le nombre de commandes est compris entre deux valeurs enti\u00e8res donn\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande totale est sup\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"total_spend_max":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande totale est inf\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"total_spend_between":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande totale est comprise entre deux valeurs donn\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande moyenne est sup\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"avg_order_value_max":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande moyenne est inf\u00e9rieure ou \u00e9gale \u00e0 la valeur donn\u00e9e.","type":"number","required":false},"avg_order_value_between":{"description":"Limiter la r\u00e9ponse aux objets dont la d\u00e9pense de commande moyenne est comprise entre deux valeurs donn\u00e9es.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re commande intervient avant (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Limiter la r\u00e9ponse aux objets dont la derni\u00e8re commande intervient apr\u00e8s (ou \u00e0) une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"customers":{"description":"Limiter le r\u00e9sultat aux articles poss\u00e9dant les ID client sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"required":false},"fields":{"description":"Limiter les champs relatifs aux statistiques aux \u00e9l\u00e9ments sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"string"},"required":false},"force_cache_refresh":{"description":"Forcer la r\u00e9cup\u00e9ration de nouvelles donn\u00e9es plut\u00f4t que du cache.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/customers\/stats"}]}},"\/wc-analytics\/imports\/status":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/imports\/status"}]}},"\/wc-analytics\/imports\/trigger":{"namespace":"wc-analytics","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/imports\/trigger"}]}},"\/wc-analytics\/reports\/performance-indicators":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"stats":{"description":"Limiter la r\u00e9ponse aux statistiques de rapport sp\u00e9cifiques. Valeurs autoris\u00e9es\u00a0: .","type":"array","items":{"type":"string","enum":[]},"default":[],"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/performance-indicators"}]}},"\/wc-analytics\/reports\/performance-indicators\/allowed":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"stats":{"description":"Limiter la r\u00e9ponse aux statistiques de rapport sp\u00e9cifiques. Valeurs autoris\u00e9es\u00a0: .","type":"array","items":{"type":"string","enum":[]},"default":[],"required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/reports\/performance-indicators\/allowed"}]}},"\/wc-analytics\/admin\/notes":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["note_id","date","type","title","status"],"required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"type":{"description":"Type de note.","type":"array","items":{"enum":["error","warning","update","info","marketing","survey"],"type":"string"},"required":false},"status":{"description":"Statut de la note.","type":"array","items":{"enum":["pending","actioned","unactioned","snoozed","sent"],"type":"string"},"required":false},"source":{"description":"Source de la note.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/admin\/notes"}]}},"\/wc-analytics\/admin\/notes\/(?P<id>[\\d-]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID unique pour la ressource.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID unique pour la ressource.","type":"integer","required":false}}}]},"\/wc-analytics\/admin\/notes\/delete\/(?P<id>[\\d-]+)":{"namespace":"wc-analytics","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}]},"\/wc-analytics\/admin\/notes\/delete\/all":{"namespace":"wc-analytics","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"status":{"description":"Statut de la note.","type":"array","items":{"enum":["pending","actioned","unactioned","snoozed","sent"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/admin\/notes\/delete\/all"}]}},"\/wc-analytics\/admin\/notes\/update":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/admin\/notes\/update"}]}},"\/wc-analytics\/admin\/notes\/experimental-activate-promo\/(?P<promo_note_name>[\\w-]+)":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-analytics\/admin\/notes\/(?P<note_id>[\\d-]+)\/action\/(?P<action_id>[\\d-]+)":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"note_id":{"description":"ID unique de la note.","type":"integer","required":false},"action_id":{"description":"ID unique de l\u2019action de note.","type":"integer","required":false}}}]},"\/wc-analytics\/coupons":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats aux codes promo dont les codes correspondent \u00e0 une cha\u00eene donn\u00e9e.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"code":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un code sp\u00e9cifique.","type":"string","required":false}}},{"methods":["POST"],"args":{"code":{"description":"Code promo.","type":"string","required":true},"amount":{"description":"Le montant de la remise. Doit toujours \u00eatre num\u00e9rique, m\u00eame si vous d\u00e9finissez un pourcentage.","type":["number","string"],"required":false},"status":{"description":"\u00c9tat du code promo. Doit toujours \u00eatre \u00e0 l\u2019\u00e9tat de brouillon, publi\u00e9 ou en cours de r\u00e9vision","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"D\u00e9termine le type de remise qui sera appliqu\u00e9.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Description du code promo.","type":"string","required":false},"date_expires":{"description":"Date d\u2019expiration du code promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"Date d\u2019expiration du code promo, format GMT.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"Si vrai, le code promo ne peut \u00eatre utilis\u00e9 qu&rsquo;individuellement. Les autres codes promo appliqu\u00e9s seront retir\u00e9s du panier.","type":"boolean","required":false},"product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo peut \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo ne peut pas \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Combien de fois le code promo peut \u00eatre utilis\u00e9.","type":"integer","required":false},"usage_limit_per_user":{"description":"Nombre de fois que le code promo peut \u00eatre utilis\u00e9 par client.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Nombre maximum d&rsquo;articles dans le panier auxquels le code promo peut \u00eatre appliqu\u00e9.","type":"integer","required":false},"free_shipping":{"default":false,"description":"Si vrai et que le mode d\u2019exp\u00e9dition gratuite n\u00e9cessite un code promo, ce code promo activera la livraison gratuite.","type":"boolean","required":false},"product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo s\u2019applique.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo ne s&rsquo;applique pas.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"Si vrai, ce code promo ne sera pas appliqu\u00e9 aux articles qui sont en promotion.","type":"boolean","required":false},"minimum_amount":{"description":"Montant minimum de commande qui doit \u00eatre dans le panier avant que le code promo ne s\u2019applique.","type":["number","string"],"required":false},"maximum_amount":{"description":"Montant maximum de commande autoris\u00e9 lors de l&rsquo;utilisation du code promo.","type":["number","string"],"required":false},"email_restrictions":{"description":"Liste des e-mails qui peuvent utiliser ce code promo.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/coupons"}]}},"\/wc-analytics\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"code":{"description":"Code promo.","type":"string","required":false},"amount":{"description":"Le montant de la remise. Doit toujours \u00eatre num\u00e9rique, m\u00eame si vous d\u00e9finissez un pourcentage.","type":["number","string"],"required":false},"status":{"description":"\u00c9tat du code promo. Doit toujours \u00eatre \u00e0 l\u2019\u00e9tat de brouillon, publi\u00e9 ou en cours de r\u00e9vision","type":"string","required":false},"discount_type":{"description":"D\u00e9termine le type de remise qui sera appliqu\u00e9.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Description du code promo.","type":"string","required":false},"date_expires":{"description":"Date d\u2019expiration du code promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"Date d\u2019expiration du code promo, format GMT.","type":["null","string"],"required":false},"individual_use":{"description":"Si vrai, le code promo ne peut \u00eatre utilis\u00e9 qu&rsquo;individuellement. Les autres codes promo appliqu\u00e9s seront retir\u00e9s du panier.","type":"boolean","required":false},"product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo peut \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo ne peut pas \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Combien de fois le code promo peut \u00eatre utilis\u00e9.","type":"integer","required":false},"usage_limit_per_user":{"description":"Nombre de fois que le code promo peut \u00eatre utilis\u00e9 par client.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Nombre maximum d&rsquo;articles dans le panier auxquels le code promo peut \u00eatre appliqu\u00e9.","type":"integer","required":false},"free_shipping":{"description":"Si vrai et que le mode d\u2019exp\u00e9dition gratuite n\u00e9cessite un code promo, ce code promo activera la livraison gratuite.","type":"boolean","required":false},"product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo s\u2019applique.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo ne s&rsquo;applique pas.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si vrai, ce code promo ne sera pas appliqu\u00e9 aux articles qui sont en promotion.","type":"boolean","required":false},"minimum_amount":{"description":"Montant minimum de commande qui doit \u00eatre dans le panier avant que le code promo ne s\u2019applique.","type":["number","string"],"required":false},"maximum_amount":{"description":"Montant maximum de commande autoris\u00e9 lors de l&rsquo;utilisation du code promo.","type":["number","string"],"required":false},"email_restrictions":{"description":"Liste des e-mails qui peuvent utiliser ce code promo.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc-analytics\/coupons\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"Code promo.","type":"string","required":false},"amount":{"description":"Le montant de la remise. Doit toujours \u00eatre num\u00e9rique, m\u00eame si vous d\u00e9finissez un pourcentage.","type":["number","string"],"required":false},"status":{"description":"\u00c9tat du code promo. Doit toujours \u00eatre \u00e0 l\u2019\u00e9tat de brouillon, publi\u00e9 ou en cours de r\u00e9vision","type":"string","required":false},"discount_type":{"description":"D\u00e9termine le type de remise qui sera appliqu\u00e9.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Description du code promo.","type":"string","required":false},"date_expires":{"description":"Date d\u2019expiration du code promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"Date d\u2019expiration du code promo, format GMT.","type":["null","string"],"required":false},"individual_use":{"description":"Si vrai, le code promo ne peut \u00eatre utilis\u00e9 qu&rsquo;individuellement. Les autres codes promo appliqu\u00e9s seront retir\u00e9s du panier.","type":"boolean","required":false},"product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo peut \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo ne peut pas \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Combien de fois le code promo peut \u00eatre utilis\u00e9.","type":"integer","required":false},"usage_limit_per_user":{"description":"Nombre de fois que le code promo peut \u00eatre utilis\u00e9 par client.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Nombre maximum d&rsquo;articles dans le panier auxquels le code promo peut \u00eatre appliqu\u00e9.","type":"integer","required":false},"free_shipping":{"description":"Si vrai et que le mode d\u2019exp\u00e9dition gratuite n\u00e9cessite un code promo, ce code promo activera la livraison gratuite.","type":"boolean","required":false},"product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo s\u2019applique.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo ne s&rsquo;applique pas.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si vrai, ce code promo ne sera pas appliqu\u00e9 aux articles qui sont en promotion.","type":"boolean","required":false},"minimum_amount":{"description":"Montant minimum de commande qui doit \u00eatre dans le panier avant que le code promo ne s\u2019applique.","type":["number","string"],"required":false},"maximum_amount":{"description":"Montant maximum de commande autoris\u00e9 lors de l&rsquo;utilisation du code promo.","type":["number","string"],"required":false},"email_restrictions":{"description":"Liste des e-mails qui peuvent utiliser ce code promo.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/coupons\/batch"}]}},"\/wc-analytics\/data":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/data"}]}},"\/wc-analytics\/data\/countries\/locales":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/data\/countries\/locales"}]}},"\/wc-analytics\/data\/countries":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/data\/countries"}]}},"\/wc-analytics\/data\/countries\/(?P<location>[\\w-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Code de pays alpha-2 ISO3166.","type":"string","required":false}}}]},"\/wc-analytics\/data\/download-ips":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/data\/download-ips"}]}},"\/wc-analytics\/orders":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":["any"],"description":"Limiter les r\u00e9sultats aux commandes qui ont les \u00e9tats sp\u00e9cifiques.","type":"array","items":{"type":"string","enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"]},"required":false},"customer":{"description":"Limiter le jeu de r\u00e9sultats aux commandes affect\u00e9es \u00e0 un client sp\u00e9cifique.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux commandes affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","required":false},"dp":{"default":2,"description":"Nombre de d\u00e9cimales \u00e0 utiliser dans chaque ressource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Affichez uniquement la m\u00e9ta qui est cens\u00e9e s\u2019afficher pour une commande.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"created_via":{"description":"Limiter le jeu de r\u00e9sultats aux commandes cr\u00e9\u00e9es via des sources sp\u00e9cifiques (par ex. validation de la commande, administrateur).","type":"array","items":{"type":"string"},"required":false},"number":{"description":"Limiter le jeu de r\u00e9sultats aux commandes correspondant partiellement au num\u00e9ro de commande.","type":"string","required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"ID de commande parente.","type":"integer","required":false},"created_via":{"description":"Affiche o\u00f9 la commande a \u00e9t\u00e9 cr\u00e9\u00e9e.","type":"string","required":false},"status":{"default":"pending","description":"\u00c9tat de la commande.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"EUR","description":"Devise avec laquelle la commande a \u00e9t\u00e9 cr\u00e9\u00e9e, au format ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"ID utilisateur propri\u00e9taire de la commande. 0 pour les invit\u00e9s.","type":"integer","required":false},"customer_note":{"description":"Note laiss\u00e9e par le client lors de la commande.","type":"string","required":false},"billing":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID du moyen de paiement.","type":"string","required":false},"payment_method_title":{"description":"Titre du moyen de paiement.","type":"string","required":false},"transaction_id":{"description":"ID unique de transaction.","type":"string","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Ligne de donn\u00e9es des articles.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom du produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nom du produit parent si le produit est une variation.","type":"string","context":["view","edit"]},"product_id":{"description":"ID produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variation, si applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantit\u00e9 command\u00e9.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Classe de taxe de produit.","type":"string","context":["view","edit"]},"subtotal":{"description":"Ligne de sous-total (avant remises).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Ligne de sous-total de taxe (avant remises).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"]},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"]},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Cl\u00e9 m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]},"display_value":{"description":"Valeur de m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]}}}},"sku":{"description":"UGS du produit.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tarif du produit.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propri\u00e9t\u00e9s de l\u2019image principale du produit.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de l\u2019instance d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Ligne de donn\u00e9es des codes promo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Code promo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Remise totale.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Taxe totale de la remise.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Type de remise.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Montant de la remise telle que d\u00e9finie dans le code promo (valeur absolue ou pourcentage, en fonction du type de remise).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si le code promo donne droit \u00e0 la livraison gratuite ou non.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"default":false,"description":"D\u00e9termine si la commande est pay\u00e9e. Cela va d\u00e9finir l\u2019\u00e9tat \u00e0 en cours et r\u00e9duire de stock des articles.","type":"boolean","required":false},"manual_update":{"default":false,"description":"D\u00e9finir l\u2019action sur manuel pour que la note de commande s\u2019enregistre comme \u00ab\u00a0ajout\u00e9e par l\u2019utilisateur\u00a0\u00bb.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/orders"}]}},"\/wc-analytics\/orders\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"parent_id":{"description":"ID de commande parente.","type":"integer","required":false},"created_via":{"description":"Affiche o\u00f9 la commande a \u00e9t\u00e9 cr\u00e9\u00e9e.","type":"string","required":false},"status":{"description":"\u00c9tat de la commande.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Devise avec laquelle la commande a \u00e9t\u00e9 cr\u00e9\u00e9e, au format ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID utilisateur propri\u00e9taire de la commande. 0 pour les invit\u00e9s.","type":"integer","required":false},"customer_note":{"description":"Note laiss\u00e9e par le client lors de la commande.","type":"string","required":false},"billing":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID du moyen de paiement.","type":"string","required":false},"payment_method_title":{"description":"Titre du moyen de paiement.","type":"string","required":false},"transaction_id":{"description":"ID unique de transaction.","type":"string","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Ligne de donn\u00e9es des articles.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom du produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nom du produit parent si le produit est une variation.","type":"string","context":["view","edit"]},"product_id":{"description":"ID produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variation, si applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantit\u00e9 command\u00e9.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Classe de taxe de produit.","type":"string","context":["view","edit"]},"subtotal":{"description":"Ligne de sous-total (avant remises).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Ligne de sous-total de taxe (avant remises).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"]},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"]},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Cl\u00e9 m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]},"display_value":{"description":"Valeur de m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]}}}},"sku":{"description":"UGS du produit.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tarif du produit.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propri\u00e9t\u00e9s de l\u2019image principale du produit.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de l\u2019instance d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Ligne de donn\u00e9es des codes promo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Code promo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Remise totale.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Taxe totale de la remise.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Type de remise.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Montant de la remise telle que d\u00e9finie dans le code promo (valeur absolue ou pourcentage, en fonction du type de remise).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si le code promo donne droit \u00e0 la livraison gratuite ou non.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"D\u00e9termine si la commande est pay\u00e9e. Cela va d\u00e9finir l\u2019\u00e9tat \u00e0 en cours et r\u00e9duire de stock des articles.","type":"boolean","required":false},"manual_update":{"description":"D\u00e9finir l\u2019action sur manuel pour que la note de commande s\u2019enregistre comme \u00ab\u00a0ajout\u00e9e par l\u2019utilisateur\u00a0\u00bb.","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc-analytics\/orders\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"ID de commande parente.","type":"integer","required":false},"created_via":{"description":"Affiche o\u00f9 la commande a \u00e9t\u00e9 cr\u00e9\u00e9e.","type":"string","required":false},"status":{"description":"\u00c9tat de la commande.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Devise avec laquelle la commande a \u00e9t\u00e9 cr\u00e9\u00e9e, au format ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID utilisateur propri\u00e9taire de la commande. 0 pour les invit\u00e9s.","type":"integer","required":false},"customer_note":{"description":"Note laiss\u00e9e par le client lors de la commande.","type":"string","required":false},"billing":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID du moyen de paiement.","type":"string","required":false},"payment_method_title":{"description":"Titre du moyen de paiement.","type":"string","required":false},"transaction_id":{"description":"ID unique de transaction.","type":"string","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Ligne de donn\u00e9es des articles.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom du produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nom du produit parent si le produit est une variation.","type":"string","context":["view","edit"]},"product_id":{"description":"ID produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variation, si applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantit\u00e9 command\u00e9.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Classe de taxe de produit.","type":"string","context":["view","edit"]},"subtotal":{"description":"Ligne de sous-total (avant remises).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Ligne de sous-total de taxe (avant remises).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"]},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"]},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Cl\u00e9 m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]},"display_value":{"description":"Valeur de m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]}}}},"sku":{"description":"UGS du produit.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tarif du produit.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propri\u00e9t\u00e9s de l\u2019image principale du produit.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de l\u2019instance d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Ligne de donn\u00e9es des codes promo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Code promo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Remise totale.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Taxe totale de la remise.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Type de remise.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Montant de la remise telle que d\u00e9finie dans le code promo (valeur absolue ou pourcentage, en fonction du type de remise).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si le code promo donne droit \u00e0 la livraison gratuite ou non.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"D\u00e9termine si la commande est pay\u00e9e. Cela va d\u00e9finir l\u2019\u00e9tat \u00e0 en cours et r\u00e9duire de stock des articles.","type":"boolean","required":false},"manual_update":{"description":"D\u00e9finir l\u2019action sur manuel pour que la note de commande s\u2019enregistre comme \u00ab\u00a0ajout\u00e9e par l\u2019utilisateur\u00a0\u00bb.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/orders\/batch"}]}},"\/wc-analytics\/products":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rechercher par nom de produit ou UGS similaire.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order","price","popularity","rating"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de marque sp\u00e9cifique.","type":"string","required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un identifiant sp\u00e9cifique.","type":"string","required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un type sp\u00e9cifique.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"featured":{"description":"Limiter le jeu de r\u00e9sultats aux produits mis en avant.","type":"boolean","required":false},"category":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de cat\u00e9gorie sp\u00e9cifique.","type":"string","required":false},"tag":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID d\u2019\u00e9tiquette sp\u00e9cifique.","type":"string","required":false},"shipping_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de classe d\u2019exp\u00e9dition sp\u00e9cifique.","type":"string","required":false},"attribute":{"description":"Limiter les r\u00e9sultats aux produits avec un attribut sp\u00e9cifique. Utiliser le nom de la taxonomie \/ le slug de l\u2019attribut.","type":"string","required":false},"attribute_term":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un ID de terme d&rsquo;attribut sp\u00e9cifique (attribut affect\u00e9 requis).","type":"string","required":false},"tax_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec une classe de taxe sp\u00e9cifique.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif minimum.","type":"string","required":false},"max_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif maximum.","type":"string","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec l\u2019\u00e9tat du stock sp\u00e9cifi\u00e9.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"search_sku":{"description":"Limiter les r\u00e9sultats \u00e0 ceux avec une UGS qui correspond partiellement \u00e0 une cha\u00eene. Cet argument pr\u00e9vaut sur \u00ab\u00a0sku\u00a0\u00bb.","type":"string","required":false},"search_name_or_sku":{"description":"Limiter les r\u00e9sultats \u00e0 ceux avec un nom ou une UGS qui correspond partiellement \u00e0 une cha\u00eene. Cet argument pr\u00e9vaut sur \u00ab\u00a0search\u00a0\u00bb, \u00ab\u00a0sku\u00a0\u00bb et \u00ab\u00a0search_sku\u00a0\u00bb.","type":"string","required":false},"search_fields":{"description":"Limiter la recherche \u00e0 des champs sp\u00e9cifiques si utilis\u00e9 avec le param\u00e8tre de recherche. Champs disponibles\u00a0: UGS, global_unique_id, description, short_description. Cet argument prend pr\u00e9vaut sur les autres param\u00e8tres de recherche.","type":"array","items":{"type":"string","enum":["name","global_unique_id","description","short_description","sku"]},"default":[],"required":false},"include_status":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec n\u2019importe quel \u00e9tat.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Excluez les produits avec n\u2019importe quel \u00e9tat du jeu de r\u00e9sultats.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"include_types":{"description":"Limitez le jeu de r\u00e9sultats aux produits de n\u2019importe quel type.","type":"array","items":{"type":"string","enum":["simple","grouped","external","variable"]},"required":false},"exclude_types":{"description":"Excluez les produits de n\u2019importe quel type du jeu de r\u00e9sultats.","type":"array","items":{"type":"string","enum":["simple","grouped","external","variable"]},"required":false},"downloadable":{"description":"Limitez le jeu de r\u00e9sultats aux produits t\u00e9l\u00e9chargeables.","type":"boolean","required":false},"virtual":{"description":"Limitez le jeu de r\u00e9sultats aux produits virtuels.","type":"boolean","required":false},"pos_products_only":{"description":"Limiter les r\u00e9sultats aux produits visibles sur le point de vente.","type":"boolean","required":false},"low_in_stock":{"description":"Limiter les r\u00e9sultats aux produits qui ont un stock faible ou en rupture. (D\u00e9pr\u00e9ci\u00e9)","type":"boolean","default":false,"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"date_created":{"description":"La date \u00e0 laquelle le produit a \u00e9t\u00e9 cr\u00e9\u00e9, en fuseau horaire du site.","type":["null","string"],"required":false},"date_created_gmt":{"description":"Date de cr\u00e9ation du produit, format GMT.","type":["null","string"],"required":false},"type":{"default":"simple","description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"default":"publish","description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"default":false,"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"virtual":{"default":false,"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"default":"taxable","description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour le produit.","type":["integer","null"],"required":false},"sold_individually":{"default":false,"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Autoriser les avis.","type":"boolean","required":false},"post_password":{"description":"Mot de passe de l\u2019article","type":"string","required":false},"upsell_ids":{"description":"Liste des IDs des produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Liste des marques.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la marque.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la marque.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de la marque.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/products"}]}},"\/wc-analytics\/products\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"date_created":{"description":"La date \u00e0 laquelle le produit a \u00e9t\u00e9 cr\u00e9\u00e9, en fuseau horaire du site.","type":["null","string"],"required":false},"date_created_gmt":{"description":"Date de cr\u00e9ation du produit, format GMT.","type":["null","string"],"required":false},"type":{"description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"virtual":{"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour le produit.","type":["integer","null"],"required":false},"sold_individually":{"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"description":"Autoriser les avis.","type":"boolean","required":false},"post_password":{"description":"Mot de passe de l\u2019article","type":"string","required":false},"upsell_ids":{"description":"Liste des IDs des produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Liste des marques.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la marque.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la marque.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de la marque.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","type":"boolean","required":false}}}]},"\/wc-analytics\/products\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"date_created":{"description":"La date \u00e0 laquelle le produit a \u00e9t\u00e9 cr\u00e9\u00e9, en fuseau horaire du site.","type":["null","string"],"required":false},"date_created_gmt":{"description":"Date de cr\u00e9ation du produit, format GMT.","type":["null","string"],"required":false},"type":{"description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"virtual":{"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour le produit.","type":["integer","null"],"required":false},"sold_individually":{"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"description":"Autoriser les avis.","type":"boolean","required":false},"post_password":{"description":"Mot de passe de l\u2019article","type":"string","required":false},"upsell_ids":{"description":"Liste des IDs des produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Liste des marques.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la marque.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la marque.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de la marque.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/products\/batch"}]}},"\/wc-analytics\/products\/(?P<id>[\\d]+)\/related":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false}}}]},"\/wc-analytics\/products\/suggested-products":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de marque sp\u00e9cifique.","type":"string","required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un identifiant sp\u00e9cifique.","type":"string","required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un type sp\u00e9cifique.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"featured":{"description":"Limiter le jeu de r\u00e9sultats aux produits mis en avant.","type":"boolean","required":false},"category":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de cat\u00e9gorie sp\u00e9cifique.","type":"string","required":false},"tag":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID d\u2019\u00e9tiquette sp\u00e9cifique.","type":"string","required":false},"shipping_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de classe d\u2019exp\u00e9dition sp\u00e9cifique.","type":"string","required":false},"attribute":{"description":"Limiter les r\u00e9sultats aux produits avec un attribut sp\u00e9cifique. Utiliser le nom de la taxonomie \/ le slug de l\u2019attribut.","type":"string","required":false},"attribute_term":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un ID de terme d&rsquo;attribut sp\u00e9cifique (attribut affect\u00e9 requis).","type":"string","required":false},"tax_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec une classe de taxe sp\u00e9cifique.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"in_stock":{"description":"Limiter le jeu de r\u00e9sultats aux produits en stock ou en rupture de stock.","type":"boolean","required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif minimum.","type":"string","required":false},"max_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif maximum.","type":"string","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 des ID sp\u00e9cifiques de cat\u00e9gorie de produits.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 des ID sp\u00e9cifiques d\u2019\u00e9tiquette produit.","type":"array","items":{"type":"integer"},"default":[],"required":false},"limit":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 une quantit\u00e9 sp\u00e9cifique de produits sugg\u00e9r\u00e9s.","type":"integer","default":5,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/products\/suggested-products"}]}},"\/wc-analytics\/products\/(?P<id>[\\d]+)\/duplicate":{"namespace":"wc-analytics","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"date_created":{"description":"La date \u00e0 laquelle le produit a \u00e9t\u00e9 cr\u00e9\u00e9, en fuseau horaire du site.","type":["null","string"],"required":false},"date_created_gmt":{"description":"Date de cr\u00e9ation du produit, format GMT.","type":["null","string"],"required":false},"type":{"description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"virtual":{"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour le produit.","type":["integer","null"],"required":false},"sold_individually":{"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"description":"Autoriser les avis.","type":"boolean","required":false},"post_password":{"description":"Mot de passe de l\u2019article","type":"string","required":false},"upsell_ids":{"description":"Liste des IDs des produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Liste des marques.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la marque.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la marque.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de la marque.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc-analytics\/products\/attributes":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"search":{"description":"Recherchez par nom d\u2019attribut similaire.","type":"string","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nom pour la ressource.","type":"string","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"type":{"default":"select","description":"Type d&rsquo;attribut.","type":"string","enum":["select"],"required":false},"order_by":{"default":"menu_order","description":"Tri par d\u00e9faut.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Activer\/d\u00e9sactiver les archives d&rsquo;attribut.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/products\/attributes"}]}},"\/wc-analytics\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de l\u2019attribut.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"type":{"description":"Type d&rsquo;attribut.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Tri par d\u00e9faut.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activer\/d\u00e9sactiver les archives d&rsquo;attribut.","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc-analytics\/products\/attributes\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom de l\u2019attribut.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"type":{"description":"Type d&rsquo;attribut.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Tri par d\u00e9faut.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activer\/d\u00e9sactiver les archives d&rsquo;attribut.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/products\/attributes\/batch"}]}},"\/wc-analytics\/products\/attributes\/(?P<slug>[a-z0-9_\\-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Identifiant unique pour la ressource.","type":"string","required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"name":{"description":"Nom du terme.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"name":{"description":"Nom du terme.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<slug>[a-z0-9_\\-]+)\/terms":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false}}}]},"\/wc-analytics\/products\/categories":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"default":"default","description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/products\/categories"}]}},"\/wc-analytics\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc-analytics\/products\/categories\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/products\/categories\/batch"}]}},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rechercher par nom de produit, UGS ou valeur d\u2019attribut similaire.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un identifiant sp\u00e9cifique.","type":"string","required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"tax_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec une classe de taxe sp\u00e9cifique.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif minimum.","type":"string","required":false},"max_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif maximum.","type":"string","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec l\u2019\u00e9tat du stock sp\u00e9cifi\u00e9.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limitez les r\u00e9sultats aux produits avec ou sans prix.","type":"boolean","required":false},"attributes":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec des attributs sp\u00e9cifiques.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Identifiant de l&rsquo;attribut."},"term":{"type":"string","description":"Terme d\u2019attribut."},"terms":{"type":"array","description":"Termes d\u2019attribut."}}},"required":false},"virtual":{"description":"Limitez le jeu de r\u00e9sultats aux variantes de produits virtuels.","type":"boolean","required":false},"downloadable":{"description":"Limitez le jeu de r\u00e9sultats aux variantes de produits t\u00e9l\u00e9chargeables.","type":"boolean","required":false},"include_status":{"description":"Limitez le jeu de r\u00e9sultats aux variantes de produit avec n\u2019importe quel \u00e9tat.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Excluez les variantes de produit avec n\u2019importe quel \u00e9tat du jeu de r\u00e9sultats.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limiter les r\u00e9sultats aux variantes visibles sur le point de vente.","type":"boolean","required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"type":{"default":"variation","description":"Type de produit.","type":"string","enum":["variation"],"required":false},"description":{"description":"Description de la variation.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","required":false},"sale_price":{"description":"Tarif promo de la variation.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"status":{"default":"publish","description":"\u00c9tat de la variation.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"Si la variation est virtuelle.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gestion des stocks au niveau des variations.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour la variation.","type":["integer","null"],"required":false},"weight":{"description":"Poids de la variation (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions de la variation.","type":"object","properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"name":{"description":"Nom du parent du produit.","type":"string","required":false}}}]},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la variation.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la variation.","type":"integer","required":false},"type":{"description":"Type de produit.","type":"string","enum":["variation"],"required":false},"description":{"description":"Description de la variation.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","required":false},"sale_price":{"description":"Tarif promo de la variation.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"status":{"description":"\u00c9tat de la variation.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"Si la variation est virtuelle.","type":"boolean","required":false},"downloadable":{"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion des stocks au niveau des variations.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour la variation.","type":["integer","null"],"required":false},"weight":{"description":"Poids de la variation (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions de la variation.","type":"object","properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"name":{"description":"Nom du parent du produit.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la variation.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"type":{"description":"Type de produit.","type":"string","enum":["variation"],"required":false},"description":{"description":"Description de la variation.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","required":false},"sale_price":{"description":"Tarif promo de la variation.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"status":{"description":"\u00c9tat de la variation.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"Si la variation est virtuelle.","type":"boolean","required":false},"downloadable":{"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion des stocks au niveau des variations.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour la variation.","type":["integer","null"],"required":false},"weight":{"description":"Poids de la variation (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions de la variation.","type":"object","properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"name":{"description":"Nom du parent du produit.","type":"string","required":false}}}]},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations\/generate":{"namespace":"wc-analytics","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"delete":{"description":"Supprime les variations non utilis\u00e9es.","type":"boolean","required":false},"default_values":{"description":"Valeurs par d\u00e9faut pour les variations g\u00e9n\u00e9r\u00e9es.","type":"object","properties":{"type":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Type de produit.","type":"string","enum":["variation"]},"description":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Description de la variation.","type":"string"},"sku":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Unit\u00e9 de Gestion de Stock.","type":"string"},"global_unique_id":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"GTIN, UPC, EAN ou ISBN.","type":"string"},"regular_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Tarif r\u00e9gulier de la variation.","type":"string"},"sale_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Tarif promo de la variation.","type":"string"},"date_on_sale_from":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"]},"date_on_sale_from_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"]},"date_on_sale_to":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"]},"date_on_sale_to_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"]},"status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"\u00c9tat de la variation.","type":"string","enum":["draft","pending","private","publish"]},"virtual":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Si la variation est virtuelle.","type":"boolean"},"downloadable":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean"},"downloads":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}}},"download_limit":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer"},"download_expiry":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer"},"tax_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"]},"tax_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Classe de taxe.","type":"string"},"manage_stock":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Gestion des stocks au niveau des variations.","type":["boolean","string"]},"stock_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Quantit\u00e9 en stock.","type":"integer"},"stock_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"]},"backorders":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"]},"low_stock_amount":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Faible quantit\u00e9 de stock pour la variation.","type":["integer","null"]},"weight":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Poids de la variation (kg).","type":"string"},"dimensions":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Dimensions de la variation.","type":"object","properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}}},"shipping_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string"},"image":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Donn\u00e9es d\u2019image de variation.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}}},"attributes":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}}},"menu_order":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer"},"meta_data":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}},"parent_id":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"ID du parent du produit.","type":"integer"},"name":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Nom du parent du produit.","type":"string"}},"required":false},"type":{"default":"variation","description":"Type de produit.","type":"string","enum":["variation"],"required":false},"description":{"description":"Description de la variation.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","required":false},"sale_price":{"description":"Tarif promo de la variation.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"status":{"default":"publish","description":"\u00c9tat de la variation.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"Si la variation est virtuelle.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gestion des stocks au niveau des variations.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour la variation.","type":["integer","null"],"required":false},"weight":{"description":"Poids de la variation (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions de la variation.","type":"object","properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"name":{"description":"Nom du parent du produit.","type":"string","required":false}}}]},"\/wc-analytics\/variations":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rechercher par nom de produit, UGS ou valeur d\u2019attribut similaire.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un identifiant sp\u00e9cifique.","type":"string","required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"tax_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec une classe de taxe sp\u00e9cifique.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif minimum.","type":"string","required":false},"max_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif maximum.","type":"string","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec l\u2019\u00e9tat du stock sp\u00e9cifi\u00e9.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limitez les r\u00e9sultats aux produits avec ou sans prix.","type":"boolean","required":false},"attributes":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec des attributs sp\u00e9cifiques.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Identifiant de l&rsquo;attribut."},"term":{"type":"string","description":"Terme d\u2019attribut."},"terms":{"type":"array","description":"Termes d\u2019attribut."}}},"required":false},"virtual":{"description":"Limitez le jeu de r\u00e9sultats aux variantes de produits virtuels.","type":"boolean","required":false},"downloadable":{"description":"Limitez le jeu de r\u00e9sultats aux variantes de produits t\u00e9l\u00e9chargeables.","type":"boolean","required":false},"include_status":{"description":"Limitez le jeu de r\u00e9sultats aux variantes de produit avec n\u2019importe quel \u00e9tat.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Excluez les variantes de produit avec n\u2019importe quel \u00e9tat du jeu de r\u00e9sultats.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limiter les r\u00e9sultats aux variantes visibles sur le point de vente.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/variations"}]}},"\/wc-analytics\/products\/reviews":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitez les r\u00e9ponses aux avis publi\u00e9s avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","product"],"required":false},"reviewer":{"description":"Limite le jeu de r\u00e9sultats aux avis assign\u00e9s \u00e0 des ID d\u2019utilisateurs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"reviewer_exclude":{"description":"V\u00e9rifiez que le jeu de r\u00e9sultats exclut les avis assign\u00e9s \u00e0 des ID d\u2019utilisateurs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"reviewer_email":{"default":null,"description":"Limiter le jeu de r\u00e9sultats \u00e0 une adresse e-mail d\u2019auteur sp\u00e9cifique.","format":"email","type":"string","required":false},"product":{"default":[],"description":"Limite le jeu de r\u00e9sultats aux avis assign\u00e9s \u00e0 des ID de produits sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approved","description":"Limiter le jeu de r\u00e9sultats aux avis affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["all","hold","approved","spam","trash"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"ID unique pour le produit.","type":"integer","required":true},"product_name":{"description":"Nom du produit.","type":"string","required":false},"status":{"default":"approved","description":"\u00c9tat de l\u2019avis.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"type":"string","description":"Nom de l&rsquo;\u00e9valuateur.","required":true},"reviewer_email":{"type":"string","description":"E-mail de l&rsquo;\u00e9valuateur.","required":true},"review":{"type":"string","description":"Contenu de l\u2019avis.","required":true},"rating":{"description":"Note de l\u2019avis (0 \u00e0 5).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/products\/reviews"}]}},"\/wc-analytics\/products\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"product_id":{"description":"ID unique du produit auquel l\u2019avis se r\u00e9f\u00e8re.","type":"integer","required":false},"product_name":{"description":"Nom du produit.","type":"string","required":false},"status":{"description":"\u00c9tat de l\u2019avis.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Nom de l&rsquo;\u00e9valuateur.","type":"string","required":false},"reviewer_email":{"description":"Email de l&rsquo;\u00e9valuateur.","type":"string","format":"email","required":false},"review":{"description":"Le contenu de l&rsquo;avis.","type":"string","required":false},"rating":{"description":"Note de l\u2019avis (0 \u00e0 5).","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc-analytics\/products\/reviews\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"ID unique du produit auquel l\u2019avis se r\u00e9f\u00e8re.","type":"integer","required":false},"product_name":{"description":"Nom du produit.","type":"string","required":false},"status":{"description":"\u00c9tat de l\u2019avis.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Nom de l&rsquo;\u00e9valuateur.","type":"string","required":false},"reviewer_email":{"description":"Email de l&rsquo;\u00e9valuateur.","type":"string","format":"email","required":false},"review":{"description":"Le contenu de l&rsquo;avis.","type":"string","required":false},"rating":{"description":"Note de l\u2019avis (0 \u00e0 5).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/products\/reviews\/batch"}]}},"\/wc-analytics\/products\/low-in-stock":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["draft","pending","private","publish","future"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/products\/low-in-stock"}]}},"\/wc-analytics\/products\/count-low-in-stock":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["draft","pending","private","publish","future"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/products\/count-low-in-stock"}]}},"\/wc-analytics\/settings\/(?P<group_id>[\\w-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"ID de groupe de r\u00e9glages.","type":"string","required":false}}}]},"\/wc-analytics\/settings\/(?P<group_id>[\\w-]+)\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"ID de groupe de r\u00e9glages.","type":"string","required":false},"value":{"description":"Valeur de r\u00e9glage.","type":["null","object","string","number","boolean","integer","array"],"required":false}}}]},"\/wc-analytics\/settings\/(?P<group_id>[\\w-]+)\/(?P<id>[\\w-]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"ID de groupe de r\u00e9glages.","type":"string","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"ID de groupe de r\u00e9glages.","type":"string","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false},"value":{"description":"Valeur de r\u00e9glage.","type":["null","object","string","number","boolean","integer","array"],"required":false}}}]},"\/wc-analytics\/taxes":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"default":"asc","description":"Attribut de tri de commande croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"Trier la collection par attribut d\u2019objet.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"Trier par classe de taxe.","enum":["standard","taux-reduit","taux-zero"],"type":"string","required":false},"search":{"description":"Rechercher par code de taxe similaire.","type":"string","required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux articles poss\u00e9dant le ou les ID de taxe sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false}}},{"methods":["POST"],"args":{"country":{"description":"Code pays ISO 3166.","type":"string","required":false},"state":{"description":"Code r\u00e9gion.","type":"string","required":false},"postcode":{"description":"Code postal \/ ZIP, il ne permet pas plusieurs valeurs. D\u00e9pr\u00e9ci\u00e9 depuis WooCommerce 5.3, \u00ab\u00a0code postaux\u00a0\u00bb devrait \u00eatre utilis\u00e9 \u00e0 la place.","type":"string","required":false},"city":{"description":"Nom de la ville, il ne permet pas plusieurs valeurs. D\u00e9pr\u00e9ci\u00e9 depuis WooCommerce 5.3, \u00ab\u00a0villes\u00a0\u00bb devrait \u00eatre utilis\u00e9 \u00e0 la place.","type":"string","required":false},"rate":{"description":"Taux de taxe.","type":"string","required":false},"name":{"description":"Nom du taux de taxe.","type":"string","required":false},"priority":{"default":1,"description":"Priorit\u00e9 de la taxe.","type":"integer","required":false},"compound":{"default":false,"description":"S\u2019il s\u2019agit ou non d\u2019un taux compos\u00e9.","type":"boolean","required":false},"shipping":{"default":true,"description":"Si ce taux de taxe s\u2019applique ou non \u00e0 l\u2019exp\u00e9dition.","type":"boolean","required":false},"order":{"description":"Indique l&rsquo;ordre dans lequel cela appara\u00eetra dans les requ\u00eates.","type":"integer","required":false},"class":{"default":"standard","description":"Classe de taxe.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"postcodes":{"description":"Liste des codes postaux \/ ZIP. Ajout\u00e9e avec WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Liste des noms de villes. Introduit par WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/taxes"}]}},"\/wc-analytics\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"country":{"description":"Code pays ISO 3166.","type":"string","required":false},"state":{"description":"Code r\u00e9gion.","type":"string","required":false},"postcode":{"description":"Code postal \/ ZIP, il ne permet pas plusieurs valeurs. D\u00e9pr\u00e9ci\u00e9 depuis WooCommerce 5.3, \u00ab\u00a0code postaux\u00a0\u00bb devrait \u00eatre utilis\u00e9 \u00e0 la place.","type":"string","required":false},"city":{"description":"Nom de la ville, il ne permet pas plusieurs valeurs. D\u00e9pr\u00e9ci\u00e9 depuis WooCommerce 5.3, \u00ab\u00a0villes\u00a0\u00bb devrait \u00eatre utilis\u00e9 \u00e0 la place.","type":"string","required":false},"rate":{"description":"Taux de taxe.","type":"string","required":false},"name":{"description":"Nom du taux de taxe.","type":"string","required":false},"priority":{"description":"Priorit\u00e9 de la taxe.","type":"integer","required":false},"compound":{"description":"S\u2019il s\u2019agit ou non d\u2019un taux compos\u00e9.","type":"boolean","required":false},"shipping":{"description":"Si ce taux de taxe s\u2019applique ou non \u00e0 l\u2019exp\u00e9dition.","type":"boolean","required":false},"order":{"description":"Indique l&rsquo;ordre dans lequel cela appara\u00eetra dans les requ\u00eates.","type":"integer","required":false},"class":{"description":"Classe de taxe.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"postcodes":{"description":"Liste des codes postaux \/ ZIP. Ajout\u00e9e avec WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Liste des noms de villes. Introduit par WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc-analytics\/taxes\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"Code pays ISO 3166.","type":"string","required":false},"state":{"description":"Code r\u00e9gion.","type":"string","required":false},"postcode":{"description":"Code postal \/ ZIP, il ne permet pas plusieurs valeurs. D\u00e9pr\u00e9ci\u00e9 depuis WooCommerce 5.3, \u00ab\u00a0code postaux\u00a0\u00bb devrait \u00eatre utilis\u00e9 \u00e0 la place.","type":"string","required":false},"city":{"description":"Nom de la ville, il ne permet pas plusieurs valeurs. D\u00e9pr\u00e9ci\u00e9 depuis WooCommerce 5.3, \u00ab\u00a0villes\u00a0\u00bb devrait \u00eatre utilis\u00e9 \u00e0 la place.","type":"string","required":false},"rate":{"description":"Taux de taxe.","type":"string","required":false},"name":{"description":"Nom du taux de taxe.","type":"string","required":false},"priority":{"description":"Priorit\u00e9 de la taxe.","type":"integer","required":false},"compound":{"description":"S\u2019il s\u2019agit ou non d\u2019un taux compos\u00e9.","type":"boolean","required":false},"shipping":{"description":"Si ce taux de taxe s\u2019applique ou non \u00e0 l\u2019exp\u00e9dition.","type":"boolean","required":false},"order":{"description":"Indique l&rsquo;ordre dans lequel cela appara\u00eetra dans les requ\u00eates.","type":"integer","required":false},"class":{"description":"Classe de taxe.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"postcodes":{"description":"Liste des codes postaux \/ ZIP. Ajout\u00e9e avec WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Liste des noms de villes. Introduit par WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-analytics\/taxes\/batch"}]}},"\/wc-admin\/launch-your-store\/initialize-coming-soon":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/launch-your-store\/initialize-coming-soon"}]}},"\/wc-admin\/launch-your-store\/update-survey-status":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"status":{"type":"string","enum":["yes","no"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/launch-your-store\/update-survey-status"}]}},"\/wc-admin\/launch-your-store\/survey-completed":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/launch-your-store\/survey-completed"}]}},"\/wc-admin\/launch-your-store\/woopayments\/test-orders\/count":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/launch-your-store\/woopayments\/test-orders\/count"}]}},"\/wc-admin\/launch-your-store\/woopayments\/test-orders":{"namespace":"wc-admin","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/launch-your-store\/woopayments\/test-orders"}]}},"\/wc\/store":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/store","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store"}]}},"\/wc\/store\/batch":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/batch"}]}},"\/wc\/store\/cart":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/cart"}]}},"\/wc\/store\/cart\/add-item":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID du produit ou de la variation plac\u00e9 dans le panier.","type":"integer","required":false},"quantity":{"description":"Quantit\u00e9 de cet article \u00e0 ajouter au panier.","type":"number","required":false},"variation":{"description":"Attributs s\u00e9lectionn\u00e9s (pour les variations).","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Nom de l\u2019attribut de la variation.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de l\u2019attribut de la variation.","type":"string","context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/cart\/add-item"}]}},"\/wc\/store\/cart\/apply-coupon":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identifiant unique du code promo dans le panier.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/cart\/apply-coupon"}]}},"\/wc\/store\/cart\/coupons":{"namespace":"wc\/store","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Le code unique du code promo.","type":"string","required":false},"discount_type":{"description":"Type de remise du code promo (pourcentage ou montant fixe, par exemple)","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/cart\/coupons"}]}},"\/wc\/store\/cart\/coupons\/(?P<code>[\\w-]+)":{"namespace":"wc\/store","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identifiant unique du code promo dans le panier.","type":"string","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identifiant unique du code promo dans le panier.","type":"string","required":false}}}]},"\/wc\/store\/cart\/extensions":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"namespace":{"description":"Nom de l\u2019extension\u00a0: il sera utilis\u00e9 pour garantir que les donn\u00e9es de la requ\u00eate sont correctement achemin\u00e9es.","type":"string","required":false},"data":{"description":"Donn\u00e9es suppl\u00e9mentaires \u00e0 passer \u00e0 l\u2019extension","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/cart\/extensions"}]}},"\/wc\/store\/cart\/items":{"namespace":"wc\/store","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"extensions":{"type":"object","properties":[],"default":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/cart\/items"}]}},"\/wc\/store\/cart\/items\/(?P<key>[\\w-]{32})":{"namespace":"wc\/store","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identifiant unique de l\u2019article plac\u00e9 dans le panier.","type":"string","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identifiant unique de l\u2019article plac\u00e9 dans le panier.","type":"string","required":false},"extensions":{"type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identifiant unique de l\u2019article plac\u00e9 dans le panier.","type":"string","required":false}}}]},"\/wc\/store\/cart\/remove-coupon":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identifiant unique du code promo dans le panier.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/cart\/remove-coupon"}]}},"\/wc\/store\/cart\/remove-item":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identifiant (cl\u00e9) unique de l\u2019article de panier.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/cart\/remove-item"}]}},"\/wc\/store\/cart\/select-shipping-rate":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"package_id":{"description":"ID du colis en cours de livraison. Laisser vide pour l\u2019appliquer \u00e0 tous les colis.","type":["integer","string","null"],"required":false},"rate_id":{"description":"L\u2019ID de frais choisi pour le colis.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/cart\/select-shipping-rate"}]}},"\/wc\/store\/cart\/update-item":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identifiant (cl\u00e9) unique de l\u2019article de panier \u00e0 mettre \u00e0 jour.","type":"string","required":false},"quantity":{"description":"Nouvelle quantit\u00e9 de l\u2019article dans le panier.","type":"number","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/cart\/update-item"}]}},"\/wc\/store\/cart\/update-customer":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"billing_address":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"E-mail","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/cart\/update-customer"}]}},"\/wc\/store\/checkout":{"namespace":"wc\/store","methods":["GET","POST","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Donn\u00e9es \u00e0 transmettre au moyen de paiement lors du traitement du paiement.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_password":{"description":"Mot de passe client pour les nouveaux comptes, le cas \u00e9ch\u00e9ant.","type":"string","required":false},"customer_note":{"description":"Note ajout\u00e9e \u00e0 la commande par le client lors de la validation de commande.","type":"string","required":false},"billing_address":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"E-mail","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"L\u2019ID du moyen de paiement utilis\u00e9 pour traiter le paiement.","type":"string","enum":["","bacs","cheque","cod","atos2"],"required":false},"create_account":{"description":"Cr\u00e9er ou non un compte utilisateur dans le processus de commande.","type":"boolean","required":false},"additional_fields":{"description":"Champs suppl\u00e9mentaires \u00e0 conserver dans la commande.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Donn\u00e9es d\u2019extensions enregistr\u00e9es par woocommerce\/order-attribution.","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Champ d\u2019attribution de commande\u00a0: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Champ d\u2019attribution de commande\u00a0: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Champ d\u2019attribution de commande\u00a0: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Champ d\u2019attribution de commande\u00a0: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Champ d\u2019attribution de commande\u00a0: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Champ d\u2019attribution de commande\u00a0: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Champ d\u2019attribution de commande\u00a0: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Champ d\u2019attribution de commande\u00a0: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Champ d\u2019attribution de commande\u00a0: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Champ d\u2019attribution de commande\u00a0: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Champ d\u2019attribution de commande\u00a0: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Champ d\u2019attribution de commande\u00a0: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Champ d\u2019attribution de commande\u00a0: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Champ d\u2019attribution de commande\u00a0: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Champ d\u2019attribution de commande\u00a0: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Champ d\u2019attribution de commande\u00a0: user_agent","type":["string","null"],"context":[]}}}},"default":{"woocommerce\/order-attribution":[]},"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"additional_fields":{"description":"Champs suppl\u00e9mentaires \u00e0 conserver dans la commande.","type":"object","properties":[],"required":false},"payment_method":{"description":"L\u2019ID du moyen de paiement utilis\u00e9 pour traiter le paiement.","type":"string","enum":["","bacs","cheque","cod","atos2"],"required":false},"order_notes":{"description":"Notes de commande.","type":"string","required":false},"customer_note":{"description":"Note ajout\u00e9e \u00e0 la commande par le client lors de la validation de commande.","type":"string","required":false},"billing_address":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"E-mail","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true}},"required":false},"create_account":{"description":"Cr\u00e9er ou non un compte utilisateur dans le processus de commande.","type":"boolean","required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Donn\u00e9es d\u2019extensions enregistr\u00e9es par woocommerce\/order-attribution.","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Champ d\u2019attribution de commande\u00a0: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Champ d\u2019attribution de commande\u00a0: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Champ d\u2019attribution de commande\u00a0: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Champ d\u2019attribution de commande\u00a0: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Champ d\u2019attribution de commande\u00a0: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Champ d\u2019attribution de commande\u00a0: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Champ d\u2019attribution de commande\u00a0: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Champ d\u2019attribution de commande\u00a0: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Champ d\u2019attribution de commande\u00a0: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Champ d\u2019attribution de commande\u00a0: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Champ d\u2019attribution de commande\u00a0: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Champ d\u2019attribution de commande\u00a0: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Champ d\u2019attribution de commande\u00a0: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Champ d\u2019attribution de commande\u00a0: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Champ d\u2019attribution de commande\u00a0: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Champ d\u2019attribution de commande\u00a0: user_agent","type":["string","null"],"context":[]}}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/checkout"}]}},"\/wc\/store\/checkout\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Donn\u00e9es \u00e0 transmettre au moyen de paiement lors du traitement du paiement.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_note":{"description":"Note ajout\u00e9e \u00e0 la commande par le client lors de la validation de commande.","type":"string","required":false},"billing_address":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"E-mail","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"L\u2019ID du moyen de paiement utilis\u00e9 pour traiter le paiement.","type":"string","enum":["","bacs","cheque","cod","atos2"],"required":false},"additional_fields":{"description":"Champs suppl\u00e9mentaires \u00e0 conserver dans la commande.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Donn\u00e9es d\u2019extensions enregistr\u00e9es par woocommerce\/order-attribution.","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Champ d\u2019attribution de commande\u00a0: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Champ d\u2019attribution de commande\u00a0: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Champ d\u2019attribution de commande\u00a0: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Champ d\u2019attribution de commande\u00a0: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Champ d\u2019attribution de commande\u00a0: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Champ d\u2019attribution de commande\u00a0: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Champ d\u2019attribution de commande\u00a0: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Champ d\u2019attribution de commande\u00a0: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Champ d\u2019attribution de commande\u00a0: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Champ d\u2019attribution de commande\u00a0: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Champ d\u2019attribution de commande\u00a0: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Champ d\u2019attribution de commande\u00a0: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Champ d\u2019attribution de commande\u00a0: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Champ d\u2019attribution de commande\u00a0: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Champ d\u2019attribution de commande\u00a0: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Champ d\u2019attribution de commande\u00a0: user_agent","type":["string","null"],"context":[]}}}},"default":{"woocommerce\/order-attribution":[]},"required":false}}}]},"\/wc\/store\/order\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/products\/attributes":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/products\/attributes"}]}},"\/wc\/store\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut.","type":"integer","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximum d\u2019articles \u00e0 retourner dans les r\u00e9sultats. Est d\u00e9fini par d\u00e9faut sur aucune limite si laiss\u00e9 vide.","type":"integer","minimum":0,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Triez dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Triez par propri\u00e9t\u00e9 de terme.","type":"string","default":"name","enum":["name","slug","count","menu_order","name_num","id"],"required":false},"hide_empty":{"description":"Si vrai, les termes vides ne seront pas retourn\u00e9s.","type":"boolean","default":true,"required":false},"parent":{"description":"Limiter les r\u00e9sultats aux termes ayant un parent sp\u00e9cifique (taxonomies hi\u00e9rarchiques uniquement).","type":"integer","required":false}}}]},"\/wc\/store\/products\/categories":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximum d\u2019articles \u00e0 retourner dans les r\u00e9sultats. Est d\u00e9fini par d\u00e9faut sur aucune limite si laiss\u00e9 vide.","type":"integer","minimum":0,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Triez dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Triez par propri\u00e9t\u00e9 de terme.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Si vrai, les termes vides ne seront pas retourn\u00e9s.","type":"boolean","default":true,"required":false},"parent":{"description":"Limiter les r\u00e9sultats aux termes ayant un parent sp\u00e9cifique (taxonomies hi\u00e9rarchiques uniquement).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/products\/categories"}]}},"\/wc\/store\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wc\/store\/products\/brands":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximum d\u2019articles \u00e0 retourner dans les r\u00e9sultats. Est d\u00e9fini par d\u00e9faut sur aucune limite si laiss\u00e9 vide.","type":"integer","minimum":0,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Triez dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Triez par propri\u00e9t\u00e9 de terme.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Si vrai, les termes vides ne seront pas retourn\u00e9s.","type":"boolean","default":true,"required":false},"parent":{"description":"Limiter les r\u00e9sultats aux termes ayant un parent sp\u00e9cifique (taxonomies hi\u00e9rarchiques uniquement).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/products\/brands"}]}},"\/wc\/store\/products\/brands\/(?P<identifier>[\\w-]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"identifier":{"description":"Identifiant unique pour la ressource.","type":"string","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wc\/store\/products\/collection-data":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"slug":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec un ou des slugs sp\u00e9cifiques. Utilisez des virgules pour s\u00e9parer.","type":"string","required":false},"after":{"description":"Limitez les r\u00e9ponses aux avis publi\u00e9s apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitez les r\u00e9ponses aux ressources cr\u00e9\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"date_column":{"description":"Lorsque la r\u00e9ponse est restreinte suivant la valeur avant\/apr\u00e8s, indiquez la colonne de date de comparaison.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un type sp\u00e9cifique.","type":"string","enum":["simple","grouped","external","variable","variation"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"featured":{"description":"Limiter le jeu de r\u00e9sultats aux produits mis en avant.","type":"boolean","required":false},"category":{"description":"Limitez le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ensemble d\u2019ID ou de slugs de cat\u00e9gories, s\u00e9par\u00e9s par des virgules.","type":"string","required":false},"category_operator":{"description":"Op\u00e9rateur pour comparer les termes de cat\u00e9gorie de produits.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Limitez le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ensemble d\u2019ID ou de slugs de marques, s\u00e9par\u00e9s par des virgules.","type":"string","required":false},"brand_operator":{"description":"Op\u00e9rateur pour comparer les termes de marque de produits.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Limitez le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ensemble d\u2019ID ou de slugs d\u2019\u00e9tiquettes, s\u00e9par\u00e9s par des virgules.","type":"string","required":false},"tag_operator":{"description":"Op\u00e9rateur pour comparer les \u00e9tiquettes produit.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limitez les r\u00e9sultats aux produits en fonction d\u2019un prix minimum, fourni en utilisant la plus petite unit\u00e9 de la devise.","type":"string","required":false},"max_price":{"description":"Limitez les r\u00e9sultats aux produits en fonction d\u2019un prix maximum, fourni en utilisant la plus petite unit\u00e9 de la devise.","type":"string","required":false},"stock_status":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec l\u2019\u00e9tat du stock sp\u00e9cifi\u00e9.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec des attributs mondiaux s\u00e9lectionn\u00e9s.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Nom de la taxonomie de l\u2019attribut.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"Liste des ID des termes des attributs.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"Liste du ou des identifiants. Si l\u2019ID d\u2019un terme est fourni, il sera ignor\u00e9.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Op\u00e9rateur pour comparer les termes d\u2019attributs de produits.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"Relation logique entre les attributs lors d\u2019un filtrage unique de plusieurs sources.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"D\u00e9termine si les produits masqu\u00e9s ou visibles dans le catalogue sont affich\u00e9s.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Limiter les r\u00e9sultats aux produits ayant une certaine note moyenne.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false},"calculate_price_range":{"description":"Si vrai, calcule le prix minimum et maximum des produits de la collection.","type":"boolean","default":false,"required":false},"calculate_stock_status_counts":{"description":"Si la valeur est vraie, calcule le stock des produits de la collection.","type":"boolean","default":false,"required":false},"calculate_attribute_counts":{"description":"Si demand\u00e9, calcule le nombre de termes d\u2019attribut des produits figurant dans la collection.","type":"array","items":{"type":"object","properties":{"taxonomy":{"description":"Nom de la taxonomie.","type":"string","context":["view","edit"],"readonly":true},"query_type":{"description":"Condition de filtre\t ex\u00e9cut\u00e9e pouvant affecter les r\u00e9sultats. Les valeurs valides incluent \u00ab\u00a0et\u00a0\u00bb et \u00ab\u00a0ou\u00a0\u00bb.","type":"string","enum":["and","or"],"context":["view","edit"],"readonly":true}}},"default":[],"required":false},"calculate_rating_counts":{"description":"Si vrai, calculez la note des produits figurant dans la collection.","type":"boolean","default":false,"required":false},"calculate_taxonomy_counts":{"description":"Si requis, calcule le nombre de termes de la taxonomie des produits figurant dans la collection.","type":"array","items":{"type":"string","description":"Nom de la taxonomie."},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/products\/collection-data"}]}},"\/wc\/store\/products\/reviews":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","date_gmt","id","rating","product"],"required":false},"category_id":{"description":"Limitez les r\u00e9sultats aux avis \u00e0 partir d\u2019ID de cat\u00e9gorie sp\u00e9cifiques.","type":"string","required":false},"product_id":{"description":"Limitez les r\u00e9sultats aux avis \u00e0 partir d\u2019ID de produit sp\u00e9cifiques.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/products\/reviews"}]}},"\/wc\/store\/products\/tags":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximum d\u2019articles \u00e0 retourner dans les r\u00e9sultats. Est d\u00e9fini par d\u00e9faut sur aucune limite si laiss\u00e9 vide.","type":"integer","minimum":0,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Triez dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Triez par propri\u00e9t\u00e9 de terme.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Si vrai, les termes vides ne seront pas retourn\u00e9s.","type":"boolean","default":true,"required":false},"parent":{"description":"Limiter les r\u00e9sultats aux termes ayant un parent sp\u00e9cifique (taxonomies hi\u00e9rarchiques uniquement).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/products\/tags"}]}},"\/wc\/store\/products":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"slug":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec un ou des slugs sp\u00e9cifiques. Utilisez des virgules pour s\u00e9parer.","type":"string","required":false},"after":{"description":"Limitez les r\u00e9ponses aux avis publi\u00e9s apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitez les r\u00e9ponses aux ressources cr\u00e9\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"date_column":{"description":"Lorsque la r\u00e9ponse est restreinte suivant la valeur avant\/apr\u00e8s, indiquez la colonne de date de comparaison.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un type sp\u00e9cifique.","type":"string","enum":["simple","grouped","external","variable","variation"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"featured":{"description":"Limiter le jeu de r\u00e9sultats aux produits mis en avant.","type":"boolean","required":false},"category":{"description":"Limitez le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ensemble d\u2019ID ou de slugs de cat\u00e9gories, s\u00e9par\u00e9s par des virgules.","type":"string","required":false},"category_operator":{"description":"Op\u00e9rateur pour comparer les termes de cat\u00e9gorie de produits.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Limitez le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ensemble d\u2019ID ou de slugs de marques, s\u00e9par\u00e9s par des virgules.","type":"string","required":false},"brand_operator":{"description":"Op\u00e9rateur pour comparer les termes de marque de produits.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Limitez le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ensemble d\u2019ID ou de slugs d\u2019\u00e9tiquettes, s\u00e9par\u00e9s par des virgules.","type":"string","required":false},"tag_operator":{"description":"Op\u00e9rateur pour comparer les \u00e9tiquettes produit.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limitez les r\u00e9sultats aux produits en fonction d\u2019un prix minimum, fourni en utilisant la plus petite unit\u00e9 de la devise.","type":"string","required":false},"max_price":{"description":"Limitez les r\u00e9sultats aux produits en fonction d\u2019un prix maximum, fourni en utilisant la plus petite unit\u00e9 de la devise.","type":"string","required":false},"stock_status":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec l\u2019\u00e9tat du stock sp\u00e9cifi\u00e9.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec des attributs mondiaux s\u00e9lectionn\u00e9s.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Nom de la taxonomie de l\u2019attribut.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"Liste des ID des termes des attributs.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"Liste du ou des identifiants. Si l\u2019ID d\u2019un terme est fourni, il sera ignor\u00e9.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Op\u00e9rateur pour comparer les termes d\u2019attributs de produits.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"Relation logique entre les attributs lors d\u2019un filtrage unique de plusieurs sources.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"D\u00e9termine si les produits masqu\u00e9s ou visibles dans le catalogue sont affich\u00e9s.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Limiter les r\u00e9sultats aux produits ayant une certaine note moyenne.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/products"}]}},"\/wc\/store\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/products\/(?P<slug>[\\S]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Slug de la ressource.","type":"string","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/v1":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/store\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1"}]}},"\/wc\/store\/v1\/batch":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/batch"}]}},"\/wc\/store\/v1\/cart":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/cart"}]}},"\/wc\/store\/v1\/cart\/add-item":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID du produit ou de la variation plac\u00e9 dans le panier.","type":"integer","required":false},"quantity":{"description":"Quantit\u00e9 de cet article \u00e0 ajouter au panier.","type":"number","required":false},"variation":{"description":"Attributs s\u00e9lectionn\u00e9s (pour les variations).","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Nom de l\u2019attribut de la variation.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de l\u2019attribut de la variation.","type":"string","context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/cart\/add-item"}]}},"\/wc\/store\/v1\/cart\/apply-coupon":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identifiant unique du code promo dans le panier.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/cart\/apply-coupon"}]}},"\/wc\/store\/v1\/cart\/coupons":{"namespace":"wc\/store\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Le code unique du code promo.","type":"string","required":false},"discount_type":{"description":"Type de remise du code promo (pourcentage ou montant fixe, par exemple)","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/cart\/coupons"}]}},"\/wc\/store\/v1\/cart\/coupons\/(?P<code>[\\w-]+)":{"namespace":"wc\/store\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identifiant unique du code promo dans le panier.","type":"string","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identifiant unique du code promo dans le panier.","type":"string","required":false}}}]},"\/wc\/store\/v1\/cart\/extensions":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"namespace":{"description":"Nom de l\u2019extension\u00a0: il sera utilis\u00e9 pour garantir que les donn\u00e9es de la requ\u00eate sont correctement achemin\u00e9es.","type":"string","required":false},"data":{"description":"Donn\u00e9es suppl\u00e9mentaires \u00e0 passer \u00e0 l\u2019extension","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/cart\/extensions"}]}},"\/wc\/store\/v1\/cart\/items":{"namespace":"wc\/store\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"extensions":{"type":"object","properties":[],"default":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/cart\/items"}]}},"\/wc\/store\/v1\/cart\/items\/(?P<key>[\\w-]{32})":{"namespace":"wc\/store\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identifiant unique de l\u2019article plac\u00e9 dans le panier.","type":"string","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identifiant unique de l\u2019article plac\u00e9 dans le panier.","type":"string","required":false},"extensions":{"type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identifiant unique de l\u2019article plac\u00e9 dans le panier.","type":"string","required":false}}}]},"\/wc\/store\/v1\/cart\/remove-coupon":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identifiant unique du code promo dans le panier.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/cart\/remove-coupon"}]}},"\/wc\/store\/v1\/cart\/remove-item":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identifiant (cl\u00e9) unique de l\u2019article de panier.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/cart\/remove-item"}]}},"\/wc\/store\/v1\/cart\/select-shipping-rate":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"package_id":{"description":"ID du colis en cours de livraison. Laisser vide pour l\u2019appliquer \u00e0 tous les colis.","type":["integer","string","null"],"required":false},"rate_id":{"description":"L\u2019ID de frais choisi pour le colis.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/cart\/select-shipping-rate"}]}},"\/wc\/store\/v1\/cart\/update-item":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identifiant (cl\u00e9) unique de l\u2019article de panier \u00e0 mettre \u00e0 jour.","type":"string","required":false},"quantity":{"description":"Nouvelle quantit\u00e9 de l\u2019article dans le panier.","type":"number","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/cart\/update-item"}]}},"\/wc\/store\/v1\/cart\/update-customer":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"billing_address":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"E-mail","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/cart\/update-customer"}]}},"\/wc\/store\/v1\/checkout":{"namespace":"wc\/store\/v1","methods":["GET","POST","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Donn\u00e9es \u00e0 transmettre au moyen de paiement lors du traitement du paiement.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_password":{"description":"Mot de passe client pour les nouveaux comptes, le cas \u00e9ch\u00e9ant.","type":"string","required":false},"customer_note":{"description":"Note ajout\u00e9e \u00e0 la commande par le client lors de la validation de commande.","type":"string","required":false},"billing_address":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"E-mail","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"L\u2019ID du moyen de paiement utilis\u00e9 pour traiter le paiement.","type":"string","enum":["","bacs","cheque","cod","atos2"],"required":false},"create_account":{"description":"Cr\u00e9er ou non un compte utilisateur dans le processus de commande.","type":"boolean","required":false},"additional_fields":{"description":"Champs suppl\u00e9mentaires \u00e0 conserver dans la commande.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Donn\u00e9es d\u2019extensions enregistr\u00e9es par woocommerce\/order-attribution.","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Champ d\u2019attribution de commande\u00a0: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Champ d\u2019attribution de commande\u00a0: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Champ d\u2019attribution de commande\u00a0: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Champ d\u2019attribution de commande\u00a0: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Champ d\u2019attribution de commande\u00a0: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Champ d\u2019attribution de commande\u00a0: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Champ d\u2019attribution de commande\u00a0: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Champ d\u2019attribution de commande\u00a0: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Champ d\u2019attribution de commande\u00a0: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Champ d\u2019attribution de commande\u00a0: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Champ d\u2019attribution de commande\u00a0: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Champ d\u2019attribution de commande\u00a0: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Champ d\u2019attribution de commande\u00a0: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Champ d\u2019attribution de commande\u00a0: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Champ d\u2019attribution de commande\u00a0: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Champ d\u2019attribution de commande\u00a0: user_agent","type":["string","null"],"context":[]}}}},"default":{"woocommerce\/order-attribution":[]},"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"additional_fields":{"description":"Champs suppl\u00e9mentaires \u00e0 conserver dans la commande.","type":"object","properties":[],"required":false},"payment_method":{"description":"L\u2019ID du moyen de paiement utilis\u00e9 pour traiter le paiement.","type":"string","enum":["","bacs","cheque","cod","atos2"],"required":false},"order_notes":{"description":"Notes de commande.","type":"string","required":false},"customer_note":{"description":"Note ajout\u00e9e \u00e0 la commande par le client lors de la validation de commande.","type":"string","required":false},"billing_address":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"E-mail","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true}},"required":false},"create_account":{"description":"Cr\u00e9er ou non un compte utilisateur dans le processus de commande.","type":"boolean","required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Donn\u00e9es d\u2019extensions enregistr\u00e9es par woocommerce\/order-attribution.","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Champ d\u2019attribution de commande\u00a0: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Champ d\u2019attribution de commande\u00a0: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Champ d\u2019attribution de commande\u00a0: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Champ d\u2019attribution de commande\u00a0: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Champ d\u2019attribution de commande\u00a0: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Champ d\u2019attribution de commande\u00a0: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Champ d\u2019attribution de commande\u00a0: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Champ d\u2019attribution de commande\u00a0: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Champ d\u2019attribution de commande\u00a0: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Champ d\u2019attribution de commande\u00a0: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Champ d\u2019attribution de commande\u00a0: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Champ d\u2019attribution de commande\u00a0: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Champ d\u2019attribution de commande\u00a0: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Champ d\u2019attribution de commande\u00a0: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Champ d\u2019attribution de commande\u00a0: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Champ d\u2019attribution de commande\u00a0: user_agent","type":["string","null"],"context":[]}}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/checkout"}]}},"\/wc\/store\/v1\/checkout\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Donn\u00e9es \u00e0 transmettre au moyen de paiement lors du traitement du paiement.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_note":{"description":"Note ajout\u00e9e \u00e0 la commande par le client lors de la validation de commande.","type":"string","required":false},"billing_address":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"E-mail","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Nom","type":"string","context":["view","edit"],"required":true},"company":{"description":"Entreprise","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Adresse","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Appartement, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ville","type":"string","context":["view","edit"],"required":true},"state":{"description":"Code d\u2019\u00e9tat\/comt\u00e9, ou nom de l\u2019\u00e9tat, du comt\u00e9, de la province ou du district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Code postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"Code de pays\/r\u00e9gion au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"T\u00e9l\u00e9phone","type":"string","context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"L\u2019ID du moyen de paiement utilis\u00e9 pour traiter le paiement.","type":"string","enum":["","bacs","cheque","cod","atos2"],"required":false},"additional_fields":{"description":"Champs suppl\u00e9mentaires \u00e0 conserver dans la commande.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Donn\u00e9es d\u2019extensions enregistr\u00e9es par woocommerce\/order-attribution.","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Champ d\u2019attribution de commande\u00a0: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Champ d\u2019attribution de commande\u00a0: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Champ d\u2019attribution de commande\u00a0: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Champ d\u2019attribution de commande\u00a0: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Champ d\u2019attribution de commande\u00a0: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Champ d\u2019attribution de commande\u00a0: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Champ d\u2019attribution de commande\u00a0: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Champ d\u2019attribution de commande\u00a0: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Champ d\u2019attribution de commande\u00a0: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Champ d\u2019attribution de commande\u00a0: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Champ d\u2019attribution de commande\u00a0: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Champ d\u2019attribution de commande\u00a0: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Champ d\u2019attribution de commande\u00a0: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Champ d\u2019attribution de commande\u00a0: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Champ d\u2019attribution de commande\u00a0: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Champ d\u2019attribution de commande\u00a0: user_agent","type":["string","null"],"context":[]}}}},"default":{"woocommerce\/order-attribution":[]},"required":false}}}]},"\/wc\/store\/v1\/order\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/v1\/products\/attributes":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/products\/attributes"}]}},"\/wc\/store\/v1\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut.","type":"integer","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximum d\u2019articles \u00e0 retourner dans les r\u00e9sultats. Est d\u00e9fini par d\u00e9faut sur aucune limite si laiss\u00e9 vide.","type":"integer","minimum":0,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Triez dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Triez par propri\u00e9t\u00e9 de terme.","type":"string","default":"name","enum":["name","slug","count","menu_order","name_num","id"],"required":false},"hide_empty":{"description":"Si vrai, les termes vides ne seront pas retourn\u00e9s.","type":"boolean","default":true,"required":false},"parent":{"description":"Limiter les r\u00e9sultats aux termes ayant un parent sp\u00e9cifique (taxonomies hi\u00e9rarchiques uniquement).","type":"integer","required":false}}}]},"\/wc\/store\/v1\/products\/categories":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximum d\u2019articles \u00e0 retourner dans les r\u00e9sultats. Est d\u00e9fini par d\u00e9faut sur aucune limite si laiss\u00e9 vide.","type":"integer","minimum":0,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Triez dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Triez par propri\u00e9t\u00e9 de terme.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Si vrai, les termes vides ne seront pas retourn\u00e9s.","type":"boolean","default":true,"required":false},"parent":{"description":"Limiter les r\u00e9sultats aux termes ayant un parent sp\u00e9cifique (taxonomies hi\u00e9rarchiques uniquement).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/products\/categories"}]}},"\/wc\/store\/v1\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wc\/store\/v1\/products\/brands":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximum d\u2019articles \u00e0 retourner dans les r\u00e9sultats. Est d\u00e9fini par d\u00e9faut sur aucune limite si laiss\u00e9 vide.","type":"integer","minimum":0,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Triez dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Triez par propri\u00e9t\u00e9 de terme.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Si vrai, les termes vides ne seront pas retourn\u00e9s.","type":"boolean","default":true,"required":false},"parent":{"description":"Limiter les r\u00e9sultats aux termes ayant un parent sp\u00e9cifique (taxonomies hi\u00e9rarchiques uniquement).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/products\/brands"}]}},"\/wc\/store\/v1\/products\/brands\/(?P<identifier>[\\w-]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"identifier":{"description":"Identifiant unique pour la ressource.","type":"string","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wc\/store\/v1\/products\/collection-data":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"slug":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec un ou des slugs sp\u00e9cifiques. Utilisez des virgules pour s\u00e9parer.","type":"string","required":false},"after":{"description":"Limitez les r\u00e9ponses aux avis publi\u00e9s apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitez les r\u00e9ponses aux ressources cr\u00e9\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"date_column":{"description":"Lorsque la r\u00e9ponse est restreinte suivant la valeur avant\/apr\u00e8s, indiquez la colonne de date de comparaison.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un type sp\u00e9cifique.","type":"string","enum":["simple","grouped","external","variable","variation"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"featured":{"description":"Limiter le jeu de r\u00e9sultats aux produits mis en avant.","type":"boolean","required":false},"category":{"description":"Limitez le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ensemble d\u2019ID ou de slugs de cat\u00e9gories, s\u00e9par\u00e9s par des virgules.","type":"string","required":false},"category_operator":{"description":"Op\u00e9rateur pour comparer les termes de cat\u00e9gorie de produits.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Limitez le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ensemble d\u2019ID ou de slugs de marques, s\u00e9par\u00e9s par des virgules.","type":"string","required":false},"brand_operator":{"description":"Op\u00e9rateur pour comparer les termes de marque de produits.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Limitez le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ensemble d\u2019ID ou de slugs d\u2019\u00e9tiquettes, s\u00e9par\u00e9s par des virgules.","type":"string","required":false},"tag_operator":{"description":"Op\u00e9rateur pour comparer les \u00e9tiquettes produit.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limitez les r\u00e9sultats aux produits en fonction d\u2019un prix minimum, fourni en utilisant la plus petite unit\u00e9 de la devise.","type":"string","required":false},"max_price":{"description":"Limitez les r\u00e9sultats aux produits en fonction d\u2019un prix maximum, fourni en utilisant la plus petite unit\u00e9 de la devise.","type":"string","required":false},"stock_status":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec l\u2019\u00e9tat du stock sp\u00e9cifi\u00e9.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec des attributs mondiaux s\u00e9lectionn\u00e9s.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Nom de la taxonomie de l\u2019attribut.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"Liste des ID des termes des attributs.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"Liste du ou des identifiants. Si l\u2019ID d\u2019un terme est fourni, il sera ignor\u00e9.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Op\u00e9rateur pour comparer les termes d\u2019attributs de produits.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"Relation logique entre les attributs lors d\u2019un filtrage unique de plusieurs sources.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"D\u00e9termine si les produits masqu\u00e9s ou visibles dans le catalogue sont affich\u00e9s.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Limiter les r\u00e9sultats aux produits ayant une certaine note moyenne.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false},"calculate_price_range":{"description":"Si vrai, calcule le prix minimum et maximum des produits de la collection.","type":"boolean","default":false,"required":false},"calculate_stock_status_counts":{"description":"Si la valeur est vraie, calcule le stock des produits de la collection.","type":"boolean","default":false,"required":false},"calculate_attribute_counts":{"description":"Si demand\u00e9, calcule le nombre de termes d\u2019attribut des produits figurant dans la collection.","type":"array","items":{"type":"object","properties":{"taxonomy":{"description":"Nom de la taxonomie.","type":"string","context":["view","edit"],"readonly":true},"query_type":{"description":"Condition de filtre\t ex\u00e9cut\u00e9e pouvant affecter les r\u00e9sultats. Les valeurs valides incluent \u00ab\u00a0et\u00a0\u00bb et \u00ab\u00a0ou\u00a0\u00bb.","type":"string","enum":["and","or"],"context":["view","edit"],"readonly":true}}},"default":[],"required":false},"calculate_rating_counts":{"description":"Si vrai, calculez la note des produits figurant dans la collection.","type":"boolean","default":false,"required":false},"calculate_taxonomy_counts":{"description":"Si requis, calcule le nombre de termes de la taxonomie des produits figurant dans la collection.","type":"array","items":{"type":"string","description":"Nom de la taxonomie."},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/products\/collection-data"}]}},"\/wc\/store\/v1\/products\/reviews":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","date_gmt","id","rating","product"],"required":false},"category_id":{"description":"Limitez les r\u00e9sultats aux avis \u00e0 partir d\u2019ID de cat\u00e9gorie sp\u00e9cifiques.","type":"string","required":false},"product_id":{"description":"Limitez les r\u00e9sultats aux avis \u00e0 partir d\u2019ID de produit sp\u00e9cifiques.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/products\/reviews"}]}},"\/wc\/store\/v1\/products\/tags":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximum d\u2019articles \u00e0 retourner dans les r\u00e9sultats. Est d\u00e9fini par d\u00e9faut sur aucune limite si laiss\u00e9 vide.","type":"integer","minimum":0,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Triez dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Triez par propri\u00e9t\u00e9 de terme.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Si vrai, les termes vides ne seront pas retourn\u00e9s.","type":"boolean","default":true,"required":false},"parent":{"description":"Limiter les r\u00e9sultats aux termes ayant un parent sp\u00e9cifique (taxonomies hi\u00e9rarchiques uniquement).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/products\/tags"}]}},"\/wc\/store\/v1\/products":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"slug":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec un ou des slugs sp\u00e9cifiques. Utilisez des virgules pour s\u00e9parer.","type":"string","required":false},"after":{"description":"Limitez les r\u00e9ponses aux avis publi\u00e9s apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitez les r\u00e9ponses aux ressources cr\u00e9\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"date_column":{"description":"Lorsque la r\u00e9ponse est restreinte suivant la valeur avant\/apr\u00e8s, indiquez la colonne de date de comparaison.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un type sp\u00e9cifique.","type":"string","enum":["simple","grouped","external","variable","variation"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"featured":{"description":"Limiter le jeu de r\u00e9sultats aux produits mis en avant.","type":"boolean","required":false},"category":{"description":"Limitez le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ensemble d\u2019ID ou de slugs de cat\u00e9gories, s\u00e9par\u00e9s par des virgules.","type":"string","required":false},"category_operator":{"description":"Op\u00e9rateur pour comparer les termes de cat\u00e9gorie de produits.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Limitez le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ensemble d\u2019ID ou de slugs de marques, s\u00e9par\u00e9s par des virgules.","type":"string","required":false},"brand_operator":{"description":"Op\u00e9rateur pour comparer les termes de marque de produits.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Limitez le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ensemble d\u2019ID ou de slugs d\u2019\u00e9tiquettes, s\u00e9par\u00e9s par des virgules.","type":"string","required":false},"tag_operator":{"description":"Op\u00e9rateur pour comparer les \u00e9tiquettes produit.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limitez les r\u00e9sultats aux produits en fonction d\u2019un prix minimum, fourni en utilisant la plus petite unit\u00e9 de la devise.","type":"string","required":false},"max_price":{"description":"Limitez les r\u00e9sultats aux produits en fonction d\u2019un prix maximum, fourni en utilisant la plus petite unit\u00e9 de la devise.","type":"string","required":false},"stock_status":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec l\u2019\u00e9tat du stock sp\u00e9cifi\u00e9.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec des attributs mondiaux s\u00e9lectionn\u00e9s.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Nom de la taxonomie de l\u2019attribut.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"Liste des ID des termes des attributs.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"Liste du ou des identifiants. Si l\u2019ID d\u2019un terme est fourni, il sera ignor\u00e9.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Op\u00e9rateur pour comparer les termes d\u2019attributs de produits.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"Relation logique entre les attributs lors d\u2019un filtrage unique de plusieurs sources.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"D\u00e9termine si les produits masqu\u00e9s ou visibles dans le catalogue sont affich\u00e9s.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Limiter les r\u00e9sultats aux produits ayant une certaine note moyenne.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/store\/v1\/products"}]}},"\/wc\/store\/v1\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/v1\/products\/(?P<slug>[\\S]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Slug de la ressource.","type":"string","required":false},"context":{"description":"Port\u00e9e de la requ\u00eate; d\u00e9termine les champs pr\u00e9sents dans la r\u00e9ponse.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/private":{"namespace":"wc\/private","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/private","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/private"}]}},"\/wc\/private\/patterns":{"namespace":"wc\/private","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/private\/patterns"}]}},"\/wc\/v2":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2"}]}},"\/wc\/v2\/products\/brands":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"default":"default","description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/products\/brands"}]}},"\/wc\/v2\/products\/brands\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v2\/products\/brands\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/products\/brands\/batch"}]}},"\/wc\/v3\/products\/brands":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"default":"default","description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/brands"}]}},"\/wc\/v3\/products\/brands\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v3\/products\/brands\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/brands\/batch"}]}},"\/aios\/v1\/onboarding":{"namespace":"aios\/v1\/onboarding","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"aios\/v1\/onboarding","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/aios\/v1\/onboarding"}]}},"\/aios\/v1\/onboarding\/tfa_key_is_valid":{"namespace":"aios\/v1\/onboarding","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/aios\/v1\/onboarding\/tfa_key_is_valid"}]}},"\/wc\/v1\/coupons":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"Utiliser les arguments de WP Query pour modifier la r\u00e9ponse; les variables de requ\u00eate priv\u00e9e requiert une autorisation appropri\u00e9e.","required":false},"code":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un code sp\u00e9cifique.","type":"string","required":false}}},{"methods":["POST"],"args":{"code":{"description":"Code promo.","type":"string","required":true},"description":{"description":"Description du code promo.","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"D\u00e9termine le type de remise qui sera appliqu\u00e9.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"amount":{"description":"Le montant de la remise. Doit toujours \u00eatre num\u00e9rique, m\u00eame si vous d\u00e9finissez un pourcentage.","type":"string","required":false},"expiry_date":{"description":"DateTime UTC de l&rsquo;expiration du code promo.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"Si vrai, le code promo ne peut \u00eatre utilis\u00e9 qu&rsquo;individuellement. Les autres codes promo appliqu\u00e9s seront retir\u00e9s du panier.","type":"boolean","required":false},"product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo peut \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"exclude_product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo ne peut pas \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Combien de fois le code promo peut \u00eatre utilis\u00e9.","type":"integer","required":false},"usage_limit_per_user":{"description":"Nombre de fois que le code promo peut \u00eatre utilis\u00e9 par client.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Nombre maximum d&rsquo;articles dans le panier auxquels le code promo peut \u00eatre appliqu\u00e9.","type":"integer","required":false},"free_shipping":{"default":false,"description":"Si vrai et que le mode d\u2019exp\u00e9dition gratuite n\u00e9cessite un code promo, ce code promo activera la livraison gratuite.","type":"boolean","required":false},"product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo s\u2019applique.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo ne s&rsquo;applique pas.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"Si vrai, ce code promo ne sera pas appliqu\u00e9 aux articles qui sont en promotion.","type":"boolean","required":false},"minimum_amount":{"description":"Montant minimum de commande qui doit \u00eatre dans le panier avant que le code promo ne s\u2019applique.","type":"string","required":false},"maximum_amount":{"description":"Montant maximum de commande autoris\u00e9 lors de l&rsquo;utilisation du code promo.","type":"string","required":false},"email_restrictions":{"description":"Liste des e-mails qui peuvent utiliser ce code promo.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/coupons"}]}},"\/wc\/v1\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"code":{"description":"Code promo.","type":"string","required":false},"description":{"description":"Description du code promo.","type":"string","required":false},"discount_type":{"description":"D\u00e9termine le type de remise qui sera appliqu\u00e9.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"amount":{"description":"Le montant de la remise. Doit toujours \u00eatre num\u00e9rique, m\u00eame si vous d\u00e9finissez un pourcentage.","type":"string","required":false},"expiry_date":{"description":"DateTime UTC de l&rsquo;expiration du code promo.","type":["null","string"],"required":false},"individual_use":{"description":"Si vrai, le code promo ne peut \u00eatre utilis\u00e9 qu&rsquo;individuellement. Les autres codes promo appliqu\u00e9s seront retir\u00e9s du panier.","type":"boolean","required":false},"product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo peut \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"exclude_product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo ne peut pas \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Combien de fois le code promo peut \u00eatre utilis\u00e9.","type":"integer","required":false},"usage_limit_per_user":{"description":"Nombre de fois que le code promo peut \u00eatre utilis\u00e9 par client.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Nombre maximum d&rsquo;articles dans le panier auxquels le code promo peut \u00eatre appliqu\u00e9.","type":"integer","required":false},"free_shipping":{"description":"Si vrai et que le mode d\u2019exp\u00e9dition gratuite n\u00e9cessite un code promo, ce code promo activera la livraison gratuite.","type":"boolean","required":false},"product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo s\u2019applique.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo ne s&rsquo;applique pas.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si vrai, ce code promo ne sera pas appliqu\u00e9 aux articles qui sont en promotion.","type":"boolean","required":false},"minimum_amount":{"description":"Montant minimum de commande qui doit \u00eatre dans le panier avant que le code promo ne s\u2019applique.","type":"string","required":false},"maximum_amount":{"description":"Montant maximum de commande autoris\u00e9 lors de l&rsquo;utilisation du code promo.","type":"string","required":false},"email_restrictions":{"description":"Liste des e-mails qui peuvent utiliser ce code promo.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v1\/coupons\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"Code promo.","type":"string","required":false},"description":{"description":"Description du code promo.","type":"string","required":false},"discount_type":{"description":"D\u00e9termine le type de remise qui sera appliqu\u00e9.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"amount":{"description":"Le montant de la remise. Doit toujours \u00eatre num\u00e9rique, m\u00eame si vous d\u00e9finissez un pourcentage.","type":"string","required":false},"expiry_date":{"description":"DateTime UTC de l&rsquo;expiration du code promo.","type":["null","string"],"required":false},"individual_use":{"description":"Si vrai, le code promo ne peut \u00eatre utilis\u00e9 qu&rsquo;individuellement. Les autres codes promo appliqu\u00e9s seront retir\u00e9s du panier.","type":"boolean","required":false},"product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo peut \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"exclude_product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo ne peut pas \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Combien de fois le code promo peut \u00eatre utilis\u00e9.","type":"integer","required":false},"usage_limit_per_user":{"description":"Nombre de fois que le code promo peut \u00eatre utilis\u00e9 par client.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Nombre maximum d&rsquo;articles dans le panier auxquels le code promo peut \u00eatre appliqu\u00e9.","type":"integer","required":false},"free_shipping":{"description":"Si vrai et que le mode d\u2019exp\u00e9dition gratuite n\u00e9cessite un code promo, ce code promo activera la livraison gratuite.","type":"boolean","required":false},"product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo s\u2019applique.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo ne s&rsquo;applique pas.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si vrai, ce code promo ne sera pas appliqu\u00e9 aux articles qui sont en promotion.","type":"boolean","required":false},"minimum_amount":{"description":"Montant minimum de commande qui doit \u00eatre dans le panier avant que le code promo ne s\u2019applique.","type":"string","required":false},"maximum_amount":{"description":"Montant maximum de commande autoris\u00e9 lors de l&rsquo;utilisation du code promo.","type":"string","required":false},"email_restrictions":{"description":"Liste des e-mails qui peuvent utiliser ce code promo.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/coupons\/batch"}]}},"\/wc\/v1\/customers\/(?P<customer_id>[\\d]+)\/downloads":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"customer_id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}]},"\/wc\/v1\/customers":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"default":"asc","description":"Attribut de tri de commande croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Trier la collection par attribut d\u2019objet.","enum":["id","include","name","registered_date"],"type":"string","required":false},"email":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un e-mail sp\u00e9cifique.","type":"string","format":"email","required":false},"role":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un r\u00f4le sp\u00e9cifique.","type":"string","default":"customer","enum":["all","administrator","editor","author","contributor","subscriber","customer","shop_manager","responsable_region","wpseo_manager","wpseo_editor"],"required":false}}},{"methods":["POST"],"args":{"email":{"type":"string","description":"Nouvelle adresse e-mail de l&rsquo;utilisateur.","required":true},"first_name":{"description":"Pr\u00e9nom du client.","type":"string","required":false},"last_name":{"description":"Nom du client.","type":"string","required":false},"username":{"description":"Nouvel identifiant.","type":"string","required":false},"password":{"description":"Nouveau mot de passe de l&rsquo;utilisateur.","type":"string","required":false},"billing":{"description":"Liste de donn\u00e9es de l&rsquo;adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2.","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Liste des donn\u00e9es d\u2019adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2.","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/customers"}]}},"\/wc\/v1\/customers\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"email":{"description":"L\u2019e-mail pour le client.","type":"string","format":"email","required":false},"first_name":{"description":"Pr\u00e9nom du client.","type":"string","required":false},"last_name":{"description":"Nom du client.","type":"string","required":false},"username":{"description":"Nom de connexion du client.","type":"string","required":false},"password":{"description":"Mot de passe client.","type":"string","required":false},"billing":{"description":"Liste de donn\u00e9es de l&rsquo;adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2.","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Liste des donn\u00e9es d\u2019adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2.","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false},"reassign":{"default":0,"type":"integer","description":"ID \u00e0 r\u00e9assigner aux articles.","required":false}}}]},"\/wc\/v1\/customers\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"email":{"description":"L\u2019e-mail pour le client.","type":"string","format":"email","required":false},"first_name":{"description":"Pr\u00e9nom du client.","type":"string","required":false},"last_name":{"description":"Nom du client.","type":"string","required":false},"username":{"description":"Nom de connexion du client.","type":"string","required":false},"password":{"description":"Mot de passe client.","type":"string","required":false},"billing":{"description":"Liste de donn\u00e9es de l&rsquo;adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2.","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Liste des donn\u00e9es d\u2019adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2.","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/customers\/batch"}]}},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/notes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"note":{"type":"string","description":"Contenu de la note de commande.","required":true},"customer_note":{"default":false,"description":"Indique\/d\u00e9fini si la note est seulement pour r\u00e9f\u00e9rence ou \u00e0 destination du client (l&rsquo;utilisateur sera notifi\u00e9).","type":"boolean","required":false}}}]},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/notes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/refunds":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"Utiliser les arguments de WP Query pour modifier la r\u00e9ponse; les variables de requ\u00eate priv\u00e9e requiert une autorisation appropri\u00e9e.","required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux commandes affect\u00e9es \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Limiter le jeu de r\u00e9sultats aux commandes affect\u00e9es \u00e0 un client sp\u00e9cifique.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux commandes affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","required":false},"dp":{"default":2,"description":"Nombre de d\u00e9cimales \u00e0 utiliser dans chaque ressource.","type":"integer","required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"amount":{"description":"Montant du remboursement.","type":"string","required":false},"reason":{"description":"Motif du remboursement.","type":"string","required":false}}}]},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/refunds\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v1\/orders":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"Utiliser les arguments de WP Query pour modifier la r\u00e9ponse; les variables de requ\u00eate priv\u00e9e requiert une autorisation appropri\u00e9e.","required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux commandes affect\u00e9es \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Limiter le jeu de r\u00e9sultats aux commandes affect\u00e9es \u00e0 un client sp\u00e9cifique.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux commandes affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","required":false},"dp":{"default":2,"description":"Nombre de d\u00e9cimales \u00e0 utiliser dans chaque ressource.","type":"integer","required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"ID de commande parente.","type":"integer","required":false},"status":{"default":"pending","description":"\u00c9tat de la commande.","type":"string","enum":["pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"EUR","description":"Devise avec laquelle la commande a \u00e9t\u00e9 cr\u00e9\u00e9e, au format ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"ID utilisateur propri\u00e9taire de la commande. 0 pour les invit\u00e9s.","type":"integer","required":false},"billing":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2.","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2.","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID du moyen de paiement.","type":"string","required":false},"payment_method_title":{"description":"Titre du moyen de paiement.","type":"string","required":false},"set_paid":{"default":false,"description":"D\u00e9termine si la commande est pay\u00e9e. Cela va d\u00e9finir l\u2019\u00e9tat \u00e0 en cours et r\u00e9duire de stock des articles.","type":"boolean","required":false},"transaction_id":{"description":"ID unique de transaction.","type":"string","required":false},"customer_note":{"description":"Note laiss\u00e9e par le client lors de la commande.","type":"string","required":false},"line_items":{"description":"Ligne de donn\u00e9es des articles.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom du produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true},"sku":{"description":"UGS du produit.","type":"string","context":["view","edit"],"readonly":true},"product_id":{"description":"ID produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variation, si applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantit\u00e9 command\u00e9.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Classe de taxe de produit.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tarif du produit.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Ligne de sous-total (avant remises).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Ligne de sous-total de taxe (avant remises).","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"]},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta":{"description":"Ligne de donn\u00e9es de m\u00e9ta de l&rsquo;article.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Libell\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"],"readonly":true},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"]},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"coupon_lines":{"description":"Ligne de donn\u00e9es des codes promo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Code promo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Remise totale.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Taxe totale de la remise.","type":"string","context":["view","edit"],"readonly":true}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/orders"}]}},"\/wc\/v1\/orders\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"parent_id":{"description":"ID de commande parente.","type":"integer","required":false},"status":{"description":"\u00c9tat de la commande.","type":"string","enum":["pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Devise avec laquelle la commande a \u00e9t\u00e9 cr\u00e9\u00e9e, au format ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID utilisateur propri\u00e9taire de la commande. 0 pour les invit\u00e9s.","type":"integer","required":false},"billing":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2.","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2.","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID du moyen de paiement.","type":"string","required":false},"payment_method_title":{"description":"Titre du moyen de paiement.","type":"string","required":false},"set_paid":{"description":"D\u00e9termine si la commande est pay\u00e9e. Cela va d\u00e9finir l\u2019\u00e9tat \u00e0 en cours et r\u00e9duire de stock des articles.","type":"boolean","required":false},"transaction_id":{"description":"ID unique de transaction.","type":"string","required":false},"customer_note":{"description":"Note laiss\u00e9e par le client lors de la commande.","type":"string","required":false},"line_items":{"description":"Ligne de donn\u00e9es des articles.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom du produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true},"sku":{"description":"UGS du produit.","type":"string","context":["view","edit"],"readonly":true},"product_id":{"description":"ID produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variation, si applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantit\u00e9 command\u00e9.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Classe de taxe de produit.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tarif du produit.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Ligne de sous-total (avant remises).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Ligne de sous-total de taxe (avant remises).","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"]},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta":{"description":"Ligne de donn\u00e9es de m\u00e9ta de l&rsquo;article.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Libell\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"],"readonly":true},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"]},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"coupon_lines":{"description":"Ligne de donn\u00e9es des codes promo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Code promo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Remise totale.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Taxe totale de la remise.","type":"string","context":["view","edit"],"readonly":true}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v1\/orders\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"ID de commande parente.","type":"integer","required":false},"status":{"description":"\u00c9tat de la commande.","type":"string","enum":["pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Devise avec laquelle la commande a \u00e9t\u00e9 cr\u00e9\u00e9e, au format ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID utilisateur propri\u00e9taire de la commande. 0 pour les invit\u00e9s.","type":"integer","required":false},"billing":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2.","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2.","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID du moyen de paiement.","type":"string","required":false},"payment_method_title":{"description":"Titre du moyen de paiement.","type":"string","required":false},"set_paid":{"description":"D\u00e9termine si la commande est pay\u00e9e. Cela va d\u00e9finir l\u2019\u00e9tat \u00e0 en cours et r\u00e9duire de stock des articles.","type":"boolean","required":false},"transaction_id":{"description":"ID unique de transaction.","type":"string","required":false},"customer_note":{"description":"Note laiss\u00e9e par le client lors de la commande.","type":"string","required":false},"line_items":{"description":"Ligne de donn\u00e9es des articles.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom du produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true},"sku":{"description":"UGS du produit.","type":"string","context":["view","edit"],"readonly":true},"product_id":{"description":"ID produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variation, si applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantit\u00e9 command\u00e9.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Classe de taxe de produit.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tarif du produit.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Ligne de sous-total (avant remises).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Ligne de sous-total de taxe (avant remises).","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"]},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta":{"description":"Ligne de donn\u00e9es de m\u00e9ta de l&rsquo;article.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Libell\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"],"readonly":true},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"]},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"coupon_lines":{"description":"Ligne de donn\u00e9es des codes promo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Code promo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Remise totale.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Taxe totale de la remise.","type":"string","context":["view","edit"],"readonly":true}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/orders\/batch"}]}},"\/wc\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}}]},"\/wc\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"name":{"description":"Nom du terme.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"name":{"description":"Nom du terme.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}}]},"\/wc\/v1\/products\/attributes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nom pour la ressource.","type":"string","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"type":{"default":"select","description":"Type d&rsquo;attribut.","type":"string","enum":["select"],"required":false},"order_by":{"default":"menu_order","description":"Tri par d\u00e9faut.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Activer\/d\u00e9sactiver les archives d&rsquo;attribut.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/products\/attributes"}]}},"\/wc\/v1\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de l\u2019attribut.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"type":{"description":"Type d&rsquo;attribut.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Tri par d\u00e9faut.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activer\/d\u00e9sactiver les archives d&rsquo;attribut.","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v1\/products\/attributes\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom de l\u2019attribut.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"type":{"description":"Type d&rsquo;attribut.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Tri par d\u00e9faut.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activer\/d\u00e9sactiver les archives d&rsquo;attribut.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/products\/attributes\/batch"}]}},"\/wc\/v1\/products\/categories":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"default":"default","description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/products\/categories"}]}},"\/wc\/v1\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v1\/products\/categories\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/products\/categories\/batch"}]}},"\/wc\/v1\/products\/(?P<product_id>[\\d]+)\/reviews":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la variation.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la variation.","type":"integer","required":false},"review":{"type":"string","description":"Contenu de l\u2019avis.","required":true},"date_created":{"description":"La date \u00e0 laquelle l&rsquo;avis a \u00e9t\u00e9 cr\u00e9\u00e9, en fuseau horaire du site.","type":["null","string"],"required":false},"rating":{"description":"Note de l\u2019avis (0 \u00e0 5).","type":"integer","required":false},"name":{"type":"string","description":"Nom de l&rsquo;\u00e9valuateur.","required":true},"email":{"type":"string","description":"E-mail de l&rsquo;\u00e9valuateur.","required":true}}}]},"\/wc\/v1\/products\/(?P<product_id>[\\d]+)\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"review":{"description":"Le contenu de l&rsquo;avis.","type":"string","required":false},"date_created":{"description":"La date \u00e0 laquelle l&rsquo;avis a \u00e9t\u00e9 cr\u00e9\u00e9, en fuseau horaire du site.","type":["null","string"],"required":false},"rating":{"description":"Note de l\u2019avis (0 \u00e0 5).","type":"integer","required":false},"name":{"description":"Nom de l&rsquo;\u00e9valuateur.","type":"string","required":false},"email":{"description":"Email de l&rsquo;\u00e9valuateur.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v1\/products\/shipping_classes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/products\/shipping_classes"}]}},"\/wc\/v1\/products\/shipping_classes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v1\/products\/shipping_classes\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/products\/shipping_classes\/batch"}]}},"\/wc\/v1\/products\/tags":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/products\/tags"}]}},"\/wc\/v1\/products\/tags\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v1\/products\/tags\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/products\/tags\/batch"}]}},"\/wc\/v1\/products":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"Utiliser les arguments de WP Query pour modifier la r\u00e9ponse; les variables de requ\u00eate priv\u00e9e requiert une autorisation appropri\u00e9e.","required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un identifiant sp\u00e9cifique.","type":"string","required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","future","draft","pending","private","publish"],"required":false},"type":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un type sp\u00e9cifique.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"category":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de cat\u00e9gorie sp\u00e9cifique.","type":"string","required":false},"tag":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID d\u2019\u00e9tiquette sp\u00e9cifique.","type":"string","required":false},"shipping_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de classe d\u2019exp\u00e9dition sp\u00e9cifique.","type":"string","required":false},"attribute":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un attribut sp\u00e9cifique.","type":"string","required":false},"attribute_term":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un ID de terme d&rsquo;attribut sp\u00e9cifique (attribut affect\u00e9 requis).","type":"string","required":false},"sku":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un UGS sp\u00e9cifique.","type":"string","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"type":{"default":"simple","description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"default":"publish","description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"default":false,"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Identifiant unique.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du tarif promo.","type":"string","required":false},"date_on_sale_to":{"description":"Date de fin du tarif de promotion.","type":"string","required":false},"virtual":{"default":false,"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"download_type":{"default":"standard","description":"Type de t\u00e9l\u00e9chargement, cela d\u00e9termine le sch\u00e9ma sur le site.","type":"string","enum":["standard"],"required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"default":"taxable","description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"in_stock":{"default":true,"description":"Contr\u00f4le si le produit est list\u00e9 comme &laquo;&nbsp;en stock&nbsp;&raquo; ou &laquo;&nbsp;en rupture&nbsp;&raquo; sur le site.","type":"boolean","required":false},"backorders":{"default":"no","description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"default":false,"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Autoriser les avis.","type":"boolean","required":false},"upsell_ids":{"description":"Liste des ID de produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]},"position":{"description":"Position de l\u2019image. 0 signifie que l\u2019image est \u00e0 la une.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"variations":{"description":"Liste de variations.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la variation.","type":"integer","context":["view","edit"],"readonly":true},"date_created":{"description":"La date \u00e0 laquelle la variation a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle la variation a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"permalink":{"description":"URL de la variation.","type":"string","format":"uri","context":["view","edit"],"readonly":true},"sku":{"description":"Identifiant unique.","type":"string","context":["view","edit"]},"price":{"description":"Tarif actuel de la variation.","type":"string","context":["view","edit"],"readonly":true},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","context":["view","edit"]},"sale_price":{"description":"Tarif promo de la variation.","type":"string","context":["view","edit"]},"date_on_sale_from":{"description":"Date de d\u00e9but du tarif promo.","type":"string","context":["view","edit"]},"date_on_sale_to":{"description":"Date de fin du tarif de promotion.","type":"string","context":["view","edit"]},"on_sale":{"description":"Indique si la variation est en promotion.","type":"boolean","context":["view","edit"],"readonly":true},"purchasable":{"description":"Indique si la variation peut \u00eatre achet\u00e9.","type":"boolean","context":["view","edit"],"readonly":true},"visible":{"description":"Si la variation est visible.","type":"boolean","context":["view","edit"]},"virtual":{"description":"Si la variation est virtuelle.","type":"boolean","default":false,"context":["view","edit"]},"downloadable":{"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","default":false,"context":["view","edit"]},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}}},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","default":null,"context":["view","edit"]},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","default":null,"context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","default":"taxable","enum":["taxable","shipping","none"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe.","type":"string","context":["view","edit"]},"manage_stock":{"description":"Gestion des stocks au niveau des variations.","type":["boolean","string"],"default":false,"context":["view","edit"]},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","context":["view","edit"]},"in_stock":{"description":"Contr\u00f4le si la variation est list\u00e9e comme \u00e9tant \u00ab\u00a0en stock\u00a0\u00bb ou \u00ab\u00a0en rupture\u00a0\u00bb sur le site.","type":"boolean","default":true,"context":["view","edit"]},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","default":"no","enum":["no","notify","yes"],"context":["view","edit"]},"backorders_allowed":{"description":"Indique si les commandes en r\u00e9assorts sont autoris\u00e9s.","type":"boolean","context":["view","edit"],"readonly":true},"backordered":{"description":"Affiche si la variation est en r\u00e9approvisionnement.","type":"boolean","context":["view","edit"],"readonly":true},"weight":{"description":"Poids de la variation (kg).","type":"string","context":["view","edit"]},"dimensions":{"description":"Dimensions de la variation.","type":"object","context":["view","edit"],"properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}}},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"shipping_class_id":{"description":"ID de la classe d\u2019exp\u00e9dition.","type":"integer","context":["view","edit"],"readonly":true},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","context":["view","edit"],"properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]},"position":{"description":"Position de l\u2019image. 0 signifie que l\u2019image est \u00e0 la une.","type":"integer","context":["view","edit"]}}},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}}}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/products"}]}},"\/wc\/v1\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"type":{"description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Identifiant unique.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du tarif promo.","type":"string","required":false},"date_on_sale_to":{"description":"Date de fin du tarif de promotion.","type":"string","required":false},"virtual":{"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"download_type":{"description":"Type de t\u00e9l\u00e9chargement, cela d\u00e9termine le sch\u00e9ma sur le site.","type":"string","enum":["standard"],"required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"in_stock":{"description":"Contr\u00f4le si le produit est list\u00e9 comme &laquo;&nbsp;en stock&nbsp;&raquo; ou &laquo;&nbsp;en rupture&nbsp;&raquo; sur le site.","type":"boolean","required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"description":"Autoriser les avis.","type":"boolean","required":false},"upsell_ids":{"description":"Liste des ID de produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]},"position":{"description":"Position de l\u2019image. 0 signifie que l\u2019image est \u00e0 la une.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"variations":{"description":"Liste de variations.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la variation.","type":"integer","context":["view","edit"],"readonly":true},"date_created":{"description":"La date \u00e0 laquelle la variation a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle la variation a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"permalink":{"description":"URL de la variation.","type":"string","format":"uri","context":["view","edit"],"readonly":true},"sku":{"description":"Identifiant unique.","type":"string","context":["view","edit"]},"price":{"description":"Tarif actuel de la variation.","type":"string","context":["view","edit"],"readonly":true},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","context":["view","edit"]},"sale_price":{"description":"Tarif promo de la variation.","type":"string","context":["view","edit"]},"date_on_sale_from":{"description":"Date de d\u00e9but du tarif promo.","type":"string","context":["view","edit"]},"date_on_sale_to":{"description":"Date de fin du tarif de promotion.","type":"string","context":["view","edit"]},"on_sale":{"description":"Indique si la variation est en promotion.","type":"boolean","context":["view","edit"],"readonly":true},"purchasable":{"description":"Indique si la variation peut \u00eatre achet\u00e9.","type":"boolean","context":["view","edit"],"readonly":true},"visible":{"description":"Si la variation est visible.","type":"boolean","context":["view","edit"]},"virtual":{"description":"Si la variation est virtuelle.","type":"boolean","default":false,"context":["view","edit"]},"downloadable":{"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","default":false,"context":["view","edit"]},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}}},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","default":null,"context":["view","edit"]},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","default":null,"context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","default":"taxable","enum":["taxable","shipping","none"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe.","type":"string","context":["view","edit"]},"manage_stock":{"description":"Gestion des stocks au niveau des variations.","type":["boolean","string"],"default":false,"context":["view","edit"]},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","context":["view","edit"]},"in_stock":{"description":"Contr\u00f4le si la variation est list\u00e9e comme \u00e9tant \u00ab\u00a0en stock\u00a0\u00bb ou \u00ab\u00a0en rupture\u00a0\u00bb sur le site.","type":"boolean","default":true,"context":["view","edit"]},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","default":"no","enum":["no","notify","yes"],"context":["view","edit"]},"backorders_allowed":{"description":"Indique si les commandes en r\u00e9assorts sont autoris\u00e9s.","type":"boolean","context":["view","edit"],"readonly":true},"backordered":{"description":"Affiche si la variation est en r\u00e9approvisionnement.","type":"boolean","context":["view","edit"],"readonly":true},"weight":{"description":"Poids de la variation (kg).","type":"string","context":["view","edit"]},"dimensions":{"description":"Dimensions de la variation.","type":"object","context":["view","edit"],"properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}}},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"shipping_class_id":{"description":"ID de la classe d\u2019exp\u00e9dition.","type":"integer","context":["view","edit"],"readonly":true},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","context":["view","edit"],"properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]},"position":{"description":"Position de l\u2019image. 0 signifie que l\u2019image est \u00e0 la une.","type":"integer","context":["view","edit"]}}},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}}}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","type":"boolean","required":false}}}]},"\/wc\/v1\/products\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"type":{"description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Identifiant unique.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du tarif promo.","type":"string","required":false},"date_on_sale_to":{"description":"Date de fin du tarif de promotion.","type":"string","required":false},"virtual":{"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"download_type":{"description":"Type de t\u00e9l\u00e9chargement, cela d\u00e9termine le sch\u00e9ma sur le site.","type":"string","enum":["standard"],"required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"in_stock":{"description":"Contr\u00f4le si le produit est list\u00e9 comme &laquo;&nbsp;en stock&nbsp;&raquo; ou &laquo;&nbsp;en rupture&nbsp;&raquo; sur le site.","type":"boolean","required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"description":"Autoriser les avis.","type":"boolean","required":false},"upsell_ids":{"description":"Liste des ID de produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]},"position":{"description":"Position de l\u2019image. 0 signifie que l\u2019image est \u00e0 la une.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"variations":{"description":"Liste de variations.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la variation.","type":"integer","context":["view","edit"],"readonly":true},"date_created":{"description":"La date \u00e0 laquelle la variation a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle la variation a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"permalink":{"description":"URL de la variation.","type":"string","format":"uri","context":["view","edit"],"readonly":true},"sku":{"description":"Identifiant unique.","type":"string","context":["view","edit"]},"price":{"description":"Tarif actuel de la variation.","type":"string","context":["view","edit"],"readonly":true},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","context":["view","edit"]},"sale_price":{"description":"Tarif promo de la variation.","type":"string","context":["view","edit"]},"date_on_sale_from":{"description":"Date de d\u00e9but du tarif promo.","type":"string","context":["view","edit"]},"date_on_sale_to":{"description":"Date de fin du tarif de promotion.","type":"string","context":["view","edit"]},"on_sale":{"description":"Indique si la variation est en promotion.","type":"boolean","context":["view","edit"],"readonly":true},"purchasable":{"description":"Indique si la variation peut \u00eatre achet\u00e9.","type":"boolean","context":["view","edit"],"readonly":true},"visible":{"description":"Si la variation est visible.","type":"boolean","context":["view","edit"]},"virtual":{"description":"Si la variation est virtuelle.","type":"boolean","default":false,"context":["view","edit"]},"downloadable":{"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","default":false,"context":["view","edit"]},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}}},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","default":null,"context":["view","edit"]},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","default":null,"context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","default":"taxable","enum":["taxable","shipping","none"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe.","type":"string","context":["view","edit"]},"manage_stock":{"description":"Gestion des stocks au niveau des variations.","type":["boolean","string"],"default":false,"context":["view","edit"]},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","context":["view","edit"]},"in_stock":{"description":"Contr\u00f4le si la variation est list\u00e9e comme \u00e9tant \u00ab\u00a0en stock\u00a0\u00bb ou \u00ab\u00a0en rupture\u00a0\u00bb sur le site.","type":"boolean","default":true,"context":["view","edit"]},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","default":"no","enum":["no","notify","yes"],"context":["view","edit"]},"backorders_allowed":{"description":"Indique si les commandes en r\u00e9assorts sont autoris\u00e9s.","type":"boolean","context":["view","edit"],"readonly":true},"backordered":{"description":"Affiche si la variation est en r\u00e9approvisionnement.","type":"boolean","context":["view","edit"],"readonly":true},"weight":{"description":"Poids de la variation (kg).","type":"string","context":["view","edit"]},"dimensions":{"description":"Dimensions de la variation.","type":"object","context":["view","edit"],"properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}}},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"shipping_class_id":{"description":"ID de la classe d\u2019exp\u00e9dition.","type":"integer","context":["view","edit"],"readonly":true},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","context":["view","edit"],"properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]},"position":{"description":"Position de l\u2019image. 0 signifie que l\u2019image est \u00e0 la une.","type":"integer","context":["view","edit"]}}},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}}}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/products\/batch"}]}},"\/wc\/v1\/reports\/sales":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"P\u00e9riode du rapport.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Retourne les ventes pour une date de d\u00e9but sp\u00e9cifique, la date doit \u00eatre dans le format YYYY-MM-DD.","type":"string","format":"date","required":false},"date_max":{"description":"Retourne les ventes pour une date de fin sp\u00e9cifique, la date doit \u00eatre dans le format YYYY-MM-DD.","type":"string","format":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/reports\/sales"}]}},"\/wc\/v1\/reports\/top_sellers":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"P\u00e9riode du rapport.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Retourne les ventes pour une date de d\u00e9but sp\u00e9cifique, la date doit \u00eatre dans le format YYYY-MM-DD.","type":"string","format":"date","required":false},"date_max":{"description":"Retourne les ventes pour une date de fin sp\u00e9cifique, la date doit \u00eatre dans le format YYYY-MM-DD.","type":"string","format":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/reports\/top_sellers"}]}},"\/wc\/v1\/reports":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/reports"}]}},"\/wc\/v1\/taxes\/classes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nom de la classe de taxe.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/taxes\/classes"}]}},"\/wc\/v1\/taxes\/classes\/(?P<slug>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"slug":{"description":"Slug unique pour la ressource.","type":"string","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v1\/taxes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"default":"asc","description":"Attribut de tri de commande croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"Trier la collection par attribut d\u2019objet.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"Trier par classe de taxe.","enum":["standard","taux-reduit","taux-zero"],"type":"string","required":false}}},{"methods":["POST"],"args":{"country":{"description":"Code pays ISO 3166.","type":"string","required":false},"state":{"description":"Code r\u00e9gion.","type":"string","required":false},"postcode":{"description":"Code postal.","type":"string","required":false},"city":{"description":"Nom de la ville.","type":"string","required":false},"rate":{"description":"Taux de taxe.","type":"string","required":false},"name":{"description":"Nom du taux de taxe.","type":"string","required":false},"priority":{"default":1,"description":"Priorit\u00e9 de la taxe.","type":"integer","required":false},"compound":{"default":false,"description":"S\u2019il s\u2019agit ou non d\u2019un taux compos\u00e9.","type":"boolean","required":false},"shipping":{"default":true,"description":"Si ce taux de taxe s\u2019applique ou non \u00e0 l\u2019exp\u00e9dition.","type":"boolean","required":false},"order":{"description":"Indique l&rsquo;ordre dans lequel cela appara\u00eetra dans les requ\u00eates.","type":"integer","required":false},"class":{"default":"standard","description":"Classe de taxe.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/taxes"}]}},"\/wc\/v1\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"country":{"description":"Code pays ISO 3166.","type":"string","required":false},"state":{"description":"Code r\u00e9gion.","type":"string","required":false},"postcode":{"description":"Code postal.","type":"string","required":false},"city":{"description":"Nom de la ville.","type":"string","required":false},"rate":{"description":"Taux de taxe.","type":"string","required":false},"name":{"description":"Nom du taux de taxe.","type":"string","required":false},"priority":{"description":"Priorit\u00e9 de la taxe.","type":"integer","required":false},"compound":{"description":"S\u2019il s\u2019agit ou non d\u2019un taux compos\u00e9.","type":"boolean","required":false},"shipping":{"description":"Si ce taux de taxe s\u2019applique ou non \u00e0 l\u2019exp\u00e9dition.","type":"boolean","required":false},"order":{"description":"Indique l&rsquo;ordre dans lequel cela appara\u00eetra dans les requ\u00eates.","type":"integer","required":false},"class":{"description":"Classe de taxe.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v1\/taxes\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"Code pays ISO 3166.","type":"string","required":false},"state":{"description":"Code r\u00e9gion.","type":"string","required":false},"postcode":{"description":"Code postal.","type":"string","required":false},"city":{"description":"Nom de la ville.","type":"string","required":false},"rate":{"description":"Taux de taxe.","type":"string","required":false},"name":{"description":"Nom du taux de taxe.","type":"string","required":false},"priority":{"description":"Priorit\u00e9 de la taxe.","type":"integer","required":false},"compound":{"description":"S\u2019il s\u2019agit ou non d\u2019un taux compos\u00e9.","type":"boolean","required":false},"shipping":{"description":"Si ce taux de taxe s\u2019applique ou non \u00e0 l\u2019exp\u00e9dition.","type":"boolean","required":false},"order":{"description":"Indique l&rsquo;ordre dans lequel cela appara\u00eetra dans les requ\u00eates.","type":"integer","required":false},"class":{"description":"Classe de taxe.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/taxes\/batch"}]}},"\/wc\/v1\/webhooks":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","title"],"required":false},"status":{"default":"all","description":"Limiter les r\u00e9sultats aux webhooks affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["all","active","paused","disabled"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Un nom convivial pour le crochet web.","type":"string","required":false},"status":{"default":"active","description":"\u00c9tat du webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"type":"string","description":"Sujet du crochet web.","required":true},"secret":{"description":"Cl\u00e9 secr\u00e8te utilis\u00e9e pour g\u00e9n\u00e9rer un hachage du crochet web livr\u00e9 et indiqu\u00e9e dans les en-t\u00eates de requ\u00eate. Si elle n\u2019est pas fournie, elle est d\u00e9finie par d\u00e9faut sur un hachage MD5 issu de l\u2019ID\u00a0\/ identifiant de l\u2019utilisateur actuel.","type":"string","required":false},"delivery_url":{"type":"string","description":"URL de livraison du crochet web.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/webhooks"}]}},"\/wc\/v1\/webhooks\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Un nom convivial pour le crochet web.","type":"string","required":false},"status":{"description":"\u00c9tat du webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Sujet du crochet web.","type":"string","required":false},"secret":{"description":"Cl\u00e9 secr\u00e8te utilis\u00e9e pour g\u00e9n\u00e9rer un hachage du crochet web livr\u00e9 et indiqu\u00e9e dans les en-t\u00eates de requ\u00eate. Si elle n\u2019est pas fournie, elle est d\u00e9finie par d\u00e9faut sur un hachage MD5 issu de l\u2019ID\u00a0\/ identifiant de l\u2019utilisateur actuel.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v1\/webhooks\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Un nom convivial pour le crochet web.","type":"string","required":false},"status":{"description":"\u00c9tat du webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Sujet du crochet web.","type":"string","required":false},"secret":{"description":"Cl\u00e9 secr\u00e8te utilis\u00e9e pour g\u00e9n\u00e9rer un hachage du crochet web livr\u00e9 et indiqu\u00e9e dans les en-t\u00eates de requ\u00eate. Si elle n\u2019est pas fournie, elle est d\u00e9finie par d\u00e9faut sur un hachage MD5 issu de l\u2019ID\u00a0\/ identifiant de l\u2019utilisateur actuel.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v1\/webhooks\/batch"}]}},"\/wc\/v1\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Identifiant unique pour le crochet web.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/v1\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Identifiant unique pour le crochet web.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/v2\/coupons":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"code":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un code sp\u00e9cifique.","type":"string","required":false}}},{"methods":["POST"],"args":{"code":{"description":"Code promo.","type":"string","required":true},"amount":{"description":"Le montant de la remise. Doit toujours \u00eatre num\u00e9rique, m\u00eame si vous d\u00e9finissez un pourcentage.","type":["number","string"],"required":false},"status":{"description":"\u00c9tat du code promo. Doit toujours \u00eatre \u00e0 l\u2019\u00e9tat de brouillon, publi\u00e9 ou en cours de r\u00e9vision","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"D\u00e9termine le type de remise qui sera appliqu\u00e9.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Description du code promo.","type":"string","required":false},"date_expires":{"description":"Date d\u2019expiration du code promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"Date d\u2019expiration du code promo, format GMT.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"Si vrai, le code promo ne peut \u00eatre utilis\u00e9 qu&rsquo;individuellement. Les autres codes promo appliqu\u00e9s seront retir\u00e9s du panier.","type":"boolean","required":false},"product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo peut \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo ne peut pas \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Combien de fois le code promo peut \u00eatre utilis\u00e9.","type":"integer","required":false},"usage_limit_per_user":{"description":"Nombre de fois que le code promo peut \u00eatre utilis\u00e9 par client.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Nombre maximum d&rsquo;articles dans le panier auxquels le code promo peut \u00eatre appliqu\u00e9.","type":"integer","required":false},"free_shipping":{"default":false,"description":"Si vrai et que le mode d\u2019exp\u00e9dition gratuite n\u00e9cessite un code promo, ce code promo activera la livraison gratuite.","type":"boolean","required":false},"product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo s\u2019applique.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo ne s&rsquo;applique pas.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"Si vrai, ce code promo ne sera pas appliqu\u00e9 aux articles qui sont en promotion.","type":"boolean","required":false},"minimum_amount":{"description":"Montant minimum de commande qui doit \u00eatre dans le panier avant que le code promo ne s\u2019applique.","type":["number","string"],"required":false},"maximum_amount":{"description":"Montant maximum de commande autoris\u00e9 lors de l&rsquo;utilisation du code promo.","type":["number","string"],"required":false},"email_restrictions":{"description":"Liste des e-mails qui peuvent utiliser ce code promo.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/coupons"}]}},"\/wc\/v2\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"code":{"description":"Code promo.","type":"string","required":false},"amount":{"description":"Le montant de la remise. Doit toujours \u00eatre num\u00e9rique, m\u00eame si vous d\u00e9finissez un pourcentage.","type":["number","string"],"required":false},"status":{"description":"\u00c9tat du code promo. Doit toujours \u00eatre \u00e0 l\u2019\u00e9tat de brouillon, publi\u00e9 ou en cours de r\u00e9vision","type":"string","required":false},"discount_type":{"description":"D\u00e9termine le type de remise qui sera appliqu\u00e9.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Description du code promo.","type":"string","required":false},"date_expires":{"description":"Date d\u2019expiration du code promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"Date d\u2019expiration du code promo, format GMT.","type":["null","string"],"required":false},"individual_use":{"description":"Si vrai, le code promo ne peut \u00eatre utilis\u00e9 qu&rsquo;individuellement. Les autres codes promo appliqu\u00e9s seront retir\u00e9s du panier.","type":"boolean","required":false},"product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo peut \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo ne peut pas \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Combien de fois le code promo peut \u00eatre utilis\u00e9.","type":"integer","required":false},"usage_limit_per_user":{"description":"Nombre de fois que le code promo peut \u00eatre utilis\u00e9 par client.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Nombre maximum d&rsquo;articles dans le panier auxquels le code promo peut \u00eatre appliqu\u00e9.","type":"integer","required":false},"free_shipping":{"description":"Si vrai et que le mode d\u2019exp\u00e9dition gratuite n\u00e9cessite un code promo, ce code promo activera la livraison gratuite.","type":"boolean","required":false},"product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo s\u2019applique.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo ne s&rsquo;applique pas.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si vrai, ce code promo ne sera pas appliqu\u00e9 aux articles qui sont en promotion.","type":"boolean","required":false},"minimum_amount":{"description":"Montant minimum de commande qui doit \u00eatre dans le panier avant que le code promo ne s\u2019applique.","type":["number","string"],"required":false},"maximum_amount":{"description":"Montant maximum de commande autoris\u00e9 lors de l&rsquo;utilisation du code promo.","type":["number","string"],"required":false},"email_restrictions":{"description":"Liste des e-mails qui peuvent utiliser ce code promo.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v2\/coupons\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"Code promo.","type":"string","required":false},"amount":{"description":"Le montant de la remise. Doit toujours \u00eatre num\u00e9rique, m\u00eame si vous d\u00e9finissez un pourcentage.","type":["number","string"],"required":false},"status":{"description":"\u00c9tat du code promo. Doit toujours \u00eatre \u00e0 l\u2019\u00e9tat de brouillon, publi\u00e9 ou en cours de r\u00e9vision","type":"string","required":false},"discount_type":{"description":"D\u00e9termine le type de remise qui sera appliqu\u00e9.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Description du code promo.","type":"string","required":false},"date_expires":{"description":"Date d\u2019expiration du code promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"Date d\u2019expiration du code promo, format GMT.","type":["null","string"],"required":false},"individual_use":{"description":"Si vrai, le code promo ne peut \u00eatre utilis\u00e9 qu&rsquo;individuellement. Les autres codes promo appliqu\u00e9s seront retir\u00e9s du panier.","type":"boolean","required":false},"product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo peut \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo ne peut pas \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Combien de fois le code promo peut \u00eatre utilis\u00e9.","type":"integer","required":false},"usage_limit_per_user":{"description":"Nombre de fois que le code promo peut \u00eatre utilis\u00e9 par client.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Nombre maximum d&rsquo;articles dans le panier auxquels le code promo peut \u00eatre appliqu\u00e9.","type":"integer","required":false},"free_shipping":{"description":"Si vrai et que le mode d\u2019exp\u00e9dition gratuite n\u00e9cessite un code promo, ce code promo activera la livraison gratuite.","type":"boolean","required":false},"product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo s\u2019applique.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo ne s&rsquo;applique pas.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si vrai, ce code promo ne sera pas appliqu\u00e9 aux articles qui sont en promotion.","type":"boolean","required":false},"minimum_amount":{"description":"Montant minimum de commande qui doit \u00eatre dans le panier avant que le code promo ne s\u2019applique.","type":["number","string"],"required":false},"maximum_amount":{"description":"Montant maximum de commande autoris\u00e9 lors de l&rsquo;utilisation du code promo.","type":["number","string"],"required":false},"email_restrictions":{"description":"Liste des e-mails qui peuvent utiliser ce code promo.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/coupons\/batch"}]}},"\/wc\/v2\/customers\/(?P<customer_id>[\\d]+)\/downloads":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"customer_id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}]},"\/wc\/v2\/customers":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"default":"asc","description":"Attribut de tri de commande croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Trier la collection par attribut d\u2019objet.","enum":["id","include","name","registered_date"],"type":"string","required":false},"email":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un e-mail sp\u00e9cifique.","type":"string","format":"email","required":false},"role":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un r\u00f4le sp\u00e9cifique.","type":"string","default":"customer","enum":["all","administrator","editor","author","contributor","subscriber","customer","shop_manager","responsable_region","wpseo_manager","wpseo_editor"],"required":false}}},{"methods":["POST"],"args":{"email":{"type":"string","description":"Nouvelle adresse e-mail de l&rsquo;utilisateur.","required":true},"first_name":{"description":"Pr\u00e9nom du client.","type":"string","required":false},"last_name":{"description":"Nom du client.","type":"string","required":false},"username":{"description":"Nouvel identifiant.","type":"string","required":false},"password":{"description":"Nouveau mot de passe de l&rsquo;utilisateur.","type":"string","required":false},"billing":{"description":"Liste de donn\u00e9es de l&rsquo;adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Liste des donn\u00e9es d\u2019adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/customers"}]}},"\/wc\/v2\/customers\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"email":{"description":"L\u2019e-mail pour le client.","type":"string","format":"email","required":false},"first_name":{"description":"Pr\u00e9nom du client.","type":"string","required":false},"last_name":{"description":"Nom du client.","type":"string","required":false},"username":{"description":"Nom de connexion du client.","type":"string","required":false},"password":{"description":"Mot de passe client.","type":"string","required":false},"billing":{"description":"Liste de donn\u00e9es de l&rsquo;adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Liste des donn\u00e9es d\u2019adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false},"reassign":{"default":0,"type":"integer","description":"ID \u00e0 r\u00e9assigner aux articles.","required":false}}}]},"\/wc\/v2\/customers\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"email":{"description":"L\u2019e-mail pour le client.","type":"string","format":"email","required":false},"first_name":{"description":"Pr\u00e9nom du client.","type":"string","required":false},"last_name":{"description":"Nom du client.","type":"string","required":false},"username":{"description":"Nom de connexion du client.","type":"string","required":false},"password":{"description":"Mot de passe client.","type":"string","required":false},"billing":{"description":"Liste de donn\u00e9es de l&rsquo;adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Liste des donn\u00e9es d\u2019adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/customers\/batch"}]}},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/notes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"type":{"default":"any","description":"Limiter le r\u00e9sultat aux clients ou aux notes internes.","type":"string","enum":["any","customer","internal"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"note":{"type":"string","description":"Contenu de la note de commande.","required":true},"customer_note":{"default":false,"description":"Si vrai, la note sera affich\u00e9e aux clients et ils seront notifi\u00e9s. Si faux, la note sera uniquement pour l&rsquo;administration.","type":"boolean","required":false}}}]},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/notes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/refunds":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"dp":{"default":2,"description":"Nombre de d\u00e9cimales \u00e0 utiliser dans chaque ressource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Affichez uniquement la m\u00e9ta qui est cens\u00e9e s\u2019afficher pour une commande.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"amount":{"description":"Montant du remboursement.","type":"string","required":false},"reason":{"description":"Motif du remboursement.","type":"string","required":false},"refunded_by":{"description":"ID de l\u2019utilisateur qui a cr\u00e9\u00e9 le remboursement.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de l\u2019instance d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"api_refund":{"default":true,"description":"Lorsque vrai, l\u2019API de passerelle de paiement est utilis\u00e9e pour g\u00e9n\u00e9rer le remboursement.","type":"boolean","required":false}}}]},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/refunds\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v2\/orders":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux commandes affect\u00e9es \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","trash","auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Limiter le jeu de r\u00e9sultats aux commandes affect\u00e9es \u00e0 un client sp\u00e9cifique.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux commandes affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","required":false},"dp":{"default":2,"description":"Nombre de d\u00e9cimales \u00e0 utiliser dans chaque ressource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Affichez uniquement la m\u00e9ta qui est cens\u00e9e s\u2019afficher pour une commande.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"ID de commande parente.","type":"integer","required":false},"status":{"default":"pending","description":"\u00c9tat de la commande.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"EUR","description":"Devise avec laquelle la commande a \u00e9t\u00e9 cr\u00e9\u00e9e, au format ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"ID utilisateur propri\u00e9taire de la commande. 0 pour les invit\u00e9s.","type":"integer","required":false},"customer_note":{"description":"Note laiss\u00e9e par le client lors de la commande.","type":"string","required":false},"billing":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID du moyen de paiement.","type":"string","required":false},"payment_method_title":{"description":"Titre du moyen de paiement.","type":"string","required":false},"transaction_id":{"description":"ID unique de transaction.","type":"string","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Ligne de donn\u00e9es des articles.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom du produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nom du produit parent si le produit est une variation.","type":"string","context":["view","edit"]},"product_id":{"description":"ID produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variation, si applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantit\u00e9 command\u00e9.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Classe de taxe de produit.","type":"string","context":["view","edit"]},"subtotal":{"description":"Ligne de sous-total (avant remises).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Ligne de sous-total de taxe (avant remises).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"]},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"]},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Cl\u00e9 m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]},"display_value":{"description":"Valeur de m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]}}}},"sku":{"description":"UGS du produit.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tarif du produit.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propri\u00e9t\u00e9s de l\u2019image principale du produit.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de l\u2019instance d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Ligne de donn\u00e9es des codes promo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Code promo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Remise totale.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Taxe totale de la remise.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Type de remise.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Montant de la remise telle que d\u00e9finie dans le code promo (valeur absolue ou pourcentage, en fonction du type de remise).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si le code promo donne droit \u00e0 la livraison gratuite ou non.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"default":false,"description":"D\u00e9termine si la commande est pay\u00e9e. Cela va d\u00e9finir l\u2019\u00e9tat \u00e0 en cours et r\u00e9duire de stock des articles.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/orders"}]}},"\/wc\/v2\/orders\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"parent_id":{"description":"ID de commande parente.","type":"integer","required":false},"status":{"description":"\u00c9tat de la commande.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Devise avec laquelle la commande a \u00e9t\u00e9 cr\u00e9\u00e9e, au format ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID utilisateur propri\u00e9taire de la commande. 0 pour les invit\u00e9s.","type":"integer","required":false},"customer_note":{"description":"Note laiss\u00e9e par le client lors de la commande.","type":"string","required":false},"billing":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID du moyen de paiement.","type":"string","required":false},"payment_method_title":{"description":"Titre du moyen de paiement.","type":"string","required":false},"transaction_id":{"description":"ID unique de transaction.","type":"string","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Ligne de donn\u00e9es des articles.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom du produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nom du produit parent si le produit est une variation.","type":"string","context":["view","edit"]},"product_id":{"description":"ID produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variation, si applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantit\u00e9 command\u00e9.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Classe de taxe de produit.","type":"string","context":["view","edit"]},"subtotal":{"description":"Ligne de sous-total (avant remises).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Ligne de sous-total de taxe (avant remises).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"]},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"]},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Cl\u00e9 m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]},"display_value":{"description":"Valeur de m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]}}}},"sku":{"description":"UGS du produit.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tarif du produit.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propri\u00e9t\u00e9s de l\u2019image principale du produit.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de l\u2019instance d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Ligne de donn\u00e9es des codes promo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Code promo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Remise totale.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Taxe totale de la remise.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Type de remise.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Montant de la remise telle que d\u00e9finie dans le code promo (valeur absolue ou pourcentage, en fonction du type de remise).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si le code promo donne droit \u00e0 la livraison gratuite ou non.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"D\u00e9termine si la commande est pay\u00e9e. Cela va d\u00e9finir l\u2019\u00e9tat \u00e0 en cours et r\u00e9duire de stock des articles.","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v2\/orders\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"ID de commande parente.","type":"integer","required":false},"status":{"description":"\u00c9tat de la commande.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Devise avec laquelle la commande a \u00e9t\u00e9 cr\u00e9\u00e9e, au format ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID utilisateur propri\u00e9taire de la commande. 0 pour les invit\u00e9s.","type":"integer","required":false},"customer_note":{"description":"Note laiss\u00e9e par le client lors de la commande.","type":"string","required":false},"billing":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID du moyen de paiement.","type":"string","required":false},"payment_method_title":{"description":"Titre du moyen de paiement.","type":"string","required":false},"transaction_id":{"description":"ID unique de transaction.","type":"string","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Ligne de donn\u00e9es des articles.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom du produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nom du produit parent si le produit est une variation.","type":"string","context":["view","edit"]},"product_id":{"description":"ID produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variation, si applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantit\u00e9 command\u00e9.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Classe de taxe de produit.","type":"string","context":["view","edit"]},"subtotal":{"description":"Ligne de sous-total (avant remises).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Ligne de sous-total de taxe (avant remises).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"]},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"]},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Cl\u00e9 m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]},"display_value":{"description":"Valeur de m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]}}}},"sku":{"description":"UGS du produit.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tarif du produit.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propri\u00e9t\u00e9s de l\u2019image principale du produit.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de l\u2019instance d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Ligne de donn\u00e9es des codes promo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Code promo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Remise totale.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Taxe totale de la remise.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Type de remise.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Montant de la remise telle que d\u00e9finie dans le code promo (valeur absolue ou pourcentage, en fonction du type de remise).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si le code promo donne droit \u00e0 la livraison gratuite ou non.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"D\u00e9termine si la commande est pay\u00e9e. Cela va d\u00e9finir l\u2019\u00e9tat \u00e0 en cours et r\u00e9duire de stock des articles.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/orders\/batch"}]}},"\/wc\/v2\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}}]},"\/wc\/v2\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"name":{"description":"Nom du terme.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v2\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"name":{"description":"Nom du terme.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}}]},"\/wc\/v2\/products\/attributes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nom pour la ressource.","type":"string","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"type":{"default":"select","description":"Type d&rsquo;attribut.","type":"string","enum":["select"],"required":false},"order_by":{"default":"menu_order","description":"Tri par d\u00e9faut.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Activer\/d\u00e9sactiver les archives d&rsquo;attribut.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/products\/attributes"}]}},"\/wc\/v2\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de l\u2019attribut.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"type":{"description":"Type d&rsquo;attribut.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Tri par d\u00e9faut.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activer\/d\u00e9sactiver les archives d&rsquo;attribut.","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v2\/products\/attributes\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom de l\u2019attribut.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"type":{"description":"Type d&rsquo;attribut.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Tri par d\u00e9faut.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activer\/d\u00e9sactiver les archives d&rsquo;attribut.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/products\/attributes\/batch"}]}},"\/wc\/v2\/products\/categories":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"default":"default","description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/products\/categories"}]}},"\/wc\/v2\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v2\/products\/categories\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/products\/categories\/batch"}]}},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/reviews":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la variation.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la variation.","type":"integer","required":false},"review":{"type":"string","description":"Contenu de l\u2019avis.","required":true},"date_created":{"description":"La date \u00e0 laquelle l&rsquo;avis a \u00e9t\u00e9 cr\u00e9\u00e9, en fuseau horaire du site.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La date \u00e0 laquelle l&rsquo;avis a \u00e9t\u00e9 cr\u00e9\u00e9, format GMT.","type":["null","string"],"required":false},"rating":{"description":"Note de l\u2019avis (0 \u00e0 5).","type":"integer","required":false},"name":{"type":"string","description":"Nom de l&rsquo;\u00e9valuateur.","required":true},"email":{"type":"string","description":"E-mail de l&rsquo;\u00e9valuateur.","required":true}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"review":{"description":"Le contenu de l&rsquo;avis.","type":"string","required":false},"date_created":{"description":"La date \u00e0 laquelle l&rsquo;avis a \u00e9t\u00e9 cr\u00e9\u00e9, en fuseau horaire du site.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La date \u00e0 laquelle l&rsquo;avis a \u00e9t\u00e9 cr\u00e9\u00e9, format GMT.","type":["null","string"],"required":false},"rating":{"description":"Note de l\u2019avis (0 \u00e0 5).","type":"integer","required":false},"name":{"description":"Nom de l&rsquo;\u00e9valuateur.","type":"string","required":false},"email":{"description":"Email de l&rsquo;\u00e9valuateur.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/reviews\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"review":{"description":"Le contenu de l&rsquo;avis.","type":"string","required":false},"date_created":{"description":"La date \u00e0 laquelle l&rsquo;avis a \u00e9t\u00e9 cr\u00e9\u00e9, en fuseau horaire du site.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La date \u00e0 laquelle l&rsquo;avis a \u00e9t\u00e9 cr\u00e9\u00e9, format GMT.","type":["null","string"],"required":false},"rating":{"description":"Note de l\u2019avis (0 \u00e0 5).","type":"integer","required":false},"name":{"description":"Nom de l&rsquo;\u00e9valuateur.","type":"string","required":false},"email":{"description":"Email de l&rsquo;\u00e9valuateur.","type":"string","required":false}}}]},"\/wc\/v2\/products\/shipping_classes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/products\/shipping_classes"}]}},"\/wc\/v2\/products\/shipping_classes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v2\/products\/shipping_classes\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/products\/shipping_classes\/batch"}]}},"\/wc\/v2\/products\/tags":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/products\/tags"}]}},"\/wc\/v2\/products\/tags\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v2\/products\/tags\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/products\/tags\/batch"}]}},"\/wc\/v2\/products":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de marque sp\u00e9cifique.","type":"string","required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un identifiant sp\u00e9cifique.","type":"string","required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un type sp\u00e9cifique.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"featured":{"description":"Limiter le jeu de r\u00e9sultats aux produits mis en avant.","type":"boolean","required":false},"category":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de cat\u00e9gorie sp\u00e9cifique.","type":"string","required":false},"tag":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID d\u2019\u00e9tiquette sp\u00e9cifique.","type":"string","required":false},"shipping_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de classe d\u2019exp\u00e9dition sp\u00e9cifique.","type":"string","required":false},"attribute":{"description":"Limiter les r\u00e9sultats aux produits avec un attribut sp\u00e9cifique. Utiliser le nom de la taxonomie \/ le slug de l\u2019attribut.","type":"string","required":false},"attribute_term":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un ID de terme d&rsquo;attribut sp\u00e9cifique (attribut affect\u00e9 requis).","type":"string","required":false},"tax_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec une classe de taxe sp\u00e9cifique.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"in_stock":{"description":"Limiter le jeu de r\u00e9sultats aux produits en stock ou en rupture de stock.","type":"boolean","required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif minimum.","type":"string","required":false},"max_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif maximum.","type":"string","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"type":{"default":"simple","description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"default":"publish","description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"default":false,"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Identifiant unique.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, notation GMT.","type":["null","string"],"required":false},"virtual":{"default":false,"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"default":"taxable","description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"in_stock":{"default":true,"description":"Contr\u00f4le si le produit est list\u00e9 comme &laquo;&nbsp;en stock&nbsp;&raquo; ou &laquo;&nbsp;en rupture&nbsp;&raquo; sur le site.","type":"boolean","required":false},"backorders":{"default":"no","description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"default":false,"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Autoriser les avis.","type":"boolean","required":false},"upsell_ids":{"description":"Liste des IDs des produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]},"position":{"description":"Position de l\u2019image. 0 signifie que l\u2019image est \u00e0 la une.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","context":["view","edit"],"items":{"type":"string"}}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"grouped_products":{"description":"Liste des ID des groupes de produits.","type":"array","items":{"type":"integer"},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/products"}]}},"\/wc\/v2\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"type":{"description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Identifiant unique.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, notation GMT.","type":["null","string"],"required":false},"virtual":{"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"in_stock":{"description":"Contr\u00f4le si le produit est list\u00e9 comme &laquo;&nbsp;en stock&nbsp;&raquo; ou &laquo;&nbsp;en rupture&nbsp;&raquo; sur le site.","type":"boolean","required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"description":"Autoriser les avis.","type":"boolean","required":false},"upsell_ids":{"description":"Liste des IDs des produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]},"position":{"description":"Position de l\u2019image. 0 signifie que l\u2019image est \u00e0 la une.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","context":["view","edit"],"items":{"type":"string"}}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"grouped_products":{"description":"Liste des ID des groupes de produits.","type":"array","items":{"type":"integer"},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","type":"boolean","required":false}}}]},"\/wc\/v2\/products\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"type":{"description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Identifiant unique.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, notation GMT.","type":["null","string"],"required":false},"virtual":{"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"in_stock":{"description":"Contr\u00f4le si le produit est list\u00e9 comme &laquo;&nbsp;en stock&nbsp;&raquo; ou &laquo;&nbsp;en rupture&nbsp;&raquo; sur le site.","type":"boolean","required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"description":"Autoriser les avis.","type":"boolean","required":false},"upsell_ids":{"description":"Liste des IDs des produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]},"position":{"description":"Position de l\u2019image. 0 signifie que l\u2019image est \u00e0 la une.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","context":["view","edit"],"items":{"type":"string"}}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"grouped_products":{"description":"Liste des ID des groupes de produits.","type":"array","items":{"type":"integer"},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/products\/batch"}]}},"\/wc\/v2\/products\/(?P<id>[\\d]+)\/related":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/variations":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un identifiant sp\u00e9cifique.","type":"string","required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un type sp\u00e9cifique.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"featured":{"description":"Limiter le jeu de r\u00e9sultats aux produits mis en avant.","type":"boolean","required":false},"category":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de cat\u00e9gorie sp\u00e9cifique.","type":"string","required":false},"tag":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID d\u2019\u00e9tiquette sp\u00e9cifique.","type":"string","required":false},"shipping_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de classe d\u2019exp\u00e9dition sp\u00e9cifique.","type":"string","required":false},"attribute":{"description":"Limiter les r\u00e9sultats aux produits avec un attribut sp\u00e9cifique. Utiliser le nom de la taxonomie \/ le slug de l\u2019attribut.","type":"string","required":false},"attribute_term":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un ID de terme d&rsquo;attribut sp\u00e9cifique (attribut affect\u00e9 requis).","type":"string","required":false},"tax_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec une classe de taxe sp\u00e9cifique.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"in_stock":{"description":"Limiter le jeu de r\u00e9sultats aux produits en stock ou en rupture de stock.","type":"boolean","required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif minimum.","type":"string","required":false},"max_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif maximum.","type":"string","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"description":{"description":"Description de la variation.","type":"string","required":false},"sku":{"description":"Identifiant unique.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","required":false},"sale_price":{"description":"Tarif promo de la variation.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, notation GMT.","type":["null","string"],"required":false},"visible":{"default":true,"description":"D\u00e9finit si la variation est visible sur la page du produit.","type":"boolean","required":false},"virtual":{"default":false,"description":"Si la variation est virtuelle.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gestion des stocks au niveau des variations.","type":["null","object","string","number","boolean","integer","array"],"required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"in_stock":{"default":true,"description":"Contr\u00f4le si la variation est list\u00e9e comme \u00e9tant \u00ab\u00a0en stock\u00a0\u00bb ou \u00ab\u00a0en rupture\u00a0\u00bb sur le site.","type":"boolean","required":false},"backorders":{"default":"no","description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"weight":{"description":"Poids de la variation (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions de la variation.","type":"object","properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]},"position":{"description":"Position de l\u2019image. 0 signifie que l\u2019image est \u00e0 la une.","type":"integer","context":["view","edit"]}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/variations\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la variation.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la variation.","type":"integer","required":false},"description":{"description":"Description de la variation.","type":"string","required":false},"sku":{"description":"Identifiant unique.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","required":false},"sale_price":{"description":"Tarif promo de la variation.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, notation GMT.","type":["null","string"],"required":false},"visible":{"description":"D\u00e9finit si la variation est visible sur la page du produit.","type":"boolean","required":false},"virtual":{"description":"Si la variation est virtuelle.","type":"boolean","required":false},"downloadable":{"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion des stocks au niveau des variations.","type":["null","object","string","number","boolean","integer","array"],"required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"in_stock":{"description":"Contr\u00f4le si la variation est list\u00e9e comme \u00e9tant \u00ab\u00a0en stock\u00a0\u00bb ou \u00ab\u00a0en rupture\u00a0\u00bb sur le site.","type":"boolean","required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"weight":{"description":"Poids de la variation (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions de la variation.","type":"object","properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]},"position":{"description":"Position de l\u2019image. 0 signifie que l\u2019image est \u00e0 la une.","type":"integer","context":["view","edit"]}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la variation.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/variations\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"description":{"description":"Description de la variation.","type":"string","required":false},"sku":{"description":"Identifiant unique.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","required":false},"sale_price":{"description":"Tarif promo de la variation.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, notation GMT.","type":["null","string"],"required":false},"visible":{"description":"D\u00e9finit si la variation est visible sur la page du produit.","type":"boolean","required":false},"virtual":{"description":"Si la variation est virtuelle.","type":"boolean","required":false},"downloadable":{"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion des stocks au niveau des variations.","type":["null","object","string","number","boolean","integer","array"],"required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"in_stock":{"description":"Contr\u00f4le si la variation est list\u00e9e comme \u00e9tant \u00ab\u00a0en stock\u00a0\u00bb ou \u00ab\u00a0en rupture\u00a0\u00bb sur le site.","type":"boolean","required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"weight":{"description":"Poids de la variation (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions de la variation.","type":"object","properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]},"position":{"description":"Position de l\u2019image. 0 signifie que l\u2019image est \u00e0 la une.","type":"integer","context":["view","edit"]}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc\/v2\/reports\/sales":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"P\u00e9riode du rapport.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Retourne les ventes pour une date de d\u00e9but sp\u00e9cifique, la date doit \u00eatre dans le format YYYY-MM-DD.","type":"string","format":"date","required":false},"date_max":{"description":"Retourne les ventes pour une date de fin sp\u00e9cifique, la date doit \u00eatre dans le format YYYY-MM-DD.","type":"string","format":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/reports\/sales"}]}},"\/wc\/v2\/reports\/top_sellers":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"P\u00e9riode du rapport.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Retourne les ventes pour une date de d\u00e9but sp\u00e9cifique, la date doit \u00eatre dans le format YYYY-MM-DD.","type":"string","format":"date","required":false},"date_max":{"description":"Retourne les ventes pour une date de fin sp\u00e9cifique, la date doit \u00eatre dans le format YYYY-MM-DD.","type":"string","format":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/reports\/top_sellers"}]}},"\/wc\/v2\/reports":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/reports"}]}},"\/wc\/v2\/settings":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/settings"}]}},"\/wc\/v2\/settings\/(?P<group_id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"ID de groupe de r\u00e9glages.","type":"string","required":false}}}]},"\/wc\/v2\/settings\/(?P<group_id>[\\w-]+)\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"ID de groupe de r\u00e9glages.","type":"string","required":false},"value":{"description":"Valeur de r\u00e9glage.","type":["null","object","string","number","boolean","integer","array"],"required":false}}}]},"\/wc\/v2\/settings\/(?P<group_id>[\\w-]+)\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"ID de groupe de r\u00e9glages.","type":"string","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"ID de groupe de r\u00e9glages.","type":"string","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false},"value":{"description":"Valeur de r\u00e9glage.","type":["null","object","string","number","boolean","integer","array"],"required":false}}}]},"\/wc\/v2\/shipping\/zones":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom de la zone de livraison.","required":true},"order":{"description":"Ordre de la zone d\u2019exp\u00e9dition.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/shipping\/zones"}]}},"\/wc\/v2\/shipping\/zones\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID unique pour la ressource.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de la zone de livraison.","type":"string","required":false},"order":{"description":"Ordre de la zone d\u2019exp\u00e9dition.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"ID unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v2\/shipping\/zones\/(?P<id>[\\d]+)\/locations":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID unique pour la ressource.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID unique pour la ressource.","type":"integer","required":false},"code":{"description":"Code de localisation du mode d\u2019exp\u00e9dition.","type":"string","required":false},"type":{"description":"Type de localisation du mode d\u2019exp\u00e9dition.","type":"string","enum":["postcode","state","country","continent"],"required":false}}}]},"\/wc\/v2\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"ID unique pour la zone.","type":"integer","required":false}}},{"methods":["POST"],"args":{"zone_id":{"description":"ID unique pour la zone.","type":"integer","required":false},"order":{"description":"Ordre de tri du mode d\u2019exp\u00e9dition.","type":"integer","required":false},"enabled":{"description":"Statut activ\u00e9 du mode d\u2019exp\u00e9dition.","type":"boolean","required":false},"settings":{"description":"R\u00e9glages du mode d\u2019exp\u00e9dition.","type":"object","properties":{"id":{"description":"Un identifiant unique pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Une \u00e9tiquette lisible par l&rsquo;utilisateur pour le r\u00e9glage utilis\u00e9 dans les interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Une description lisible par l&rsquo;utilisateur pour le r\u00e9glage utilis\u00e9 dans les interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Type de r\u00e9glage.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Valeur de r\u00e9glage.","type":"string","context":["view","edit"]},"default":{"description":"Valeur par d\u00e9faut pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Texte d&rsquo;aide suppl\u00e9mentaire affich\u00e9 \u00e0 l&rsquo;utilisateur pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Texte substitutif \u00e0 afficher dans les champs texte.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","required":true}}}]},"\/wc\/v2\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods\/(?P<instance_id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"ID unique pour la zone.","type":"integer","required":false},"instance_id":{"description":"ID unique pour l\u2019instance.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"zone_id":{"description":"ID unique pour la zone.","type":"integer","required":false},"instance_id":{"description":"ID unique pour l\u2019instance.","type":"integer","required":false},"order":{"description":"Ordre de tri du mode d\u2019exp\u00e9dition.","type":"integer","required":false},"enabled":{"description":"Statut activ\u00e9 du mode d\u2019exp\u00e9dition.","type":"boolean","required":false},"settings":{"description":"R\u00e9glages du mode d\u2019exp\u00e9dition.","type":"object","properties":{"id":{"description":"Un identifiant unique pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Une \u00e9tiquette lisible par l&rsquo;utilisateur pour le r\u00e9glage utilis\u00e9 dans les interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Une description lisible par l&rsquo;utilisateur pour le r\u00e9glage utilis\u00e9 dans les interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Type de r\u00e9glage.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Valeur de r\u00e9glage.","type":"string","context":["view","edit"]},"default":{"description":"Valeur par d\u00e9faut pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Texte d&rsquo;aide suppl\u00e9mentaire affich\u00e9 \u00e0 l&rsquo;utilisateur pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Texte substitutif \u00e0 afficher dans les champs texte.","type":"string","context":["view","edit"],"readonly":true}},"required":false}}},{"methods":["DELETE"],"args":{"zone_id":{"description":"ID unique pour la zone.","type":"integer","required":false},"instance_id":{"description":"ID unique pour l\u2019instance.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v2\/taxes\/classes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nom de la classe de taxe.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/taxes\/classes"}]}},"\/wc\/v2\/taxes\/classes\/(?P<slug>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Slug unique pour la ressource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"slug":{"description":"Slug unique pour la ressource.","type":"string","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v2\/taxes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"default":"asc","description":"Attribut de tri de commande croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"Trier la collection par attribut d\u2019objet.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"Trier par classe de taxe.","enum":["standard","taux-reduit","taux-zero"],"type":"string","required":false}}},{"methods":["POST"],"args":{"country":{"description":"Code pays ISO 3166.","type":"string","required":false},"state":{"description":"Code r\u00e9gion.","type":"string","required":false},"postcode":{"description":"Code postal.","type":"string","required":false},"city":{"description":"Nom de la ville.","type":"string","required":false},"rate":{"description":"Taux de taxe.","type":"string","required":false},"name":{"description":"Nom du taux de taxe.","type":"string","required":false},"priority":{"default":1,"description":"Priorit\u00e9 de la taxe.","type":"integer","required":false},"compound":{"default":false,"description":"S\u2019il s\u2019agit ou non d\u2019un taux compos\u00e9.","type":"boolean","required":false},"shipping":{"default":true,"description":"Si ce taux de taxe s\u2019applique ou non \u00e0 l\u2019exp\u00e9dition.","type":"boolean","required":false},"order":{"description":"Indique l&rsquo;ordre dans lequel cela appara\u00eetra dans les requ\u00eates.","type":"integer","required":false},"class":{"default":"standard","description":"Classe de taxe.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/taxes"}]}},"\/wc\/v2\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"country":{"description":"Code pays ISO 3166.","type":"string","required":false},"state":{"description":"Code r\u00e9gion.","type":"string","required":false},"postcode":{"description":"Code postal.","type":"string","required":false},"city":{"description":"Nom de la ville.","type":"string","required":false},"rate":{"description":"Taux de taxe.","type":"string","required":false},"name":{"description":"Nom du taux de taxe.","type":"string","required":false},"priority":{"description":"Priorit\u00e9 de la taxe.","type":"integer","required":false},"compound":{"description":"S\u2019il s\u2019agit ou non d\u2019un taux compos\u00e9.","type":"boolean","required":false},"shipping":{"description":"Si ce taux de taxe s\u2019applique ou non \u00e0 l\u2019exp\u00e9dition.","type":"boolean","required":false},"order":{"description":"Indique l&rsquo;ordre dans lequel cela appara\u00eetra dans les requ\u00eates.","type":"integer","required":false},"class":{"description":"Classe de taxe.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v2\/taxes\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"Code pays ISO 3166.","type":"string","required":false},"state":{"description":"Code r\u00e9gion.","type":"string","required":false},"postcode":{"description":"Code postal.","type":"string","required":false},"city":{"description":"Nom de la ville.","type":"string","required":false},"rate":{"description":"Taux de taxe.","type":"string","required":false},"name":{"description":"Nom du taux de taxe.","type":"string","required":false},"priority":{"description":"Priorit\u00e9 de la taxe.","type":"integer","required":false},"compound":{"description":"S\u2019il s\u2019agit ou non d\u2019un taux compos\u00e9.","type":"boolean","required":false},"shipping":{"description":"Si ce taux de taxe s\u2019applique ou non \u00e0 l\u2019exp\u00e9dition.","type":"boolean","required":false},"order":{"description":"Indique l&rsquo;ordre dans lequel cela appara\u00eetra dans les requ\u00eates.","type":"integer","required":false},"class":{"description":"Classe de taxe.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/taxes\/batch"}]}},"\/wc\/v2\/webhooks":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","title"],"required":false},"status":{"default":"all","description":"Limiter les r\u00e9sultats aux webhooks affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["all","active","paused","disabled"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Un nom convivial pour le crochet web.","type":"string","required":false},"status":{"default":"active","description":"\u00c9tat du webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"type":"string","description":"Sujet du crochet web.","required":true},"secret":{"description":"Cl\u00e9 secr\u00e8te utilis\u00e9e pour g\u00e9n\u00e9rer un hachage du crochet web livr\u00e9 et indiqu\u00e9e dans les en-t\u00eates de requ\u00eate. Si elle n\u2019est pas fournie, elle est d\u00e9finie par d\u00e9faut sur un hachage MD5 issu de l\u2019ID\u00a0\/ identifiant de l\u2019utilisateur actuel.","type":"string","required":false},"delivery_url":{"type":"string","description":"URL de livraison du crochet web.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/webhooks"}]}},"\/wc\/v2\/webhooks\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Un nom convivial pour le crochet web.","type":"string","required":false},"status":{"description":"\u00c9tat du webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Sujet du crochet web.","type":"string","required":false},"secret":{"description":"Cl\u00e9 secr\u00e8te utilis\u00e9e pour g\u00e9n\u00e9rer un hachage du crochet web livr\u00e9 et indiqu\u00e9e dans les en-t\u00eates de requ\u00eate. Si elle n\u2019est pas fournie, elle est d\u00e9finie par d\u00e9faut sur un hachage MD5 issu de l\u2019ID\u00a0\/ identifiant de l\u2019utilisateur actuel.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v2\/webhooks\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Un nom convivial pour le crochet web.","type":"string","required":false},"status":{"description":"\u00c9tat du webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Sujet du crochet web.","type":"string","required":false},"secret":{"description":"Cl\u00e9 secr\u00e8te utilis\u00e9e pour g\u00e9n\u00e9rer un hachage du crochet web livr\u00e9 et indiqu\u00e9e dans les en-t\u00eates de requ\u00eate. Si elle n\u2019est pas fournie, elle est d\u00e9finie par d\u00e9faut sur un hachage MD5 issu de l\u2019ID\u00a0\/ identifiant de l\u2019utilisateur actuel.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/webhooks\/batch"}]}},"\/wc\/v2\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Identifiant unique pour le crochet web.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/v2\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Identifiant unique pour le crochet web.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/v2\/system_status":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/system_status"}]}},"\/wc\/v2\/system_status\/tools":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/system_status\/tools"}]}},"\/wc\/v2\/system_status\/tools\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Un identifiant unique pour l&rsquo;outil.","type":"string","required":false},"name":{"description":"Nom de l\u2019outil.","type":"string","required":false},"action":{"description":"Ce que l\u2019ex\u00e9cution de l\u2019outil va faire.","type":"string","required":false},"description":{"description":"Description de l\u2019outil.","type":"string","required":false},"success":{"description":"L\u2019outil a t-il \u00e9t\u00e9 ex\u00e9cut\u00e9 avec succ\u00e8s\u00a0?","type":"boolean","required":false},"message":{"description":"Message de retour de l&rsquo;outil.","type":"string","required":false}}}]},"\/wc\/v2\/shipping_methods":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/shipping_methods"}]}},"\/wc\/v2\/shipping_methods\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}]},"\/wc\/v2\/payment_gateways":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v2\/payment_gateways"}]}},"\/wc\/v2\/payment_gateways\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false},"title":{"description":"Titre sur la commande de la passerelle de paiement.","type":"string","required":false},"description":{"description":"Description de la passerelle de paiement \u00e0 la commande.","type":"string","required":false},"order":{"description":"Ordre de tri des passerelles de paiement.","type":"integer","required":false},"enabled":{"description":"\u00c9tat activ\u00e9 de la passerelle de paiement.","type":"boolean","required":false},"settings":{"description":"R\u00e9glages des passerelles de paiement.","type":"object","properties":{"id":{"description":"Un identifiant unique pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Une \u00e9tiquette lisible par l&rsquo;utilisateur pour le r\u00e9glage utilis\u00e9 dans les interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Une description lisible par l&rsquo;utilisateur pour le r\u00e9glage utilis\u00e9 dans les interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Type de r\u00e9glage.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Valeur de r\u00e9glage.","type":"string","context":["view","edit"]},"default":{"description":"Valeur par d\u00e9faut pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Texte d&rsquo;aide suppl\u00e9mentaire affich\u00e9 \u00e0 l&rsquo;utilisateur pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Texte substitutif \u00e0 afficher dans les champs texte.","type":"string","context":["view","edit"],"readonly":true}},"required":false}}}]},"\/wc\/v3\/coupons":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"code":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un code sp\u00e9cifique.","type":"string","required":false}}},{"methods":["POST"],"args":{"code":{"description":"Code promo.","type":"string","required":true},"amount":{"description":"Le montant de la remise. Doit toujours \u00eatre num\u00e9rique, m\u00eame si vous d\u00e9finissez un pourcentage.","type":["number","string"],"required":false},"status":{"description":"\u00c9tat du code promo. Doit toujours \u00eatre \u00e0 l\u2019\u00e9tat de brouillon, publi\u00e9 ou en cours de r\u00e9vision","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"D\u00e9termine le type de remise qui sera appliqu\u00e9.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Description du code promo.","type":"string","required":false},"date_expires":{"description":"Date d\u2019expiration du code promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"Date d\u2019expiration du code promo, format GMT.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"Si vrai, le code promo ne peut \u00eatre utilis\u00e9 qu&rsquo;individuellement. Les autres codes promo appliqu\u00e9s seront retir\u00e9s du panier.","type":"boolean","required":false},"product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo peut \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo ne peut pas \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Combien de fois le code promo peut \u00eatre utilis\u00e9.","type":"integer","required":false},"usage_limit_per_user":{"description":"Nombre de fois que le code promo peut \u00eatre utilis\u00e9 par client.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Nombre maximum d&rsquo;articles dans le panier auxquels le code promo peut \u00eatre appliqu\u00e9.","type":"integer","required":false},"free_shipping":{"default":false,"description":"Si vrai et que le mode d\u2019exp\u00e9dition gratuite n\u00e9cessite un code promo, ce code promo activera la livraison gratuite.","type":"boolean","required":false},"product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo s\u2019applique.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo ne s&rsquo;applique pas.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"Si vrai, ce code promo ne sera pas appliqu\u00e9 aux articles qui sont en promotion.","type":"boolean","required":false},"minimum_amount":{"description":"Montant minimum de commande qui doit \u00eatre dans le panier avant que le code promo ne s\u2019applique.","type":["number","string"],"required":false},"maximum_amount":{"description":"Montant maximum de commande autoris\u00e9 lors de l&rsquo;utilisation du code promo.","type":["number","string"],"required":false},"email_restrictions":{"description":"Liste des e-mails qui peuvent utiliser ce code promo.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/coupons"}]}},"\/wc\/v3\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"code":{"description":"Code promo.","type":"string","required":false},"amount":{"description":"Le montant de la remise. Doit toujours \u00eatre num\u00e9rique, m\u00eame si vous d\u00e9finissez un pourcentage.","type":["number","string"],"required":false},"status":{"description":"\u00c9tat du code promo. Doit toujours \u00eatre \u00e0 l\u2019\u00e9tat de brouillon, publi\u00e9 ou en cours de r\u00e9vision","type":"string","required":false},"discount_type":{"description":"D\u00e9termine le type de remise qui sera appliqu\u00e9.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Description du code promo.","type":"string","required":false},"date_expires":{"description":"Date d\u2019expiration du code promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"Date d\u2019expiration du code promo, format GMT.","type":["null","string"],"required":false},"individual_use":{"description":"Si vrai, le code promo ne peut \u00eatre utilis\u00e9 qu&rsquo;individuellement. Les autres codes promo appliqu\u00e9s seront retir\u00e9s du panier.","type":"boolean","required":false},"product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo peut \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo ne peut pas \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Combien de fois le code promo peut \u00eatre utilis\u00e9.","type":"integer","required":false},"usage_limit_per_user":{"description":"Nombre de fois que le code promo peut \u00eatre utilis\u00e9 par client.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Nombre maximum d&rsquo;articles dans le panier auxquels le code promo peut \u00eatre appliqu\u00e9.","type":"integer","required":false},"free_shipping":{"description":"Si vrai et que le mode d\u2019exp\u00e9dition gratuite n\u00e9cessite un code promo, ce code promo activera la livraison gratuite.","type":"boolean","required":false},"product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo s\u2019applique.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo ne s&rsquo;applique pas.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si vrai, ce code promo ne sera pas appliqu\u00e9 aux articles qui sont en promotion.","type":"boolean","required":false},"minimum_amount":{"description":"Montant minimum de commande qui doit \u00eatre dans le panier avant que le code promo ne s\u2019applique.","type":["number","string"],"required":false},"maximum_amount":{"description":"Montant maximum de commande autoris\u00e9 lors de l&rsquo;utilisation du code promo.","type":["number","string"],"required":false},"email_restrictions":{"description":"Liste des e-mails qui peuvent utiliser ce code promo.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v3\/coupons\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"Code promo.","type":"string","required":false},"amount":{"description":"Le montant de la remise. Doit toujours \u00eatre num\u00e9rique, m\u00eame si vous d\u00e9finissez un pourcentage.","type":["number","string"],"required":false},"status":{"description":"\u00c9tat du code promo. Doit toujours \u00eatre \u00e0 l\u2019\u00e9tat de brouillon, publi\u00e9 ou en cours de r\u00e9vision","type":"string","required":false},"discount_type":{"description":"D\u00e9termine le type de remise qui sera appliqu\u00e9.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Description du code promo.","type":"string","required":false},"date_expires":{"description":"Date d\u2019expiration du code promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"Date d\u2019expiration du code promo, format GMT.","type":["null","string"],"required":false},"individual_use":{"description":"Si vrai, le code promo ne peut \u00eatre utilis\u00e9 qu&rsquo;individuellement. Les autres codes promo appliqu\u00e9s seront retir\u00e9s du panier.","type":"boolean","required":false},"product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo peut \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Liste des IDs de produits pour lesquels le code promo ne peut pas \u00eatre utilis\u00e9.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Combien de fois le code promo peut \u00eatre utilis\u00e9.","type":"integer","required":false},"usage_limit_per_user":{"description":"Nombre de fois que le code promo peut \u00eatre utilis\u00e9 par client.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Nombre maximum d&rsquo;articles dans le panier auxquels le code promo peut \u00eatre appliqu\u00e9.","type":"integer","required":false},"free_shipping":{"description":"Si vrai et que le mode d\u2019exp\u00e9dition gratuite n\u00e9cessite un code promo, ce code promo activera la livraison gratuite.","type":"boolean","required":false},"product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo s\u2019applique.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Liste des IDs de cat\u00e9gories pour lesquels le code promo ne s&rsquo;applique pas.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si vrai, ce code promo ne sera pas appliqu\u00e9 aux articles qui sont en promotion.","type":"boolean","required":false},"minimum_amount":{"description":"Montant minimum de commande qui doit \u00eatre dans le panier avant que le code promo ne s\u2019applique.","type":["number","string"],"required":false},"maximum_amount":{"description":"Montant maximum de commande autoris\u00e9 lors de l&rsquo;utilisation du code promo.","type":["number","string"],"required":false},"email_restrictions":{"description":"Liste des e-mails qui peuvent utiliser ce code promo.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/coupons\/batch"}]}},"\/wc\/v3\/customers\/(?P<customer_id>[\\d]+)\/downloads":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"customer_id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}]},"\/wc\/v3\/customers":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"default":"asc","description":"Attribut de tri de commande croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Trier la collection par attribut d\u2019objet.","enum":["id","include","name","registered_date"],"type":"string","required":false},"email":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un e-mail sp\u00e9cifique.","type":"string","format":"email","required":false},"role":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un r\u00f4le sp\u00e9cifique.","type":"string","default":"customer","enum":["all","administrator","editor","author","contributor","subscriber","customer","shop_manager","responsable_region","wpseo_manager","wpseo_editor"],"required":false}}},{"methods":["POST"],"args":{"email":{"type":"string","description":"Nouvelle adresse e-mail de l&rsquo;utilisateur.","required":true},"first_name":{"description":"Pr\u00e9nom du client.","type":"string","required":false},"last_name":{"description":"Nom du client.","type":"string","required":false},"username":{"description":"Nouvel identifiant.","type":"string","required":false},"password":{"description":"Nouveau mot de passe de l&rsquo;utilisateur.","type":"string","required":false},"billing":{"description":"Liste de donn\u00e9es de l&rsquo;adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Liste des donn\u00e9es d\u2019adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/customers"}]}},"\/wc\/v3\/customers\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"email":{"description":"L\u2019e-mail pour le client.","type":"string","format":"email","required":false},"first_name":{"description":"Pr\u00e9nom du client.","type":"string","required":false},"last_name":{"description":"Nom du client.","type":"string","required":false},"username":{"description":"Nom de connexion du client.","type":"string","required":false},"password":{"description":"Mot de passe client.","type":"string","required":false},"billing":{"description":"Liste de donn\u00e9es de l&rsquo;adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Liste des donn\u00e9es d\u2019adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false},"reassign":{"default":0,"type":"integer","description":"ID \u00e0 r\u00e9assigner aux articles.","required":false}}}]},"\/wc\/v3\/customers\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"email":{"description":"L\u2019e-mail pour le client.","type":"string","format":"email","required":false},"first_name":{"description":"Pr\u00e9nom du client.","type":"string","required":false},"last_name":{"description":"Nom du client.","type":"string","required":false},"username":{"description":"Nom de connexion du client.","type":"string","required":false},"password":{"description":"Mot de passe client.","type":"string","required":false},"billing":{"description":"Liste de donn\u00e9es de l&rsquo;adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Liste des donn\u00e9es d\u2019adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code ISO du pays.","type":"string","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/customers\/batch"}]}},"\/wc\/v3\/layout-templates":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"area":{"description":"Zone pour obtenir des mod\u00e8les.","type":"string","default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/layout-templates"}]}},"\/wc\/v3\/layout-templates\/(?P<id>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/notes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"type":{"default":"any","description":"Limiter le r\u00e9sultat aux clients ou aux notes internes.","type":"string","enum":["any","customer","internal"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"note":{"type":"string","description":"Contenu de la note de commande.","required":true},"customer_note":{"default":false,"description":"Si vrai, la note sera affich\u00e9e aux clients et ils seront notifi\u00e9s. Si faux, la note sera uniquement pour l&rsquo;administration.","type":"boolean","required":false},"added_by_user":{"default":false,"description":"Si le r\u00e9sultat est \u00ab\u00a0true\u00a0\u00bb, cette note sera attribu\u00e9e \u00e0 l\u2019utilisateur actuel. Si le r\u00e9sultat est \u00ab\u00a0false\u00a0\u00bb, la note sera attribu\u00e9e au syst\u00e8me.","type":"boolean","required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/notes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/refunds":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"dp":{"default":2,"description":"Nombre de d\u00e9cimales \u00e0 utiliser dans chaque ressource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Affichez uniquement la m\u00e9ta qui est cens\u00e9e s\u2019afficher pour une commande.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"amount":{"description":"Montant du remboursement.","type":"string","required":false},"reason":{"description":"Motif du remboursement.","type":"string","required":false},"refunded_by":{"description":"ID de l\u2019utilisateur qui a cr\u00e9\u00e9 le remboursement.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de l\u2019instance d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"api_refund":{"default":true,"description":"Lorsque vrai, l\u2019API de passerelle de paiement est utilis\u00e9e pour g\u00e9n\u00e9rer le remboursement.","type":"boolean","required":false},"api_restock":{"default":true,"description":"Lorsque la valeur est Vrai, les articles rembours\u00e9s sont r\u00e9approvisionn\u00e9s.","type":"boolean","required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/refunds\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"order_id":{"description":"L\u2019ID de commande.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v3\/orders":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":"any","description":"Limiter les r\u00e9sultats aux commandes qui ont les \u00e9tats sp\u00e9cifiques.","type":"array","items":{"type":"string","enum":["any","trash","auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"]},"required":false},"customer":{"description":"Limiter le jeu de r\u00e9sultats aux commandes affect\u00e9es \u00e0 un client sp\u00e9cifique.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux commandes affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","required":false},"dp":{"default":2,"description":"Nombre de d\u00e9cimales \u00e0 utiliser dans chaque ressource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Affichez uniquement la m\u00e9ta qui est cens\u00e9e s\u2019afficher pour une commande.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"created_via":{"description":"Limiter le jeu de r\u00e9sultats aux commandes cr\u00e9\u00e9es via des sources sp\u00e9cifiques (par ex. validation de la commande, administrateur).","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"ID de commande parente.","type":"integer","required":false},"created_via":{"description":"Affiche o\u00f9 la commande a \u00e9t\u00e9 cr\u00e9\u00e9e.","type":"string","required":false},"status":{"default":"pending","description":"\u00c9tat de la commande.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"EUR","description":"Devise avec laquelle la commande a \u00e9t\u00e9 cr\u00e9\u00e9e, au format ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"ID utilisateur propri\u00e9taire de la commande. 0 pour les invit\u00e9s.","type":"integer","required":false},"customer_note":{"description":"Note laiss\u00e9e par le client lors de la commande.","type":"string","required":false},"billing":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID du moyen de paiement.","type":"string","required":false},"payment_method_title":{"description":"Titre du moyen de paiement.","type":"string","required":false},"transaction_id":{"description":"ID unique de transaction.","type":"string","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Ligne de donn\u00e9es des articles.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom du produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nom du produit parent si le produit est une variation.","type":"string","context":["view","edit"]},"product_id":{"description":"ID produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variation, si applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantit\u00e9 command\u00e9.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Classe de taxe de produit.","type":"string","context":["view","edit"]},"subtotal":{"description":"Ligne de sous-total (avant remises).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Ligne de sous-total de taxe (avant remises).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"]},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"]},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Cl\u00e9 m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]},"display_value":{"description":"Valeur de m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]}}}},"sku":{"description":"UGS du produit.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tarif du produit.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propri\u00e9t\u00e9s de l\u2019image principale du produit.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de l\u2019instance d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Ligne de donn\u00e9es des codes promo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Code promo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Remise totale.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Taxe totale de la remise.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Type de remise.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Montant de la remise telle que d\u00e9finie dans le code promo (valeur absolue ou pourcentage, en fonction du type de remise).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si le code promo donne droit \u00e0 la livraison gratuite ou non.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"default":false,"description":"D\u00e9termine si la commande est pay\u00e9e. Cela va d\u00e9finir l\u2019\u00e9tat \u00e0 en cours et r\u00e9duire de stock des articles.","type":"boolean","required":false},"manual_update":{"default":false,"description":"D\u00e9finir l\u2019action sur manuel pour que la note de commande s\u2019enregistre comme \u00ab\u00a0ajout\u00e9e par l\u2019utilisateur\u00a0\u00bb.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/orders"}]}},"\/wc\/v3\/orders\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"parent_id":{"description":"ID de commande parente.","type":"integer","required":false},"created_via":{"description":"Affiche o\u00f9 la commande a \u00e9t\u00e9 cr\u00e9\u00e9e.","type":"string","required":false},"status":{"description":"\u00c9tat de la commande.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Devise avec laquelle la commande a \u00e9t\u00e9 cr\u00e9\u00e9e, au format ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID utilisateur propri\u00e9taire de la commande. 0 pour les invit\u00e9s.","type":"integer","required":false},"customer_note":{"description":"Note laiss\u00e9e par le client lors de la commande.","type":"string","required":false},"billing":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID du moyen de paiement.","type":"string","required":false},"payment_method_title":{"description":"Titre du moyen de paiement.","type":"string","required":false},"transaction_id":{"description":"ID unique de transaction.","type":"string","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Ligne de donn\u00e9es des articles.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom du produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nom du produit parent si le produit est une variation.","type":"string","context":["view","edit"]},"product_id":{"description":"ID produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variation, si applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantit\u00e9 command\u00e9.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Classe de taxe de produit.","type":"string","context":["view","edit"]},"subtotal":{"description":"Ligne de sous-total (avant remises).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Ligne de sous-total de taxe (avant remises).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"]},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"]},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Cl\u00e9 m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]},"display_value":{"description":"Valeur de m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]}}}},"sku":{"description":"UGS du produit.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tarif du produit.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propri\u00e9t\u00e9s de l\u2019image principale du produit.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de l\u2019instance d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Ligne de donn\u00e9es des codes promo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Code promo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Remise totale.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Taxe totale de la remise.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Type de remise.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Montant de la remise telle que d\u00e9finie dans le code promo (valeur absolue ou pourcentage, en fonction du type de remise).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si le code promo donne droit \u00e0 la livraison gratuite ou non.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"D\u00e9termine si la commande est pay\u00e9e. Cela va d\u00e9finir l\u2019\u00e9tat \u00e0 en cours et r\u00e9duire de stock des articles.","type":"boolean","required":false},"manual_update":{"description":"D\u00e9finir l\u2019action sur manuel pour que la note de commande s\u2019enregistre comme \u00ab\u00a0ajout\u00e9e par l\u2019utilisateur\u00a0\u00bb.","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v3\/orders\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"ID de commande parente.","type":"integer","required":false},"created_via":{"description":"Affiche o\u00f9 la commande a \u00e9t\u00e9 cr\u00e9\u00e9e.","type":"string","required":false},"status":{"description":"\u00c9tat de la commande.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Devise avec laquelle la commande a \u00e9t\u00e9 cr\u00e9\u00e9e, au format ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID utilisateur propri\u00e9taire de la commande. 0 pour les invit\u00e9s.","type":"integer","required":false},"customer_note":{"description":"Note laiss\u00e9e par le client lors de la commande.","type":"string","required":false},"billing":{"description":"Adresse de facturation.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"E-mail.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Num\u00e9ro de t\u00e9l\u00e9phone","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Adresse de livraison.","type":"object","properties":{"first_name":{"description":"Pr\u00e9nom.","type":"string","context":["view","edit"]},"last_name":{"description":"Nom.","type":"string","context":["view","edit"]},"company":{"description":"Nom de l&rsquo;entreprise.","type":"string","context":["view","edit"]},"address_1":{"description":"Adresse ligne 1","type":"string","context":["view","edit"]},"address_2":{"description":"Adresse ligne 2","type":"string","context":["view","edit"]},"city":{"description":"Nom de la ville.","type":"string","context":["view","edit"]},"state":{"description":"Code ISO ou nom de l&rsquo;\u00e9tat, province ou quartier.","type":"string","context":["view","edit"]},"postcode":{"description":"Code postal.","type":"string","context":["view","edit"]},"country":{"description":"Code pays au format ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID du moyen de paiement.","type":"string","required":false},"payment_method_title":{"description":"Titre du moyen de paiement.","type":"string","required":false},"transaction_id":{"description":"ID unique de transaction.","type":"string","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Ligne de donn\u00e9es des articles.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom du produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nom du produit parent si le produit est une variation.","type":"string","context":["view","edit"]},"product_id":{"description":"ID produit.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variation, si applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantit\u00e9 command\u00e9.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Classe de taxe de produit.","type":"string","context":["view","edit"]},"subtotal":{"description":"Ligne de sous-total (avant remises).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Ligne de sous-total de taxe (avant remises).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"]},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"]},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Cl\u00e9 m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]},"display_value":{"description":"Valeur de m\u00e9ta pour l\u2019affichage dans l\u2019interface.","type":"string","context":["view","edit"]}}}},"sku":{"description":"UGS du produit.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tarif du produit.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propri\u00e9t\u00e9s de l\u2019image principale du produit.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Lignes de donn\u00e9es de livraison.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nom du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de l\u2019instance d\u2019exp\u00e9dition.","type":"string","context":["view","edit"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Lignes de donn\u00e9es des frais.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nom des frais.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Classe de taxe de frais.","type":"string","context":["view","edit"]},"tax_status":{"description":"\u00c9tat de la taxe des frais.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Ligne de total (apr\u00e8s remises).","type":"string","context":["view","edit"]},"total_tax":{"description":"Ligne de total de taxe (apr\u00e8s remises).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Ligne de taxe.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID du taux de taxe.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de la taxe.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Sous-total de la taxe.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Ligne de donn\u00e9es des codes promo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l&rsquo;article.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Code promo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Remise totale.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Taxe totale de la remise.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Type de remise.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Montant de la remise telle que d\u00e9finie dans le code promo (valeur absolue ou pourcentage, en fonction du type de remise).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si le code promo donne droit \u00e0 la livraison gratuite ou non.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"D\u00e9termine si la commande est pay\u00e9e. Cela va d\u00e9finir l\u2019\u00e9tat \u00e0 en cours et r\u00e9duire de stock des articles.","type":"boolean","required":false},"manual_update":{"description":"D\u00e9finir l\u2019action sur manuel pour que la note de commande s\u2019enregistre comme \u00ab\u00a0ajout\u00e9e par l\u2019utilisateur\u00a0\u00bb.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/orders\/batch"}]}},"\/wc\/v3\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}}]},"\/wc\/v3\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"name":{"description":"Nom du terme.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v3\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Identifiant unique pour l\u2019attribut des termes.","type":"integer","required":false},"name":{"description":"Nom du terme.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 de la ressource.","type":"integer","required":false}}}]},"\/wc\/v3\/products\/attributes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nom pour la ressource.","type":"string","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"type":{"default":"select","description":"Type d&rsquo;attribut.","type":"string","enum":["select"],"required":false},"order_by":{"default":"menu_order","description":"Tri par d\u00e9faut.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Activer\/d\u00e9sactiver les archives d&rsquo;attribut.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/attributes"}]}},"\/wc\/v3\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de l\u2019attribut.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"type":{"description":"Type d&rsquo;attribut.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Tri par d\u00e9faut.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activer\/d\u00e9sactiver les archives d&rsquo;attribut.","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v3\/products\/attributes\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom de l\u2019attribut.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"type":{"description":"Type d&rsquo;attribut.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Tri par d\u00e9faut.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activer\/d\u00e9sactiver les archives d&rsquo;attribut.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/attributes\/batch"}]}},"\/wc\/v3\/products\/categories":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"default":"default","description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/categories"}]}},"\/wc\/v3\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v3\/products\/categories\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la ressource.","type":"integer","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false},"display":{"description":"Type d&rsquo;affichage de l&rsquo;archive de cat\u00e9gorie.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Donn\u00e9es d\u2019image.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/categories\/batch"}]}},"\/wc\/v3\/products\/custom-fields\/names":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"order":{"description":"Triez les articles par ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/custom-fields\/names"}]}},"\/wc\/v3\/products\/reviews":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitez les r\u00e9ponses aux avis publi\u00e9s avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","product"],"required":false},"reviewer":{"description":"Limite le jeu de r\u00e9sultats aux avis assign\u00e9s \u00e0 des ID d\u2019utilisateurs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"reviewer_exclude":{"description":"V\u00e9rifiez que le jeu de r\u00e9sultats exclut les avis assign\u00e9s \u00e0 des ID d\u2019utilisateurs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"reviewer_email":{"default":null,"description":"Limiter le jeu de r\u00e9sultats \u00e0 une adresse e-mail d\u2019auteur sp\u00e9cifique.","format":"email","type":"string","required":false},"product":{"default":[],"description":"Limite le jeu de r\u00e9sultats aux avis assign\u00e9s \u00e0 des ID de produits sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approved","description":"Limiter le jeu de r\u00e9sultats aux avis affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["all","hold","approved","spam","trash"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"ID unique pour le produit.","type":"integer","required":true},"product_name":{"description":"Nom du produit.","type":"string","required":false},"status":{"default":"approved","description":"\u00c9tat de l\u2019avis.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"type":"string","description":"Nom de l&rsquo;\u00e9valuateur.","required":true},"reviewer_email":{"type":"string","description":"E-mail de l&rsquo;\u00e9valuateur.","required":true},"review":{"type":"string","description":"Contenu de l\u2019avis.","required":true},"rating":{"description":"Note de l\u2019avis (0 \u00e0 5).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/reviews"}]}},"\/wc\/v3\/products\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"product_id":{"description":"ID unique du produit auquel l\u2019avis se r\u00e9f\u00e8re.","type":"integer","required":false},"product_name":{"description":"Nom du produit.","type":"string","required":false},"status":{"description":"\u00c9tat de l\u2019avis.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Nom de l&rsquo;\u00e9valuateur.","type":"string","required":false},"reviewer_email":{"description":"Email de l&rsquo;\u00e9valuateur.","type":"string","format":"email","required":false},"review":{"description":"Le contenu de l&rsquo;avis.","type":"string","required":false},"rating":{"description":"Note de l\u2019avis (0 \u00e0 5).","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v3\/products\/reviews\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"ID unique du produit auquel l\u2019avis se r\u00e9f\u00e8re.","type":"integer","required":false},"product_name":{"description":"Nom du produit.","type":"string","required":false},"status":{"description":"\u00c9tat de l\u2019avis.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Nom de l&rsquo;\u00e9valuateur.","type":"string","required":false},"reviewer_email":{"description":"Email de l&rsquo;\u00e9valuateur.","type":"string","format":"email","required":false},"review":{"description":"Le contenu de l&rsquo;avis.","type":"string","required":false},"rating":{"description":"Note de l\u2019avis (0 \u00e0 5).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/reviews\/batch"}]}},"\/wc\/v3\/products\/shipping_classes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/shipping_classes"}]}},"\/wc\/v3\/products\/shipping_classes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v3\/products\/shipping_classes\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/shipping_classes\/batch"}]}},"\/wc\/v3\/products\/shipping_classes\/slug-suggestion":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nom de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/shipping_classes\/slug-suggestion"}]}},"\/wc\/v3\/products\/tags":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d\u2019articles. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de ressource.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"S&rsquo;il faut masquer les ressources affect\u00e9es \u00e0 aucun produit.","type":"boolean","default":false,"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un parent sp\u00e9cifique. S\u2019applique uniquement aux taxonomies hi\u00e9rarchiques.","type":"integer","required":false},"product":{"description":"Limiter le jeu de r\u00e9sultats aux ressources affect\u00e9es \u00e0 un produit sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux ressources avec un identifiant sp\u00e9cifique.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom pour la ressource.","required":true},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/tags"}]}},"\/wc\/v3\/products\/tags\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v3\/products\/tags\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","required":false},"slug":{"description":"Un identifiant alphanum\u00e9rique pour la ressource unique en son genre.","type":"string","required":false},"description":{"description":"Description HTML de la ressource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/tags\/batch"}]}},"\/wc\/v3\/products":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order","price","popularity","rating"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de marque sp\u00e9cifique.","type":"string","required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un identifiant sp\u00e9cifique.","type":"string","required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un type sp\u00e9cifique.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"featured":{"description":"Limiter le jeu de r\u00e9sultats aux produits mis en avant.","type":"boolean","required":false},"category":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de cat\u00e9gorie sp\u00e9cifique.","type":"string","required":false},"tag":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID d\u2019\u00e9tiquette sp\u00e9cifique.","type":"string","required":false},"shipping_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de classe d\u2019exp\u00e9dition sp\u00e9cifique.","type":"string","required":false},"attribute":{"description":"Limiter les r\u00e9sultats aux produits avec un attribut sp\u00e9cifique. Utiliser le nom de la taxonomie \/ le slug de l\u2019attribut.","type":"string","required":false},"attribute_term":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un ID de terme d&rsquo;attribut sp\u00e9cifique (attribut affect\u00e9 requis).","type":"string","required":false},"tax_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec une classe de taxe sp\u00e9cifique.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif minimum.","type":"string","required":false},"max_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif maximum.","type":"string","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec l\u2019\u00e9tat du stock sp\u00e9cifi\u00e9.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"search_sku":{"description":"Limiter les r\u00e9sultats \u00e0 ceux avec une UGS qui correspond partiellement \u00e0 une cha\u00eene. Cet argument pr\u00e9vaut sur \u00ab\u00a0sku\u00a0\u00bb.","type":"string","required":false},"search_name_or_sku":{"description":"Limiter les r\u00e9sultats \u00e0 ceux avec un nom ou une UGS qui correspond partiellement \u00e0 une cha\u00eene. Cet argument pr\u00e9vaut sur \u00ab\u00a0search\u00a0\u00bb, \u00ab\u00a0sku\u00a0\u00bb et \u00ab\u00a0search_sku\u00a0\u00bb.","type":"string","required":false},"search_fields":{"description":"Limiter la recherche \u00e0 des champs sp\u00e9cifiques si utilis\u00e9 avec le param\u00e8tre de recherche. Champs disponibles\u00a0: UGS, global_unique_id, description, short_description. Cet argument prend pr\u00e9vaut sur les autres param\u00e8tres de recherche.","type":"array","items":{"type":"string","enum":["name","global_unique_id","description","short_description","sku"]},"default":[],"required":false},"include_status":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec n\u2019importe quel \u00e9tat.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Excluez les produits avec n\u2019importe quel \u00e9tat du jeu de r\u00e9sultats.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"include_types":{"description":"Limitez le jeu de r\u00e9sultats aux produits de n\u2019importe quel type.","type":"array","items":{"type":"string","enum":["simple","grouped","external","variable"]},"required":false},"exclude_types":{"description":"Excluez les produits de n\u2019importe quel type du jeu de r\u00e9sultats.","type":"array","items":{"type":"string","enum":["simple","grouped","external","variable"]},"required":false},"downloadable":{"description":"Limitez le jeu de r\u00e9sultats aux produits t\u00e9l\u00e9chargeables.","type":"boolean","required":false},"virtual":{"description":"Limitez le jeu de r\u00e9sultats aux produits virtuels.","type":"boolean","required":false},"pos_products_only":{"description":"Limiter les r\u00e9sultats aux produits visibles sur le point de vente.","type":"boolean","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"date_created":{"description":"La date \u00e0 laquelle le produit a \u00e9t\u00e9 cr\u00e9\u00e9, en fuseau horaire du site.","type":["null","string"],"required":false},"date_created_gmt":{"description":"Date de cr\u00e9ation du produit, format GMT.","type":["null","string"],"required":false},"type":{"default":"simple","description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"default":"publish","description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"default":false,"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"virtual":{"default":false,"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"default":"taxable","description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour le produit.","type":["integer","null"],"required":false},"sold_individually":{"default":false,"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Autoriser les avis.","type":"boolean","required":false},"post_password":{"description":"Mot de passe de l\u2019article","type":"string","required":false},"upsell_ids":{"description":"Liste des IDs des produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Liste des marques.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la marque.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la marque.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de la marque.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products"}]}},"\/wc\/v3\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"date_created":{"description":"La date \u00e0 laquelle le produit a \u00e9t\u00e9 cr\u00e9\u00e9, en fuseau horaire du site.","type":["null","string"],"required":false},"date_created_gmt":{"description":"Date de cr\u00e9ation du produit, format GMT.","type":["null","string"],"required":false},"type":{"description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"virtual":{"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour le produit.","type":["integer","null"],"required":false},"sold_individually":{"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"description":"Autoriser les avis.","type":"boolean","required":false},"post_password":{"description":"Mot de passe de l\u2019article","type":"string","required":false},"upsell_ids":{"description":"Liste des IDs des produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Liste des marques.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la marque.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la marque.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de la marque.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","type":"boolean","required":false}}}]},"\/wc\/v3\/products\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"date_created":{"description":"La date \u00e0 laquelle le produit a \u00e9t\u00e9 cr\u00e9\u00e9, en fuseau horaire du site.","type":["null","string"],"required":false},"date_created_gmt":{"description":"Date de cr\u00e9ation du produit, format GMT.","type":["null","string"],"required":false},"type":{"description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"virtual":{"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour le produit.","type":["integer","null"],"required":false},"sold_individually":{"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"description":"Autoriser les avis.","type":"boolean","required":false},"post_password":{"description":"Mot de passe de l\u2019article","type":"string","required":false},"upsell_ids":{"description":"Liste des IDs des produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Liste des marques.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la marque.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la marque.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de la marque.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/batch"}]}},"\/wc\/v3\/products\/(?P<id>[\\d]+)\/related":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false}}}]},"\/wc\/v3\/products\/suggested-products":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de marque sp\u00e9cifique.","type":"string","required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un identifiant sp\u00e9cifique.","type":"string","required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un type sp\u00e9cifique.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"featured":{"description":"Limiter le jeu de r\u00e9sultats aux produits mis en avant.","type":"boolean","required":false},"category":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de cat\u00e9gorie sp\u00e9cifique.","type":"string","required":false},"tag":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID d\u2019\u00e9tiquette sp\u00e9cifique.","type":"string","required":false},"shipping_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de classe d\u2019exp\u00e9dition sp\u00e9cifique.","type":"string","required":false},"attribute":{"description":"Limiter les r\u00e9sultats aux produits avec un attribut sp\u00e9cifique. Utiliser le nom de la taxonomie \/ le slug de l\u2019attribut.","type":"string","required":false},"attribute_term":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un ID de terme d&rsquo;attribut sp\u00e9cifique (attribut affect\u00e9 requis).","type":"string","required":false},"tax_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec une classe de taxe sp\u00e9cifique.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"in_stock":{"description":"Limiter le jeu de r\u00e9sultats aux produits en stock ou en rupture de stock.","type":"boolean","required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif minimum.","type":"string","required":false},"max_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif maximum.","type":"string","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 des ID sp\u00e9cifiques de cat\u00e9gorie de produits.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 des ID sp\u00e9cifiques d\u2019\u00e9tiquette produit.","type":"array","items":{"type":"integer"},"default":[],"required":false},"limit":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 une quantit\u00e9 sp\u00e9cifique de produits sugg\u00e9r\u00e9s.","type":"integer","default":5,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/products\/suggested-products"}]}},"\/wc\/v3\/products\/(?P<id>[\\d]+)\/duplicate":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom du produit.","type":"string","required":false},"slug":{"description":"Identifiant du produit.","type":"string","required":false},"date_created":{"description":"La date \u00e0 laquelle le produit a \u00e9t\u00e9 cr\u00e9\u00e9, en fuseau horaire du site.","type":["null","string"],"required":false},"date_created_gmt":{"description":"Date de cr\u00e9ation du produit, format GMT.","type":["null","string"],"required":false},"type":{"description":"Type de produit.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"\u00c9tat du produit (\u00e9tat de l&rsquo;article).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Produit en avant.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilit\u00e9 du catalogue.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Description du produit.","type":"string","required":false},"short_description":{"description":"Description courte du produit.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier du produit.","type":"string","required":false},"sale_price":{"description":"Tarif de promotion.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"virtual":{"description":"Si le produit est virtuel.","type":"boolean","required":false},"downloadable":{"description":"Si le produit est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"external_url":{"description":"URL du produit externe. Uniquement pour les produits externes.","type":"string","format":"uri","required":false},"button_text":{"description":"Texte du bouton du produit externe. Uniquement pour les produits externes.","type":"string","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion du stock au niveau produit.","type":"boolean","required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour le produit.","type":["integer","null"],"required":false},"sold_individually":{"description":"Ne permettre l&rsquo;achat que d&rsquo;un article dans une commande.","type":"boolean","required":false},"weight":{"description":"Poids du produit (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions du produit.","type":"object","properties":{"length":{"description":"Longueur du produit (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur du produit (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur du produit (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"reviews_allowed":{"description":"Autoriser les avis.","type":"boolean","required":false},"post_password":{"description":"Mot de passe de l\u2019article","type":"string","required":false},"upsell_ids":{"description":"Liste des IDs des produits de mont\u00e9e en gamme.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Liste des IDs de produits de vente crois\u00e9e.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID du parent du produit.","type":"integer","required":false},"purchase_note":{"description":"Note facultative \u00e0 envoyer au client apr\u00e8s l\u2019achat.","type":"string","required":false},"categories":{"description":"\ufeffListe de cat\u00e9gories.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de cat\u00e9gorie.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant de la cat\u00e9gorie.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Liste des marques.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la marque.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de la marque.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de la marque.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Liste des \u00e9tiquettes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019\u00e9tiquette.","type":"integer","context":["view","edit"]},"name":{"description":"Nom d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Identifiant d&rsquo;\u00e9tiquette.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Liste d\u2019images.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"position":{"description":"Position de l&rsquo;attribut.","type":"integer","context":["view","edit"]},"visible":{"description":"D\u00e9termine si l\u2019attribut est visible dans l\u2019onglet \u00ab\u00a0Informations compl\u00e9mentaires\u00a0\u00bb dans la page produit.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"D\u00e9termine su l&rsquo;attribut peut \u00eatre utilis\u00e9 comme variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Liste des noms de terme disponibles de l&rsquo;attribut.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Attributs de variation par d\u00e9faut.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un identifiant sp\u00e9cifique.","type":"string","required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"tax_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec une classe de taxe sp\u00e9cifique.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif minimum.","type":"string","required":false},"max_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif maximum.","type":"string","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec l\u2019\u00e9tat du stock sp\u00e9cifi\u00e9.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limitez les r\u00e9sultats aux produits avec ou sans prix.","type":"boolean","required":false},"attributes":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec des attributs sp\u00e9cifiques.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Identifiant de l&rsquo;attribut."},"term":{"type":"string","description":"Terme d\u2019attribut."},"terms":{"type":"array","description":"Termes d\u2019attribut."}}},"required":false},"virtual":{"description":"Limitez le jeu de r\u00e9sultats aux variantes de produits virtuels.","type":"boolean","required":false},"downloadable":{"description":"Limitez le jeu de r\u00e9sultats aux variantes de produits t\u00e9l\u00e9chargeables.","type":"boolean","required":false},"include_status":{"description":"Limitez le jeu de r\u00e9sultats aux variantes de produit avec n\u2019importe quel \u00e9tat.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Excluez les variantes de produit avec n\u2019importe quel \u00e9tat du jeu de r\u00e9sultats.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limiter les r\u00e9sultats aux variantes visibles sur le point de vente.","type":"boolean","required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"description":{"description":"Description de la variation.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","required":false},"sale_price":{"description":"Tarif promo de la variation.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"status":{"default":"publish","description":"\u00c9tat de la variation.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"Si la variation est virtuelle.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gestion des stocks au niveau des variations.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour la variation.","type":["integer","null"],"required":false},"weight":{"description":"Poids de la variation (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions de la variation.","type":"object","properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la variation.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la variation.","type":"integer","required":false},"description":{"description":"Description de la variation.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","required":false},"sale_price":{"description":"Tarif promo de la variation.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"status":{"description":"\u00c9tat de la variation.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"Si la variation est virtuelle.","type":"boolean","required":false},"downloadable":{"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion des stocks au niveau des variations.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour la variation.","type":["integer","null"],"required":false},"weight":{"description":"Poids de la variation (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions de la variation.","type":"object","properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la variation.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"description":{"description":"Description de la variation.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","required":false},"sale_price":{"description":"Tarif promo de la variation.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"status":{"description":"\u00c9tat de la variation.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"Si la variation est virtuelle.","type":"boolean","required":false},"downloadable":{"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"tax_status":{"description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"description":"Gestion des stocks au niveau des variations.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour la variation.","type":["integer","null"],"required":false},"weight":{"description":"Poids de la variation (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions de la variation.","type":"object","properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations\/generate":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_id":{"description":"Identifiant unique pour le produit variable.","type":"integer","required":false},"delete":{"description":"Supprime les variations non utilis\u00e9es.","type":"boolean","required":false},"default_values":{"description":"Valeurs par d\u00e9faut pour les variations g\u00e9n\u00e9r\u00e9es.","type":"object","properties":{"description":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Description de la variation.","type":"string"},"sku":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Unit\u00e9 de Gestion de Stock.","type":"string"},"global_unique_id":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"GTIN, UPC, EAN ou ISBN.","type":"string"},"regular_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Tarif r\u00e9gulier de la variation.","type":"string"},"sale_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Tarif promo de la variation.","type":"string"},"date_on_sale_from":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"]},"date_on_sale_from_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"]},"date_on_sale_to":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"]},"date_on_sale_to_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"]},"status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"\u00c9tat de la variation.","type":"string","enum":["draft","pending","private","publish"]},"virtual":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Si la variation est virtuelle.","type":"boolean"},"downloadable":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean"},"downloads":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}}},"download_limit":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer"},"download_expiry":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer"},"tax_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"]},"tax_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Classe de taxe.","type":"string"},"manage_stock":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Gestion des stocks au niveau des variations.","type":["boolean","string"]},"stock_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Quantit\u00e9 en stock.","type":"integer"},"stock_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"]},"backorders":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"]},"low_stock_amount":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Faible quantit\u00e9 de stock pour la variation.","type":["integer","null"]},"weight":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Poids de la variation (kg).","type":"string"},"dimensions":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Dimensions de la variation.","type":"object","properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}}},"shipping_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string"},"image":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Donn\u00e9es d\u2019image de variation.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}}},"attributes":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}}},"menu_order":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer"},"meta_data":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}},"required":false},"description":{"description":"Description de la variation.","type":"string","required":false},"sku":{"description":"Unit\u00e9 de Gestion de Stock.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN ou ISBN.","type":"string","required":false},"regular_price":{"description":"Tarif r\u00e9gulier de la variation.","type":"string","required":false},"sale_price":{"description":"Tarif promo de la variation.","type":"string","required":false},"date_on_sale_from":{"description":"Date de d\u00e9but du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Date de d\u00e9but du prix promo, format GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Date de fin du prix promo, fuseau horaire du site.","type":["null","string"],"required":false},"status":{"default":"publish","description":"\u00c9tat de la variation.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"Si la variation est virtuelle.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si la variation est t\u00e9l\u00e9chargeable.","type":"boolean","required":false},"downloads":{"description":"Liste de fichiers t\u00e9l\u00e9chargeables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID du fichier.","type":"string","context":["view","edit"]},"name":{"description":"Nom du fichier.","type":"string","context":["view","edit"]},"file":{"description":"URL du fichier.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Nombre de fois que les fichiers t\u00e9l\u00e9chargeables peuvent \u00eatre t\u00e9l\u00e9charg\u00e9s apr\u00e8s l&rsquo;achat.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Nombre de jours jusqu&rsquo;\u00e0 l&rsquo;expiration des acc\u00e8s aux fichiers t\u00e9l\u00e9chargeables.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"\u00c9tat de la TVA.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Classe de taxe.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gestion des stocks au niveau des variations.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Quantit\u00e9 en stock.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Contr\u00f4le l\u2019\u00e9tat du stock du produit.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Si vous g\u00e9rez le stock, cela d\u00e9termine si les commandes en r\u00e9assort sont autoris\u00e9es.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Faible quantit\u00e9 de stock pour la variation.","type":["integer","null"],"required":false},"weight":{"description":"Poids de la variation (kg).","type":"string","required":false},"dimensions":{"description":"Dimensions de la variation.","type":"object","properties":{"length":{"description":"Longueur de la variation (cm).","type":"string","context":["view","edit"]},"width":{"description":"Largeur de la variation (cm).","type":"string","context":["view","edit"]},"height":{"description":"Hauteur de la variation (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Identifiant de la classe d\u2019exp\u00e9dition.","type":"string","required":false},"image":{"description":"Donn\u00e9es d\u2019image de variation.","type":"object","properties":{"id":{"description":"ID de l\u2019image.","type":"integer","context":["view","edit"]},"date_created":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 cr\u00e9\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"Date de cr\u00e9ation de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La date \u00e0 laquelle l\u2019image a \u00e9t\u00e9 modifi\u00e9e, en fuseau horaire du site.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"Date de la derni\u00e8re modification de l\u2019image, format GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de l\u2019image.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nom de l\u2019image.","type":"string","context":["view","edit"]},"alt":{"description":"Texte alternatif de l\u2019image.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Liste d&rsquo;attributs.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de l\u2019attribut.","type":"integer","context":["view","edit"]},"name":{"description":"Nom de l\u2019attribut.","type":"string","context":["view","edit"]},"option":{"description":"Nom de terme d&rsquo;attribut s\u00e9lectionn\u00e9.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Ordre du menu, utilis\u00e9 pour le tri personnalis\u00e9 des produits.","type":"integer","required":false},"meta_data":{"description":"M\u00e9tadonn\u00e9es.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID m\u00e9ta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Cl\u00e9 de la m\u00e9ta.","type":"string","context":["view","edit"]},"value":{"description":"Valeur de la m\u00e9ta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc\/v3\/refunds":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"dp":{"default":2,"description":"Nombre de d\u00e9cimales \u00e0 utiliser dans chaque ressource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Affichez uniquement la m\u00e9ta qui est cens\u00e9e s\u2019afficher pour une commande.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/refunds"}]}},"\/wc\/v3\/reports\/sales":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"P\u00e9riode du rapport.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Retourne les ventes pour une date de d\u00e9but sp\u00e9cifique, la date doit \u00eatre dans le format YYYY-MM-DD.","type":"string","format":"date","required":false},"date_max":{"description":"Retourne les ventes pour une date de fin sp\u00e9cifique, la date doit \u00eatre dans le format YYYY-MM-DD.","type":"string","format":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/reports\/sales"}]}},"\/wc\/v3\/reports\/top_sellers":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"P\u00e9riode du rapport.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Retourne les ventes pour une date de d\u00e9but sp\u00e9cifique, la date doit \u00eatre dans le format YYYY-MM-DD.","type":"string","format":"date","required":false},"date_max":{"description":"Retourne les ventes pour une date de fin sp\u00e9cifique, la date doit \u00eatre dans le format YYYY-MM-DD.","type":"string","format":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/reports\/top_sellers"}]}},"\/wc\/v3\/reports\/orders\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/reports\/orders\/totals"}]}},"\/wc\/v3\/reports\/products\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/reports\/products\/totals"}]}},"\/wc\/v3\/reports\/customers\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/reports\/customers\/totals"}]}},"\/wc\/v3\/reports\/coupons\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/reports\/coupons\/totals"}]}},"\/wc\/v3\/reports\/reviews\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/reports\/reviews\/totals"}]}},"\/wc\/v3\/reports":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/reports"}]}},"\/wc\/v3\/settings":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/settings"}]}},"\/wc\/v3\/settings\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/settings\/batch"}]}},"\/wc\/v3\/settings\/(?P<group_id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"ID de groupe de r\u00e9glages.","type":"string","required":false}}}]},"\/wc\/v3\/settings\/(?P<group_id>[\\w-]+)\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"ID de groupe de r\u00e9glages.","type":"string","required":false},"value":{"description":"Valeur de r\u00e9glage.","type":["null","object","string","number","boolean","integer","array"],"required":false}}}]},"\/wc\/v3\/settings\/(?P<group_id>[\\w-]+)\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"ID de groupe de r\u00e9glages.","type":"string","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"ID de groupe de r\u00e9glages.","type":"string","required":false},"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false},"value":{"description":"Valeur de r\u00e9glage.","type":["null","object","string","number","boolean","integer","array"],"required":false}}}]},"\/wc\/v3\/shipping\/zones":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nom de la zone de livraison.","required":true},"order":{"description":"Ordre de la zone d\u2019exp\u00e9dition.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/shipping\/zones"}]}},"\/wc\/v3\/shipping\/zones\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID unique pour la ressource.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID unique pour la ressource.","type":"integer","required":false},"name":{"description":"Nom de la zone de livraison.","type":"string","required":false},"order":{"description":"Ordre de la zone d\u2019exp\u00e9dition.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"ID unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v3\/shipping\/zones\/(?P<id>[\\d]+)\/locations":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID unique pour la ressource.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID unique pour la ressource.","type":"integer","required":false},"code":{"description":"Code de localisation du mode d\u2019exp\u00e9dition.","type":"string","required":false},"type":{"description":"Type de localisation du mode d\u2019exp\u00e9dition.","type":"string","enum":["postcode","state","country","continent"],"required":false}}}]},"\/wc\/v3\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"ID unique pour la zone.","type":"integer","required":false}}},{"methods":["POST"],"args":{"zone_id":{"description":"ID unique pour la zone.","type":"integer","required":false},"order":{"description":"Ordre de tri du mode d\u2019exp\u00e9dition.","type":"integer","required":false},"enabled":{"description":"Statut activ\u00e9 du mode d\u2019exp\u00e9dition.","type":"boolean","required":false},"settings":{"description":"R\u00e9glages du mode d\u2019exp\u00e9dition.","type":"object","properties":{"id":{"description":"Un identifiant unique pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Une \u00e9tiquette lisible par l&rsquo;utilisateur pour le r\u00e9glage utilis\u00e9 dans les interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Une description lisible par l&rsquo;utilisateur pour le r\u00e9glage utilis\u00e9 dans les interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Type de r\u00e9glage.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox","class","order"],"readonly":true},"value":{"description":"Valeur de r\u00e9glage.","type":"string","context":["view","edit"]},"default":{"description":"Valeur par d\u00e9faut pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Texte d&rsquo;aide suppl\u00e9mentaire affich\u00e9 \u00e0 l&rsquo;utilisateur pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Texte substitutif \u00e0 afficher dans les champs texte.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"method_id":{"description":"ID du mode d\u2019exp\u00e9dition.","required":true}}}]},"\/wc\/v3\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods\/(?P<instance_id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"ID unique pour la zone.","type":"integer","required":false},"instance_id":{"description":"ID unique pour l\u2019instance.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"zone_id":{"description":"ID unique pour la zone.","type":"integer","required":false},"instance_id":{"description":"ID unique pour l\u2019instance.","type":"integer","required":false},"order":{"description":"Ordre de tri du mode d\u2019exp\u00e9dition.","type":"integer","required":false},"enabled":{"description":"Statut activ\u00e9 du mode d\u2019exp\u00e9dition.","type":"boolean","required":false},"settings":{"description":"R\u00e9glages du mode d\u2019exp\u00e9dition.","type":"object","properties":{"id":{"description":"Un identifiant unique pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Une \u00e9tiquette lisible par l&rsquo;utilisateur pour le r\u00e9glage utilis\u00e9 dans les interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Une description lisible par l&rsquo;utilisateur pour le r\u00e9glage utilis\u00e9 dans les interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Type de r\u00e9glage.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox","class","order"],"readonly":true},"value":{"description":"Valeur de r\u00e9glage.","type":"string","context":["view","edit"]},"default":{"description":"Valeur par d\u00e9faut pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Texte d&rsquo;aide suppl\u00e9mentaire affich\u00e9 \u00e0 l&rsquo;utilisateur pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Texte substitutif \u00e0 afficher dans les champs texte.","type":"string","context":["view","edit"],"readonly":true}},"required":false}}},{"methods":["DELETE"],"args":{"zone_id":{"description":"ID unique pour la zone.","type":"integer","required":false},"instance_id":{"description":"ID unique pour l\u2019instance.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si la corbeille doit \u00eatre contourn\u00e9e et la suppression forc\u00e9e.","required":false}}}]},"\/wc\/v3\/taxes\/classes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nom de la classe de taxe.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/taxes\/classes"}]}},"\/wc\/v3\/taxes\/classes\/(?P<slug>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v3","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Slug unique pour la ressource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"slug":{"description":"Slug unique pour la ressource.","type":"string","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v3\/taxes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"default":"asc","description":"Attribut de tri de commande croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"Trier la collection par attribut d\u2019objet.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"Trier par classe de taxe.","enum":["standard","taux-reduit","taux-zero"],"type":"string","required":false}}},{"methods":["POST"],"args":{"country":{"description":"Code pays ISO 3166.","type":"string","required":false},"state":{"description":"Code r\u00e9gion.","type":"string","required":false},"postcode":{"description":"Code postal \/ ZIP, il ne permet pas plusieurs valeurs. D\u00e9pr\u00e9ci\u00e9 depuis WooCommerce 5.3, \u00ab\u00a0code postaux\u00a0\u00bb devrait \u00eatre utilis\u00e9 \u00e0 la place.","type":"string","required":false},"city":{"description":"Nom de la ville, il ne permet pas plusieurs valeurs. D\u00e9pr\u00e9ci\u00e9 depuis WooCommerce 5.3, \u00ab\u00a0villes\u00a0\u00bb devrait \u00eatre utilis\u00e9 \u00e0 la place.","type":"string","required":false},"rate":{"description":"Taux de taxe.","type":"string","required":false},"name":{"description":"Nom du taux de taxe.","type":"string","required":false},"priority":{"default":1,"description":"Priorit\u00e9 de la taxe.","type":"integer","required":false},"compound":{"default":false,"description":"S\u2019il s\u2019agit ou non d\u2019un taux compos\u00e9.","type":"boolean","required":false},"shipping":{"default":true,"description":"Si ce taux de taxe s\u2019applique ou non \u00e0 l\u2019exp\u00e9dition.","type":"boolean","required":false},"order":{"description":"Indique l&rsquo;ordre dans lequel cela appara\u00eetra dans les requ\u00eates.","type":"integer","required":false},"class":{"default":"standard","description":"Classe de taxe.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"postcodes":{"description":"Liste des codes postaux \/ ZIP. Ajout\u00e9e avec WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Liste des noms de villes. Introduit par WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/taxes"}]}},"\/wc\/v3\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"country":{"description":"Code pays ISO 3166.","type":"string","required":false},"state":{"description":"Code r\u00e9gion.","type":"string","required":false},"postcode":{"description":"Code postal \/ ZIP, il ne permet pas plusieurs valeurs. D\u00e9pr\u00e9ci\u00e9 depuis WooCommerce 5.3, \u00ab\u00a0code postaux\u00a0\u00bb devrait \u00eatre utilis\u00e9 \u00e0 la place.","type":"string","required":false},"city":{"description":"Nom de la ville, il ne permet pas plusieurs valeurs. D\u00e9pr\u00e9ci\u00e9 depuis WooCommerce 5.3, \u00ab\u00a0villes\u00a0\u00bb devrait \u00eatre utilis\u00e9 \u00e0 la place.","type":"string","required":false},"rate":{"description":"Taux de taxe.","type":"string","required":false},"name":{"description":"Nom du taux de taxe.","type":"string","required":false},"priority":{"description":"Priorit\u00e9 de la taxe.","type":"integer","required":false},"compound":{"description":"S\u2019il s\u2019agit ou non d\u2019un taux compos\u00e9.","type":"boolean","required":false},"shipping":{"description":"Si ce taux de taxe s\u2019applique ou non \u00e0 l\u2019exp\u00e9dition.","type":"boolean","required":false},"order":{"description":"Indique l&rsquo;ordre dans lequel cela appara\u00eetra dans les requ\u00eates.","type":"integer","required":false},"class":{"description":"Classe de taxe.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"postcodes":{"description":"Liste des codes postaux \/ ZIP. Ajout\u00e9e avec WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Liste des noms de villes. Introduit par WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v3\/taxes\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"Code pays ISO 3166.","type":"string","required":false},"state":{"description":"Code r\u00e9gion.","type":"string","required":false},"postcode":{"description":"Code postal \/ ZIP, il ne permet pas plusieurs valeurs. D\u00e9pr\u00e9ci\u00e9 depuis WooCommerce 5.3, \u00ab\u00a0code postaux\u00a0\u00bb devrait \u00eatre utilis\u00e9 \u00e0 la place.","type":"string","required":false},"city":{"description":"Nom de la ville, il ne permet pas plusieurs valeurs. D\u00e9pr\u00e9ci\u00e9 depuis WooCommerce 5.3, \u00ab\u00a0villes\u00a0\u00bb devrait \u00eatre utilis\u00e9 \u00e0 la place.","type":"string","required":false},"rate":{"description":"Taux de taxe.","type":"string","required":false},"name":{"description":"Nom du taux de taxe.","type":"string","required":false},"priority":{"description":"Priorit\u00e9 de la taxe.","type":"integer","required":false},"compound":{"description":"S\u2019il s\u2019agit ou non d\u2019un taux compos\u00e9.","type":"boolean","required":false},"shipping":{"description":"Si ce taux de taxe s\u2019applique ou non \u00e0 l\u2019exp\u00e9dition.","type":"boolean","required":false},"order":{"description":"Indique l&rsquo;ordre dans lequel cela appara\u00eetra dans les requ\u00eates.","type":"integer","required":false},"class":{"description":"Classe de taxe.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"postcodes":{"description":"Liste des codes postaux \/ ZIP. Ajout\u00e9e avec WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Liste des noms de villes. Introduit par WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/taxes\/batch"}]}},"\/wc\/v3\/variations":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante de la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019articles \u00e0 retourner dans le jeu de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux correspondant \u00e0 une cha\u00eene.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es apr\u00e8s une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux ressources modifi\u00e9es avant une date de conformit\u00e9 ISO8601 donn\u00e9e.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Utiliser ou non les dates de publication GMT pour la limitation de la r\u00e9ponse par date de publication ou de modification.","type":"boolean","default":false,"required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 ceux d\u2019IDs parent particuliers.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les articles except\u00e9s ceux disposant d&rsquo;un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un identifiant sp\u00e9cifique.","type":"string","required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Limiter les r\u00e9sultats aux produits avec des UGS sp\u00e9cifiques. S\u00e9parez les UGS par des virgules.","type":"string","required":false},"tax_class":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec une classe de taxe sp\u00e9cifique.","type":"string","enum":["standard","taux-reduit","taux-zero"],"required":false},"on_sale":{"description":"Limiter le jeu de r\u00e9sultats aux produits en promotion.","type":"boolean","required":false},"min_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif minimum.","type":"string","required":false},"max_price":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec un tarif maximum.","type":"string","required":false},"include_meta":{"default":[],"description":"Limitez meta_data \u00e0 des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"V\u00e9rifiez que meta_data exclut des cl\u00e9s sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Limitez le jeu de r\u00e9sultats aux produits avec l\u2019\u00e9tat du stock sp\u00e9cifi\u00e9.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limitez les r\u00e9sultats aux produits avec ou sans prix.","type":"boolean","required":false},"attributes":{"description":"Limiter le jeu de r\u00e9sultats aux produits avec des attributs sp\u00e9cifiques.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Identifiant de l&rsquo;attribut."},"term":{"type":"string","description":"Terme d\u2019attribut."},"terms":{"type":"array","description":"Termes d\u2019attribut."}}},"required":false},"virtual":{"description":"Limitez le jeu de r\u00e9sultats aux variantes de produits virtuels.","type":"boolean","required":false},"downloadable":{"description":"Limitez le jeu de r\u00e9sultats aux variantes de produits t\u00e9l\u00e9chargeables.","type":"boolean","required":false},"include_status":{"description":"Limitez le jeu de r\u00e9sultats aux variantes de produit avec n\u2019importe quel \u00e9tat.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Excluez les variantes de produit avec n\u2019importe quel \u00e9tat du jeu de r\u00e9sultats.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limiter les r\u00e9sultats aux variantes visibles sur le point de vente.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/variations"}]}},"\/wc\/v3\/webhooks":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es apr\u00e8s une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter les r\u00e9ponses aux ressources publi\u00e9es avant une certaine date conforme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut des IDs sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le jeu de r\u00e9sultats aux identifiants sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Compenser le jeu de r\u00e9sultats par un nombre sp\u00e9cifique d&rsquo;articles.","type":"integer","required":false},"order":{"description":"Attribut de tri de commande croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","title"],"required":false},"status":{"default":"all","description":"Limiter les r\u00e9sultats aux webhooks affect\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique.","type":"string","enum":["all","active","paused","disabled"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Un nom convivial pour le crochet web.","type":"string","required":false},"status":{"default":"active","description":"\u00c9tat du webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"type":"string","description":"Sujet du crochet web.","required":true},"secret":{"description":"Cl\u00e9 secr\u00e8te utilis\u00e9e pour g\u00e9n\u00e9rer un hachage du crochet web livr\u00e9 et indiqu\u00e9e dans les en-t\u00eates de requ\u00eate. Si elle n\u2019est pas fournie, elle est d\u00e9finie par d\u00e9faut sur un hachage MD5 issu de l\u2019ID\u00a0\/ identifiant de l\u2019utilisateur actuel.","type":"string","required":false},"delivery_url":{"type":"string","description":"URL de livraison du crochet web.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/webhooks"}]}},"\/wc\/v3\/webhooks\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"name":{"description":"Un nom convivial pour le crochet web.","type":"string","required":false},"status":{"description":"\u00c9tat du webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Sujet du crochet web.","type":"string","required":false},"secret":{"description":"Cl\u00e9 secr\u00e8te utilis\u00e9e pour g\u00e9n\u00e9rer un hachage du crochet web livr\u00e9 et indiqu\u00e9e dans les en-t\u00eates de requ\u00eate. Si elle n\u2019est pas fournie, elle est d\u00e9finie par d\u00e9faut sur un hachage MD5 issu de l\u2019ID\u00a0\/ identifiant de l\u2019utilisateur actuel.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Requiert d&rsquo;\u00eatre vrai, car la ressource ne supporte pas la mise \u00e0 la corbeille.","required":false}}}]},"\/wc\/v3\/webhooks\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Un nom convivial pour le crochet web.","type":"string","required":false},"status":{"description":"\u00c9tat du webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Sujet du crochet web.","type":"string","required":false},"secret":{"description":"Cl\u00e9 secr\u00e8te utilis\u00e9e pour g\u00e9n\u00e9rer un hachage du crochet web livr\u00e9 et indiqu\u00e9e dans les en-t\u00eates de requ\u00eate. Si elle n\u2019est pas fournie, elle est d\u00e9finie par d\u00e9faut sur un hachage MD5 issu de l\u2019ID\u00a0\/ identifiant de l\u2019utilisateur actuel.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/webhooks\/batch"}]}},"\/wc\/v3\/system_status":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/system_status"}]}},"\/wc\/v3\/system_status\/tools":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/system_status\/tools"}]}},"\/wc\/v3\/system_status\/tools\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Un identifiant unique pour l&rsquo;outil.","type":"string","required":false},"name":{"description":"Nom de l\u2019outil.","type":"string","required":false},"action":{"description":"Ce que l\u2019ex\u00e9cution de l\u2019outil va faire.","type":"string","required":false},"description":{"description":"Description de l\u2019outil.","type":"string","required":false},"success":{"description":"L\u2019outil a t-il \u00e9t\u00e9 ex\u00e9cut\u00e9 avec succ\u00e8s\u00a0?","type":"boolean","required":false},"message":{"description":"Message de retour de l&rsquo;outil.","type":"string","required":false}}}]},"\/wc\/v3\/shipping_methods":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/shipping_methods"}]}},"\/wc\/v3\/shipping_methods\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false}}}]},"\/wc\/v3\/payment_gateways":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/payment_gateways"}]}},"\/wc\/v3\/payment_gateways\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la ressource.","type":"string","required":false},"title":{"description":"Titre sur la commande de la passerelle de paiement.","type":"string","required":false},"description":{"description":"Description de la passerelle de paiement \u00e0 la commande.","type":"string","required":false},"order":{"description":"Ordre de tri des passerelles de paiement.","type":"integer","required":false},"enabled":{"description":"\u00c9tat activ\u00e9 de la passerelle de paiement.","type":"boolean","required":false},"settings":{"description":"R\u00e9glages des passerelles de paiement.","type":"object","properties":{"id":{"description":"Un identifiant unique pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Une \u00e9tiquette lisible par l&rsquo;utilisateur pour le r\u00e9glage utilis\u00e9 dans les interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Une description lisible par l&rsquo;utilisateur pour le r\u00e9glage utilis\u00e9 dans les interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Type de r\u00e9glage.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Valeur de r\u00e9glage.","type":"string","context":["view","edit"]},"default":{"description":"Valeur par d\u00e9faut pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Texte d&rsquo;aide suppl\u00e9mentaire affich\u00e9 \u00e0 l&rsquo;utilisateur pour le r\u00e9glage.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Texte substitutif \u00e0 afficher dans les champs texte.","type":"string","context":["view","edit"],"readonly":true}},"required":false}}}]},"\/wc\/v3\/data":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/data"}]}},"\/wc\/v3\/data\/continents":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/data\/continents"}]}},"\/wc\/v3\/data\/continents\/(?P<location>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"continent":{"description":"Code de continent \u00e0 2\u00a0caract\u00e8res.","type":"string","required":false}}}]},"\/wc\/v3\/data\/countries":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/data\/countries"}]}},"\/wc\/v3\/data\/countries\/(?P<location>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Code de pays alpha-2 ISO3166.","type":"string","required":false}}}]},"\/wc\/v3\/data\/currencies":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/data\/currencies"}]}},"\/wc\/v3\/data\/currencies\/current":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/data\/currencies\/current"}]}},"\/wc\/v3\/data\/currencies\/(?P<currency>[\\w-]{3})":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Code de devise ISO4217.","type":"string","required":false}}}]},"\/wc\/v3\/paypal-standard\/update-shipping":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/paypal-standard\/update-shipping"}]}},"\/wc\/v3\/paypal-webhooks":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/paypal-webhooks"}]}},"\/wc\/v3\/paypal-buttons\/create-order":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/paypal-buttons\/create-order"}]}},"\/wc\/v3\/paypal-buttons\/cancel-payment":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/paypal-buttons\/cancel-payment"}]}},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/receipt":{"namespace":"wc\/v3","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identifiant unique de la commande.","type":"integer","required":false},"expiration_date":{"description":"Date d\u2019expiration au format aaaa-mm-jj.","type":"string","default":null,"required":false},"expiration_days":{"description":"Nombre de jours \u00e0 ajouter \u00e0 la date actuelle pour obtenir la date d\u2019expiration.","type":"integer","default":1,"required":false},"force_new":{"description":"Validez pour forcer la cr\u00e9ation d\u2019un nouveau re\u00e7u, quand bien m\u00eame il en existe d\u00e9j\u00e0 un qui n\u2019a pas encore expir\u00e9.","type":"boolean","default":false,"required":false}}},{"methods":["GET"],"args":{"id":{"description":"Identifiant unique de la commande.","type":"integer","required":false}}}]},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/actions\/email_templates":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique de la commande.","type":"integer","required":false}}}]},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/actions\/send_email":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identifiant unique de la commande.","type":"integer","required":false},"email":{"description":"Adresse e-mail \u00e0 laquelle envoyer les d\u00e9tails de la commande.","type":"string","format":"email","required":false},"force_email_update":{"description":"Indique s\u2019il faut mettre \u00e0 jour l\u2019adresse e-mail de facturation de la commande, m\u00eame si elle en a d\u00e9j\u00e0 une.","type":"boolean","required":false},"template_id":{"description":"L\u2019ID du mod\u00e8le \u00e0 utiliser pour envoyer l\u2019e-mail.","type":"string","enum":["new_order","cancelled_order","customer_cancelled_order","failed_order","customer_failed_order","customer_on_hold_order","customer_processing_order","customer_completed_order","customer_refunded_order","customer_invoice","customer_note","customer_reset_password","customer_new_account","customer_pos_completed_order","customer_pos_refunded_order"],"required":true}}}]},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/actions\/send_order_details":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identifiant unique de la commande.","type":"integer","required":false},"email":{"description":"Adresse e-mail \u00e0 laquelle envoyer les d\u00e9tails de la commande.","type":"string","format":"email","required":false},"force_email_update":{"description":"Indique s\u2019il faut mettre \u00e0 jour l\u2019adresse e-mail de facturation de la commande, m\u00eame si elle en a d\u00e9j\u00e0 une.","type":"boolean","required":false}}}]},"\/wc\/v3\/orders\/statuses":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc\/v3\/orders\/statuses"}]}},"\/wc-admin\/settings\/payments\/country":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"location":{"description":"Le code pays ISO\u00a03166 alpha-2 \u00e0 enregistrer pour l\u2019utilisateur actuel.","type":"string","pattern":"[a-zA-Z]{2}","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/settings\/payments\/country"}]}},"\/wc-admin\/settings\/payments\/providers":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le pays correspondant \u00e0 l\u2019emplacement de base de WooCommerce.","type":"string","pattern":"[a-zA-Z]{2}","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/settings\/payments\/providers"}]}},"\/wc-admin\/settings\/payments\/providers\/order":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"order_map":{"description":"Une association d\u2019ID de fournisseurs et de valeurs enti\u00e8res repr\u00e9sentant l\u2019ordre de tri.","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/settings\/payments\/providers\/order"}]}},"\/wc-admin\/settings\/payments\/suggestion\/(?P<id>[\\w\\d\\-]+)\/attach":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/settings\/payments\/suggestion\/(?P<id>[\\w\\d\\-]+)\/hide":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/settings\/payments\/suggestion\/(?P<suggestion_id>[\\w\\d\\-]+)\/incentive\/(?P<incentive_id>[\\w\\d\\-]+)\/dismiss":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"L\u2019ID du contexte pour lequel l\u2019incitation doit \u00eatre rejet\u00e9e. S\u2019il n\u2019est pas indiqu\u00e9, l\u2019incitation sera rejet\u00e9e pour tous les contextes.","type":"string","required":false},"do_not_track":{"description":"Si true, le suivi ne tiendra pas compte de la suppression de l\u2019incitation.","type":"boolean","default":false,"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"Le point d\u2019entr\u00e9e le plus \u00e9lev\u00e9 \u00e0 partir duquel le commer\u00e7ant est entr\u00e9 dans le flux d\u2019int\u00e9gration.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/start":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"Le point d\u2019entr\u00e9e le plus \u00e9lev\u00e9 \u00e0 partir duquel le commer\u00e7ant est entr\u00e9 dans le flux d\u2019int\u00e9gration.","type":"string","required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/save":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"Le point d\u2019entr\u00e9e le plus \u00e9lev\u00e9 \u00e0 partir duquel le commer\u00e7ant est entr\u00e9 dans le flux d\u2019int\u00e9gration.","type":"string","required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/check":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/finish":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"Le point d\u2019entr\u00e9e le plus \u00e9lev\u00e9 \u00e0 partir duquel le commer\u00e7ant est entr\u00e9 dans le flux d\u2019int\u00e9gration.","type":"string","required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/clean":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/init":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"Le point d\u2019entr\u00e9e le plus \u00e9lev\u00e9 \u00e0 partir duquel le commer\u00e7ant est entr\u00e9 dans le flux d\u2019int\u00e9gration.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/init"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/reset":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"Le point d\u2019entr\u00e9e le plus \u00e9lev\u00e9 \u00e0 partir duquel le commer\u00e7ant est entr\u00e9 dans le flux d\u2019int\u00e9gration.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/reset"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"Le point d\u2019entr\u00e9e le plus \u00e9lev\u00e9 \u00e0 partir duquel le commer\u00e7ant est entr\u00e9 dans le flux d\u2019int\u00e9gration.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session\/finish":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"Le point d\u2019entr\u00e9e le plus \u00e9lev\u00e9 \u00e0 partir duquel le commer\u00e7ant est entr\u00e9 dans le flux d\u2019int\u00e9gration.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session\/finish"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/test_account\/disable":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"from":{"description":"L\u2019endroit o\u00f9 cette requ\u00eate a \u00e9t\u00e9 d\u00e9clench\u00e9e dans le flux d\u2019int\u00e9gration.","type":"string","required":false},"source":{"description":"Le point d\u2019entr\u00e9e le plus \u00e9lev\u00e9 \u00e0 partir duquel le commer\u00e7ant est entr\u00e9 dans le flux d\u2019int\u00e9gration.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/test_account\/disable"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/preload":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/preload"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/reset":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"from":{"description":"L\u2019endroit o\u00f9 cette requ\u00eate a \u00e9t\u00e9 d\u00e9clench\u00e9e dans le flux d\u2019int\u00e9gration.","type":"string","required":false},"source":{"description":"Le point d\u2019entr\u00e9e le plus \u00e9lev\u00e9 \u00e0 partir duquel le commer\u00e7ant est entr\u00e9 dans le flux d\u2019int\u00e9gration.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/reset"}]}},"\/wc-admin\/settings\/payments\/woopayments\/woopay-eligibility":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/woopay-eligibility"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/test_account\/disable":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"Code pays ISO\u00a03166 alpha-2. Par d\u00e9faut, le code pays de l\u2019emplacement commercial des fournisseurs enregistr\u00e9s.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"from":{"description":"L\u2019endroit o\u00f9 cette requ\u00eate a \u00e9t\u00e9 d\u00e9clench\u00e9e dans le flux d\u2019int\u00e9gration.","type":"string","required":false},"source":{"description":"Le point d\u2019entr\u00e9e le plus \u00e9lev\u00e9 \u00e0 partir duquel le commer\u00e7ant est entr\u00e9 dans le flux d\u2019int\u00e9gration.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/test_account\/disable"}]}},"\/wc-admin-email":{"namespace":"wc-admin-email","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-admin-email","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin-email"}]}},"\/wc-admin-email\/settings\/email\/send-preview":{"namespace":"wc-admin-email","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"description":"Le type d\u2019e-mail \u00e0 pr\u00e9visualiser.","type":"string","required":true},"email":{"description":"L\u2019adresse e-mail \u00e0 laquelle envoyer l\u2019aper\u00e7u de l\u2019e-mail.","type":"string","format":"email","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin-email\/settings\/email\/send-preview"}]}},"\/wc-admin-email\/settings\/email\/preview-subject":{"namespace":"wc-admin-email","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Le type d\u2019e-mail pour lequel un objet doit \u00eatre obtenu.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin-email\/settings\/email\/preview-subject"}]}},"\/wc-admin-email\/settings\/email\/save-transient":{"namespace":"wc-admin-email","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"type":"string","description":"The key for the transient. Must be one of the allowed options.","required":true},"value":{"type":"string","description":"The value to be saved for the transient.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin-email\/settings\/email\/save-transient"}]}},"\/wc-admin-email\/settings\/email\/listing\/recreate-email-post":{"namespace":"wc-admin-email","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"email_id":{"description":"L\u2019ID d\u2019e-mail pour lequel recr\u00e9er l\u2019article.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-admin-email\/settings\/email\/listing\/recreate-email-post"}]}},"\/wc-telemetry":{"namespace":"wc-telemetry","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-telemetry","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-telemetry"}]}},"\/wc-telemetry\/tracker":{"namespace":"wc-telemetry","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"platform":{"description":"Plateforme \u00e0 suivre.","type":"string","required":true},"version":{"description":"Version de la plateforme \u00e0 suivre.","type":"string","required":true},"installation_date":{"description":"Date d\u2019installation de l\u2019application mobile WooCommerce.","type":"string","format":"date-time","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wc-telemetry\/tracker"}]}},"\/wccom-site\/v3":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wccom-site\/v3","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wccom-site\/v3"}]}},"\/wccom-site\/v3\/installer\/(?P<product_id>\\d+)\/state":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"type":"integer","required":true}}}]},"\/wccom-site\/v3\/installer":{"namespace":"wccom-site\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product-id":{"type":"integer","required":true},"run-until-step":{"type":"string","enum":["get_product_info","download_product","unpack_product","move_product","activate_product"],"required":true},"idempotency-key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wccom-site\/v3\/installer"}]}},"\/wccom-site\/v3\/installer\/reset":{"namespace":"wccom-site\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product-id":{"type":"integer","required":true},"idempotency-key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wccom-site\/v3\/installer\/reset"}]}},"\/wccom-site\/v3\/ssr":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wccom-site\/v3\/ssr"}]}},"\/wccom-site\/v3\/status":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wccom-site\/v3\/status"}]}},"\/wccom-site\/v3\/connection\/disconnect":{"namespace":"wccom-site\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wccom-site\/v3\/connection\/disconnect"}]}},"\/wccom-site\/v3\/connection\/status":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wccom-site\/v3\/connection\/status"}]}},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}},{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Identifiant unique de la cat\u00e9gorie de fonctionnalit\u00e9s.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}},{"methods":["GET"],"args":{"slug":{"description":"Identifiant unique de la cat\u00e9gorie de fonctionnalit\u00e9s.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE","GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Identifiant unique de l\u2019\u00ab\u00a0ability\u00a0\u00bb.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Param\u00e8tres d\u2019entr\u00e9e pour l\u2019ex\u00e9cution de cette \u00ab\u00a0ability\u00a0\u00bb.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}},{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Identifiant unique de l\u2019\u00ab\u00a0ability\u00a0\u00bb.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Param\u00e8tres d\u2019entr\u00e9e pour l\u2019ex\u00e9cution de cette \u00ab\u00a0ability\u00a0\u00bb.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Limiter les r\u00e9sultats aux \u00ab\u00a0abilities\u00a0\u00bb d\u2019une cat\u00e9gorie sp\u00e9cifique.","type":"string","required":false}}},{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Limiter les r\u00e9sultats aux \u00ab\u00a0abilities\u00a0\u00bb d\u2019une cat\u00e9gorie sp\u00e9cifique.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Identifiant unique de l\u2019\u00ab\u00a0ability\u00a0\u00bb.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}},{"methods":["GET"],"args":{"name":{"description":"Identifiant unique de l\u2019\u00ab\u00a0ability\u00a0\u00bb.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]},"\/jetpack\/v4\/remote_authorize":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/remote_authorize"}]}},"\/jetpack\/v4\/remote_provision":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/remote_provision"}]}},"\/jetpack\/v4\/remote_register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/remote_register"}]}},"\/jetpack\/v4\/remote_connect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/remote_connect"}]}},"\/jetpack\/v4\/connection\/check":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/connection\/check"}]}},"\/jetpack\/v4\/connection":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"isActive":{"description":"Set to false will trigger the site to disconnect.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/connection"}]}},"\/jetpack\/v4\/connection\/user":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/connection\/user"}]}},"\/jetpack\/v4\/connection\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/connection\/data"}]}},"\/jetpack\/v4\/connection\/plugins":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/connection\/plugins"}]}},"\/jetpack\/v4\/connection\/reconnect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/connection\/reconnect"}]}},"\/jetpack\/v4\/connection\/register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"from":{"description":"Indicates where the registration action was triggered for tracking\/segmentation purposes","type":"string","required":false},"redirect_uri":{"description":"URI of the admin page where the user should be redirected after connection flow","type":"string","required":false},"plugin_slug":{"description":"Indicates from what plugin the request is coming from","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/connection\/register"}]}},"\/jetpack\/v4\/connection\/authorize_url":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_uri":{"description":"URI of the admin page where the user should be redirected after connection flow","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/connection\/authorize_url"}]}},"\/jetpack\/v4\/user-token":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"user_token":{"description":"New user token","type":"string","required":true},"is_connection_owner":{"description":"Is connection owner","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/user-token"}]}},"\/jetpack\/v4\/connection\/owner":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"owner":{"description":"New owner","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/jetpack\/v4\/connection\/owner"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Limiter les r\u00e9sultats aux \u00e9l\u00e9ments qui sont \u00e9pingl\u00e9s.","type":"boolean","required":false},"ignore_sticky":{"description":"Ignorer les publications \u00e9pingl\u00e9es ou non.","type":"boolean","default":true,"required":false},"format":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments auxquels un ou plusieurs formats sont assign\u00e9s.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Le format pour la publication.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"D\u00e9finit si la publication doit \u00eatre trait\u00e9e en tant que contenu \u00e9pingl\u00e9 ou non.","type":"boolean","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Le format pour la publication.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"D\u00e9finit si la publication doit \u00eatre trait\u00e9e en tant que contenu \u00e9pingl\u00e9 ou non.","type":"boolean","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Le format pour la publication.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"D\u00e9finit si la publication doit \u00eatre trait\u00e9e en tant que contenu \u00e9pingl\u00e9 ou non.","type":"boolean","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments ayant un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les r\u00e9sultats, except\u00e9s ceux dont le parent porte un ID sp\u00e9cifique.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la publication.","type":"integer","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la publication.","type":"integer","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments ayant un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les r\u00e9sultats, except\u00e9s ceux dont le parent porte un ID sp\u00e9cifique.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Limite le jeu de r\u00e9sultats aux fichiers joints d\u2018un type de m\u00e9dia particulier ou de types de m\u00e9dias particuliers.","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"Limite le jeu de r\u00e9sultats aux fichiers joints d\u2018un type de MIME particulier ou de types de MIME particuliers.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"alt_text":{"description":"Texte alternatif propos\u00e9 si le fichier ne peut pas \u00eatre affich\u00e9.","type":"string","required":false},"caption":{"description":"La l\u00e9gende du fichier joint.","type":"object","properties":{"raw":{"description":"L\u00e9gende pour le fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"L\u00e9gende HTML pour le fichier joint, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La description du fichier joint.","type":"object","properties":{"raw":{"description":"Description du fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Description HTML de la pi\u00e8ce jointe, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"L\u2019ID pour la publication associ\u00e9e au fichier.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"alt_text":{"description":"Texte alternatif propos\u00e9 si le fichier ne peut pas \u00eatre affich\u00e9.","type":"string","required":false},"caption":{"description":"La l\u00e9gende du fichier joint.","type":"object","properties":{"raw":{"description":"L\u00e9gende pour le fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"L\u00e9gende HTML pour le fichier joint, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La description du fichier joint.","type":"object","properties":{"raw":{"description":"Description du fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Description HTML de la pi\u00e8ce jointe, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"L\u2019ID pour la publication associ\u00e9e au fichier.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identifiant unique du fichier joint.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL vers le fichier image modifi\u00e9.","type":"string","format":"uri","required":true},"modifiers":{"description":"Tableau des modifications d\u2019images.","type":"array","minItems":1,"items":{"description":"Modification d\u2019image.","type":"object","required":["type","args"],"oneOf":[{"title":"Retourner","properties":{"type":{"description":"Type de retournement.","type":"string","enum":["flip"]},"args":{"description":"Inverser les arguments.","type":"object","required":["flip"],"properties":{"flip":{"description":"Sens de retournement.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"D\u00e9termine s\u2019il faut retourner dans le sens horizontal.","type":"boolean"},"vertical":{"description":"D\u00e9termine s\u2019il faut retourner dans le sens vertical.","type":"boolean"}}}}}}},{"title":"Rotation","properties":{"type":{"description":"Type de rotation.","type":"string","enum":["rotate"]},"args":{"description":"Arguments de rotation.","type":"object","required":["angle"],"properties":{"angle":{"description":"Angle de rotation dans le sens horaire en degr\u00e9s.","type":"number"}}}}},{"title":"Recadrer","properties":{"type":{"description":"Type de recadrage.","type":"string","enum":["crop"]},"args":{"description":"Arguments de recadrage.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Position horizontale \u00e0 partir de la gauche pour commencer le recadrage en pourcentage de la largeur de l\u2019image.","type":"number"},"top":{"description":"En pourcentage de l\u2019image, la position verticale \u00e0 partir du haut \u00e0 laquelle commencer le recadrage de l\u2019image.","type":"number"},"width":{"description":"Largeur du recadrage en pourcentage de la largeur de l\u2019image.","type":"number"},"height":{"description":"Hauteur du recadrage en pourcentage de la hauteur de l\u2019image.","type":"number"}}}}}]},"required":false},"rotation":{"description":"La valeur en degr\u00e9s de la rotation de l\u2019image dans le sens des aiguilles d\u2019une montre. Obsol\u00e8te\u00a0: utilisez `modifiers` \u00e0 la place.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"En pourcentage de l\u2019image, la position X \u00e0 laquelle commencer le recadrage de l\u2019image. Obsol\u00e8te\u00a0: utilisez `modifiers` \u00e0 la place.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"En pourcentage de l\u2019image, la position Y \u00e0 laquelle commencer le recadrage de l\u2019image. Obsol\u00e8te\u00a0: utilisez `modifiers` \u00e0 la place.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"En pourcentage de l\u2019image, la largeur \u00e0 laquelle il faut recadrer l\u2019image. Obsol\u00e8te\u00a0: Utilisez `modifiers` \u00e0 la place.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"En pourcentage de l\u2019image, la hauteur \u00e0 laquelle il faut recadrer l\u2019image. Obsol\u00e8te\u00a0: Utilisez `modifiers` \u00e0 la place.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"La l\u00e9gende du fichier joint.","type":"object","properties":{"raw":{"description":"L\u00e9gende pour le fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"L\u00e9gende HTML pour le fichier joint, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La description du fichier joint.","type":"object","properties":{"raw":{"description":"Description du fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Description HTML de la pi\u00e8ce jointe, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"L\u2019ID pour la publication associ\u00e9e au fichier.","type":"integer","required":false},"alt_text":{"description":"Texte alternatif propos\u00e9 si le fichier ne peut pas \u00eatre affich\u00e9.","type":"string","required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie menus.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie menus.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Le titre pour l\u2019objet.","type":["string","object"],"properties":{"raw":{"description":"Le titre pour l\u2019objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour l\u2019objet, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"La famille d\u2019objets originellement repr\u00e9sent\u00e9e comme \u00ab\u00a0type de publication\u00a0\u00bb ou \u00ab\u00a0taxonomie\u00a0\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"parent":{"default":0,"description":"L\u2019ID pour le parent de l\u2019objet.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texte de l\u2019attribut titre de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"classes":{"description":"Noms de classe de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La description de cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"menu_order":{"default":1,"description":"L\u2019ID en base de donn\u00e9es due nav_menu_item qui est le parent de l\u2019\u00e9l\u00e9ment de menu, sinon 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Le type d\u2019objet originellement repr\u00e9sent\u00e9 comme \u00ab\u00a0cat\u00e9gorie\u00a0\u00bb, \u00ab\u00a0publication\u00a0\u00bb ou \u00ab\u00a0fichier joint\u00a0\u00bb.","type":"string","required":false},"object_id":{"default":0,"description":"L\u2019ID en base de donn\u00e9es de l\u2019objet original que repr\u00e9sente l\u2019\u00e9l\u00e9ment de menu, comme par exemple l\u2019ID pour les publication et le term_id pour les cat\u00e9gories.","type":"integer","minimum":0,"required":false},"target":{"description":"L\u2019attribut cible de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"L\u2019URL vers laquelle l\u2019\u00e9l\u00e9ment de menu renvoie.","type":"string","format":"uri","required":false},"xfn":{"description":"La relation XFN exprim\u00e9e dans ce lien de l\u2019\u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Les termes assign\u00e9s \u00e0 l\u2019objet dans la taxonomie nav_menu.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"title":{"description":"Le titre pour l\u2019objet.","type":["string","object"],"properties":{"raw":{"description":"Le titre pour l\u2019objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour l\u2019objet, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La famille d\u2019objets originellement repr\u00e9sent\u00e9e comme \u00ab\u00a0type de publication\u00a0\u00bb ou \u00ab\u00a0taxonomie\u00a0\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"parent":{"description":"L\u2019ID pour le parent de l\u2019objet.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texte de l\u2019attribut titre de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"classes":{"description":"Noms de classe de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La description de cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"menu_order":{"description":"L\u2019ID en base de donn\u00e9es due nav_menu_item qui est le parent de l\u2019\u00e9l\u00e9ment de menu, sinon 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Le type d\u2019objet originellement repr\u00e9sent\u00e9 comme \u00ab\u00a0cat\u00e9gorie\u00a0\u00bb, \u00ab\u00a0publication\u00a0\u00bb ou \u00ab\u00a0fichier joint\u00a0\u00bb.","type":"string","required":false},"object_id":{"description":"L\u2019ID en base de donn\u00e9es de l\u2019objet original que repr\u00e9sente l\u2019\u00e9l\u00e9ment de menu, comme par exemple l\u2019ID pour les publication et le term_id pour les cat\u00e9gories.","type":"integer","minimum":0,"required":false},"target":{"description":"L\u2019attribut cible de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"L\u2019URL vers laquelle l\u2019\u00e9l\u00e9ment de menu renvoie.","type":"string","format":"uri","required":false},"xfn":{"description":"La relation XFN exprim\u00e9e dans ce lien de l\u2019\u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Les termes assign\u00e9s \u00e0 l\u2019objet dans la taxonomie nav_menu.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID pour le parent de l\u2019objet.","type":"integer","minimum":0,"required":false},"title":{"description":"Le titre pour l\u2019objet.","type":["string","object"],"properties":{"raw":{"description":"Le titre pour l\u2019objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour l\u2019objet, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La famille d\u2019objets originellement repr\u00e9sent\u00e9e comme \u00ab\u00a0type de publication\u00a0\u00bb ou \u00ab\u00a0taxonomie\u00a0\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"attr_title":{"description":"Texte de l\u2019attribut titre de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"classes":{"description":"Noms de classe de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La description de cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"menu_order":{"description":"L\u2019ID en base de donn\u00e9es due nav_menu_item qui est le parent de l\u2019\u00e9l\u00e9ment de menu, sinon 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Le type d\u2019objet originellement repr\u00e9sent\u00e9 comme \u00ab\u00a0cat\u00e9gorie\u00a0\u00bb, \u00ab\u00a0publication\u00a0\u00bb ou \u00ab\u00a0fichier joint\u00a0\u00bb.","type":"string","required":false},"object_id":{"description":"L\u2019ID en base de donn\u00e9es de l\u2019objet original que repr\u00e9sente l\u2019\u00e9l\u00e9ment de menu, comme par exemple l\u2019ID pour les publication et le term_id pour les cat\u00e9gories.","type":"integer","minimum":0,"required":false},"target":{"description":"L\u2019attribut cible de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"L\u2019URL vers laquelle l\u2019\u00e9l\u00e9ment de menu renvoie.","type":"string","format":"uri","required":false},"xfn":{"description":"La relation XFN exprim\u00e9e dans ce lien de l\u2019\u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Les termes assign\u00e9s \u00e0 l\u2019objet dans la taxonomie nav_menu.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"wp_pattern_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"wp_pattern_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"wp_pattern_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limiter \u00e0 l\u2019ID de publication sp\u00e9cifi\u00e9.","type":"integer","required":false},"area":{"description":"Limite \u00e0 la zone de l\u2019\u00e9l\u00e9ment de mod\u00e8le sp\u00e9cifi\u00e9.","type":"string","required":false},"post_type":{"description":"Type de publication pour lequel obtenir les mod\u00e8les.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"default":"","description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"default":"publish","description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Le slug du mod\u00e8le doit r\u00e9cup\u00e9rer l\u2019alternative pour","type":"string","required":true},"is_custom":{"description":"Indique si un mod\u00e8le est personnalis\u00e9 ou fait partie de la hi\u00e9rarchie des mod\u00e8les.","type":"boolean","required":false},"template_prefix":{"description":"Le pr\u00e9fixe de mod\u00e8le pour le mod\u00e8le cr\u00e9\u00e9. Ceci est utilis\u00e9 pour extraire le type de mod\u00e8le principal, p.\u00a0ex.\u00a0dans \u00ab\u00a0taxonomy-books\u00a0\u00bb, cela extrait \u00ab\u00a0taxonomy\u00a0\u00bb","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false},"area":{"description":"L\u2019emplacement o\u00f9 l\u2019\u00e9l\u00e9ment de mod\u00e8le devrait \u00eatre utilis\u00e9 (ent\u00eate, pied de page, etc.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limiter \u00e0 l\u2019ID de publication sp\u00e9cifi\u00e9.","type":"integer","required":false},"area":{"description":"Limite \u00e0 la zone de l\u2019\u00e9l\u00e9ment de mod\u00e8le sp\u00e9cifi\u00e9.","type":"string","required":false},"post_type":{"description":"Type de publication pour lequel obtenir les mod\u00e8les.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"default":"","description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"default":"publish","description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false},"area":{"description":"L\u2019emplacement o\u00f9 l\u2019\u00e9l\u00e9ment de mod\u00e8le devrait \u00eatre utilis\u00e9 (ent\u00eate, pied de page, etc.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Le slug du mod\u00e8le doit r\u00e9cup\u00e9rer l\u2019alternative pour","type":"string","required":true},"is_custom":{"description":"Indique si un mod\u00e8le est personnalis\u00e9 ou fait partie de la hi\u00e9rarchie des mod\u00e8les.","type":"boolean","required":false},"template_prefix":{"description":"Le pr\u00e9fixe de mod\u00e8le pour le mod\u00e8le cr\u00e9\u00e9. Ceci est utilis\u00e9 pour extraire le type de mod\u00e8le principal, p.\u00a0ex.\u00a0dans \u00ab\u00a0taxonomy-books\u00a0\u00bb, cela extrait \u00ab\u00a0taxonomy\u00a0\u00bb","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false},"area":{"description":"L\u2019emplacement o\u00f9 l\u2019\u00e9l\u00e9ment de mod\u00e8le devrait \u00eatre utilis\u00e9 (ent\u00eate, pied de page, etc.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la r\u00e9vision des styles globaux.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision de styles globaux.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"L\u2018identifiant du th\u00e8me","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"L\u2018identifiant du th\u00e8me","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"ID de la configuration de styles globaux.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Styles globaux.","type":["object"],"required":false},"settings":{"description":"R\u00e9glages globaux.","type":["object"],"required":false},"title":{"description":"Titre de la variation de styles globaux.","type":["object","string"],"properties":{"raw":{"description":"Titre de la variation de styles globaux, tel qu\u2019il existe en base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Version du sch\u00e9ma theme.json utilis\u00e9 pour les r\u00e9glages de typographie.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"d\u00e9claration font-family dans le format theme.json, encod\u00e9e comme une cha\u00eene.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"theme_json_version":{"description":"Version du sch\u00e9ma theme.json utilis\u00e9 pour les r\u00e9glages de typographie.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"d\u00e9claration font-family dans le format theme.json, encod\u00e9e comme une cha\u00eene.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"L\u2019ID de la famille de polices parente de la police de caract\u00e8res.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"L\u2019ID de la famille de polices parente de la police de caract\u00e8res.","type":"integer","required":true},"theme_json_version":{"description":"Version du sch\u00e9ma theme.json utilis\u00e9 pour les r\u00e9glages de typographie.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"D\u00e9claration font-face dans le format theme.json, encod\u00e9e comme une cha\u00eene.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"L\u2019ID de la famille de polices parente de la police de caract\u00e8res.","type":"integer","required":true},"id":{"description":"Identifiant unique de la police de caract\u00e8res.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"L\u2019ID de la famille de polices parente de la police de caract\u00e8res.","type":"integer","required":true},"id":{"description":"Identifiant unique de la police de caract\u00e8res.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/traction_membre":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/traction_membre"}]}},"\/wp\/v2\/traction_membre\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/traction_membre\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/traction_membre\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/product":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"product_brand":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie product_brand.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_brand_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie product_brand.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"product_cat":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie product_cat.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_cat_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie product_cat.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"product_tag":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie product_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_tag_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie product_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"brand":{"description":"Limiter le jeu de r\u00e9sultats aux produits affect\u00e9s \u00e0 un ID de marque sp\u00e9cifique.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"product_brand":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie product_brand.","type":"array","items":{"type":"integer"},"required":false},"product_cat":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie product_cat.","type":"array","items":{"type":"integer"},"required":false},"product_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie product_tag.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/product"}]}},"\/wp\/v2\/product\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"product_brand":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie product_brand.","type":"array","items":{"type":"integer"},"required":false},"product_cat":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie product_cat.","type":"array","items":{"type":"integer"},"required":false},"product_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie product_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/product\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"product_brand":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie product_brand.","type":"array","items":{"type":"integer"},"required":false},"product_cat":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie product_cat.","type":"array","items":{"type":"integer"},"required":false},"product_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie product_tag.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/product\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/book":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/book"}]}},"\/wp\/v2\/book\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/book\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/book\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/evenements":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"event_region":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie event_region.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"event_region_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie event_region.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"event_year":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie event_year.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"event_year_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie event_year.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"event_national":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie event_national.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"event_national_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie event_national.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"event_featured":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie event_featured.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"event_featured_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie event_featured.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"event_region":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie event_region.","type":"array","items":{"type":"integer"},"required":false},"event_year":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie event_year.","type":"array","items":{"type":"integer"},"required":false},"event_national":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie event_national.","type":"array","items":{"type":"integer"},"required":false},"event_featured":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie event_featured.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/evenements"}]}},"\/wp\/v2\/evenements\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"event_region":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie event_region.","type":"array","items":{"type":"integer"},"required":false},"event_year":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie event_year.","type":"array","items":{"type":"integer"},"required":false},"event_national":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie event_national.","type":"array","items":{"type":"integer"},"required":false},"event_featured":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie event_featured.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/evenements\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"event_region":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie event_region.","type":"array","items":{"type":"integer"},"required":false},"event_year":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie event_year.","type":"array","items":{"type":"integer"},"required":false},"event_national":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie event_national.","type":"array","items":{"type":"integer"},"required":false},"event_featured":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie event_featured.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/evenements\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/salons":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"salon_year":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie salon_year.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"salon_year_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie salon_year.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"salon_year":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie salon_year.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/salons"}]}},"\/wp\/v2\/salons\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"salon_year":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie salon_year.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/salons\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"salon_year":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie salon_year.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/salons\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/revue":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"revue_year":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie revue_year.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"revue_year_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie revue_year.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"revue_year":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie revue_year.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/revue"}]}},"\/wp\/v2\/revue\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"revue_year":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie revue_year.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/revue\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"revue_year":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie revue_year.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/revue\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/antennes":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/antennes"}]}},"\/wp\/v2\/antennes\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/antennes\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/antennes\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Un identificateur alphanum\u00e9rique pour le type de publication.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Un identificateur alphanum\u00e9rique pour l\u2019\u00e9tat.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Limiter les r\u00e9sultats aux taxonomies associ\u00e9es un type de publication sp\u00e9cifique.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Un identificateur alphanum\u00e9rique pour la taxonomie.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"parent":{"description":"R\u00e9sultats limit\u00e9s aux termes ayant un parent sp\u00e9cifique.","type":"integer","required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false},"locations":{"description":"Les emplacements assign\u00e9s au menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ajouter automatiquement les pages de premier niveau \u00e0 ce menu.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false},"locations":{"description":"Les emplacements assign\u00e9s au menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ajouter automatiquement les pages de premier niveau \u00e0 ce menu.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/product_brand":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"parent":{"description":"R\u00e9sultats limit\u00e9s aux termes ayant un parent sp\u00e9cifique.","type":"integer","required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/product_brand"}]}},"\/wp\/v2\/product_brand\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/product_cat":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"parent":{"description":"R\u00e9sultats limit\u00e9s aux termes ayant un parent sp\u00e9cifique.","type":"integer","required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/product_cat"}]}},"\/wp\/v2\/product_cat\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/product_tag":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/product_tag"}]}},"\/wp\/v2\/product_tag\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/event_region":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/event_region"}]}},"\/wp\/v2\/event_region\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/event_year":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"parent":{"description":"R\u00e9sultats limit\u00e9s aux termes ayant un parent sp\u00e9cifique.","type":"integer","required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/event_year"}]}},"\/wp\/v2\/event_year\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/event_national":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/event_national"}]}},"\/wp\/v2\/event_national\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/event_featured":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/event_featured"}]}},"\/wp\/v2\/event_featured\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/salon_year":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"parent":{"description":"R\u00e9sultats limit\u00e9s aux termes ayant un parent sp\u00e9cifique.","type":"integer","required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/salon_year"}]}},"\/wp\/v2\/salon_year\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/revue_year":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"parent":{"description":"R\u00e9sultats limit\u00e9s aux termes ayant un parent sp\u00e9cifique.","type":"integer","required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/revue_year"}]}},"\/wp\/v2\/revue_year\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"default":"asc","description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Trier la collection par attributs de compte.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux comptes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limiter le r\u00e9sultat aux comptes correspondants \u00e0 au moins un r\u00f4le sp\u00e9cifique fourni. Accepte les listes de type CSV ou les r\u00f4les uniques.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limiter le jeu de r\u00e9sultats aux comptes correspondant \u00e0 au moins une capacit\u00e9 sp\u00e9cifique fournie. Accepte une liste CSV ou une capacit\u00e9 unique.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limiter le jeu de r\u00e9sultats aux comptes consid\u00e9r\u00e9s comme auteurs ou autrices.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limiter les r\u00e9sultats aux comptes qui ont mis en ligne des publications.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","traction_membre":"traction_membre","product":"product","book":"book","evenements":"evenements","salons":"salons","revue":"revue","antennes":"antennes"}},"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Nom de connexion pour le compte.","type":"string","required":true},"name":{"description":"Nom affich\u00e9 pour le compte.","type":"string","required":false},"first_name":{"description":"Pr\u00e9nom associ\u00e9 au compte.","type":"string","required":false},"last_name":{"description":"Nom du compte.","type":"string","required":false},"email":{"description":"L\u2019adresse e-mail du compte.","type":"string","format":"email","required":true},"url":{"description":"URL de ce compte.","type":"string","format":"uri","required":false},"description":{"description":"Description du compte.","type":"string","required":false},"locale":{"description":"Langue du compte.","type":"string","enum":["","en_US","fr_FR"],"required":false},"nickname":{"description":"Le surnom du compte.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le compte.","type":"string","required":false},"roles":{"description":"R\u00f4les assign\u00e9s au compte.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Mot de passe pour le compte (jamais inclus).","type":"string","required":true},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La date et l\u2019heure auxquelles les pr\u00e9f\u00e9rences ont \u00e9t\u00e9 mises \u00e0 jour.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le compte.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le compte.","type":"integer","required":false},"username":{"description":"Nom de connexion pour le compte.","type":"string","required":false},"name":{"description":"Nom affich\u00e9 pour le compte.","type":"string","required":false},"first_name":{"description":"Pr\u00e9nom associ\u00e9 au compte.","type":"string","required":false},"last_name":{"description":"Nom du compte.","type":"string","required":false},"email":{"description":"L\u2019adresse e-mail du compte.","type":"string","format":"email","required":false},"url":{"description":"URL de ce compte.","type":"string","format":"uri","required":false},"description":{"description":"Description du compte.","type":"string","required":false},"locale":{"description":"Langue du compte.","type":"string","enum":["","en_US","fr_FR"],"required":false},"nickname":{"description":"Le surnom du compte.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le compte.","type":"string","required":false},"roles":{"description":"R\u00f4les assign\u00e9s au compte.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Mot de passe pour le compte (jamais inclus).","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La date et l\u2019heure auxquelles les pr\u00e9f\u00e9rences ont \u00e9t\u00e9 mises \u00e0 jour.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le compte.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les comptes ne prennent pas en charge la suppression forc\u00e9e.","required":false},"reassign":{"type":"integer","description":"R\u00e9affectez les publications et les liens du compte supprim\u00e9 \u00e0 cet ID de compte.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Nom de connexion pour le compte.","type":"string","required":false},"name":{"description":"Nom affich\u00e9 pour le compte.","type":"string","required":false},"first_name":{"description":"Pr\u00e9nom associ\u00e9 au compte.","type":"string","required":false},"last_name":{"description":"Nom du compte.","type":"string","required":false},"email":{"description":"L\u2019adresse e-mail du compte.","type":"string","format":"email","required":false},"url":{"description":"URL de ce compte.","type":"string","format":"uri","required":false},"description":{"description":"Description du compte.","type":"string","required":false},"locale":{"description":"Langue du compte.","type":"string","enum":["","en_US","fr_FR"],"required":false},"nickname":{"description":"Le surnom du compte.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le compte.","type":"string","required":false},"roles":{"description":"R\u00f4les assign\u00e9s au compte.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Mot de passe pour le compte (jamais inclus).","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La date et l\u2019heure auxquelles les pr\u00e9f\u00e9rences ont \u00e9t\u00e9 mises \u00e0 jour.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les comptes ne prennent pas en charge la suppression forc\u00e9e.","required":false},"reassign":{"type":"integer","description":"R\u00e9affectez les publications et les liens du compte supprim\u00e9 \u00e0 cet ID de compte.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Un UUID fourni par l\u2019application pour l\u2019identifier de mani\u00e8re unique. Il est recommand\u00e9 d\u2019utiliser un UUID v5 avec l\u2019URL ou l\u2019espace de noms DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Le nom du mot de passe de l\u2019application.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Un UUID fourni par l\u2019application pour l\u2019identifier de mani\u00e8re unique. Il est recommand\u00e9 d\u2019utiliser un UUID v5 avec l\u2019URL ou l\u2019espace de noms DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Le nom du mot de passe de l\u2019application.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux commentaires publi\u00e9s apr\u00e8s une date donn\u00e9e et conforme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter le jeu de r\u00e9sultats aux commentaires assign\u00e9s aux ID de compte sp\u00e9cifi\u00e9s. N\u00e9cessite des droits sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les commentaires assign\u00e9s aux ID des comptes sp\u00e9cifi\u00e9s. N\u00e9cessite des droits sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Limiter le jeu de r\u00e9sultats \u00e0 une adresse e-mail d\u2019auteur ou d\u2019autrice sp\u00e9cifique. N\u00e9cessite les droits correspondants.","format":"email","type":"string","required":false},"before":{"description":"Limiter les r\u00e9ponses aux commentaires publi\u00e9s avant une date donn\u00e9e et conforme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de commentaire.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Limiter le jeu de r\u00e9sultats aux commentaires ayant un ID parent sp\u00e9cifique.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID parents sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Limite le jeu de r\u00e9sultats aux commentaires assign\u00e9s \u00e0 des ID de publications sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Limiter le jeu de r\u00e9sultats aux commentaires assign\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique. N\u00e9cessite les droits correspondants.","type":"string","required":false},"type":{"default":"comment","description":"Limite le jeu de r\u00e9sultats aux commentaires assign\u00e9s \u00e0 un type sp\u00e9cifique. N\u00e9cessite des droits sp\u00e9cifiques.","type":"string","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"L\u2019ID de l\u2019objet <code>user<\/code>, si l\u2019auteur ou l\u2019autrice \u00e9tait un compte.","type":"integer","required":false},"author_email":{"description":"Adresse e-mail de l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"email","required":false},"author_ip":{"description":"Adresse IP de l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"ip","required":false},"author_name":{"description":"Nom affich\u00e9 pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","required":false},"author_url":{"description":"URL pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agent utilisateur pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","required":false},"content":{"description":"Le contenu pour le commentaire.","type":"object","properties":{"raw":{"description":"Contenu pour le commentaire, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour le commentaire, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"La date \u00e0 laquelle le commentaire a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"La date \u00e0 laquelle le commentaire a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"L\u2019ID du parent du commentaire.","type":"integer","required":false},"post":{"default":0,"description":"L\u2019ID de l\u2019objet publication associ\u00e9.","type":"integer","required":false},"status":{"description":"\u00c9tat du commentaire.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"\u00c9tat de r\u00e9solution de la note","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique du commentaire.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Mot de passe de la publication parente du commentaire (si la publication est prot\u00e9g\u00e9e par un mot de passe).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique du commentaire.","type":"integer","required":false},"author":{"description":"L\u2019ID de l\u2019objet <code>user<\/code>, si l\u2019auteur ou l\u2019autrice \u00e9tait un compte.","type":"integer","required":false},"author_email":{"description":"Adresse e-mail de l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"email","required":false},"author_ip":{"description":"Adresse IP de l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"ip","required":false},"author_name":{"description":"Nom affich\u00e9 pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","required":false},"author_url":{"description":"URL pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agent utilisateur pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","required":false},"content":{"description":"Le contenu pour le commentaire.","type":"object","properties":{"raw":{"description":"Contenu pour le commentaire, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour le commentaire, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"La date \u00e0 laquelle le commentaire a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"La date \u00e0 laquelle le commentaire a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"L\u2019ID du parent du commentaire.","type":"integer","required":false},"post":{"description":"L\u2019ID de l\u2019objet publication associ\u00e9.","type":"integer","required":false},"status":{"description":"\u00c9tat du commentaire.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"\u00c9tat de r\u00e9solution de la note","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique du commentaire.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false},"password":{"description":"Mot de passe de la publication parente du commentaire (si la publication est prot\u00e9g\u00e9e par un mot de passe).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"type":{"default":"post","description":"Limiter les r\u00e9sultats aux \u00e9l\u00e9ments d\u2019un type d\u2019objet.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Limiter les r\u00e9sultats aux \u00e9l\u00e9ments d\u2019un ou plusieurs sous-types d\u2019objet.","type":"array","items":{"enum":["post","page","traction_membre","product","book","evenements","salons","revue","antennes","category","post_tag","product_brand","product_cat","product_tag","event_region","event_year","event_national","event_featured","salon_year","revue_year","any"],"type":"string"},"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Nom unique enregistr\u00e9 de ce bloc.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Attributs pour le bloc.","type":"object","default":[],"required":false},"post_id":{"description":"ID de ce contenu\/contexte.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Espace de nom du bloc.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Espace de nom du bloc.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nom du bloc.","type":"string","required":false},"namespace":{"description":"Espace de nom du bloc.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"Titre","description":"Titre du site.","type":"string","required":false},"description":{"title":"Slogan","description":"Slogan du site.","type":"string","required":false},"url":{"title":"","description":"URL du site.","type":"string","format":"uri","required":false},"email":{"title":"","description":"Cette adresse est utilis\u00e9e \u00e0 des fins d\u2019administration, comme les notifications de nouveaux comptes.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"Une ville dans le m\u00eame fuseau horaire que le v\u00f4tre.","type":"string","required":false},"date_format":{"title":"","description":"Un format de date commun pour tous les r\u00e9glages de dates.","type":"string","required":false},"time_format":{"title":"","description":"Un format d\u2019heure commun pour tous les r\u00e9glages d\u2019heures.","type":"string","required":false},"start_of_week":{"title":"","description":"Le num\u00e9ro du jour de la semaine \u00e0 laquelle la semaine devrait commencer.","type":"integer","required":false},"language":{"title":"","description":"Code local de l\u2019installation WordPress.","type":"string","required":false},"use_smilies":{"title":"","description":"Convertir les \u00e9motic\u00f4nes, comme :-) et :-P, en images lors de l\u2019affichage.","type":"boolean","required":false},"default_category":{"title":"","description":"Cat\u00e9gorie d\u2019article par d\u00e9faut.","type":"integer","required":false},"default_post_format":{"title":"","description":"Format d\u2019article par d\u00e9faut.","type":"string","required":false},"posts_per_page":{"title":"Nombre maximum de publications par page","description":"Les pages de blog affichent au maximum.","type":"integer","required":false},"show_on_front":{"title":"Affichage en page d\u2019accueil","description":"Afficher quoi sur la page d\u2019accueil","type":"string","required":false},"page_on_front":{"title":"Page d\u2019accueil","description":"L\u2019ID de la page qui doit \u00eatre affich\u00e9 sur la page d\u2019accueil","type":"integer","required":false},"page_for_posts":{"title":"","description":"L\u2019ID de la page qui affichera les derniers articles","type":"integer","required":false},"default_ping_status":{"title":"","description":"Autoriser les liens de notification d\u2019autres blogs (pings et r\u00e9troliens) sur les nouveaux articles.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Autoriser les commentaires sur les nouvelles publications","description":"Autoriser les gens \u00e0 envoyer des commentaires sur les nouvelles publications.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Logo du site.","type":"integer","required":false},"site_icon":{"title":"Ic\u00f4ne","description":"Ic\u00f4ne du site.","type":"integer","required":false},"pickup_location_settings":{"title":"","description":"WooCommerce Local Pickup Method Settings","type":"object","properties":{"enabled":{"description":"Si cette option est activ\u00e9e, ce mode appara\u00eet dans la validation de commande bas\u00e9e sur des blocs.","type":"string","enum":["yes","no"]},"title":{"description":"Cela d\u00e9termine le titre que les utilisateurs verront durant la commande.","type":"string"},"tax_status":{"description":"Si un co\u00fbt est d\u00e9fini, cela contr\u00f4le si des taxes sont appliqu\u00e9es \u00e0 ce co\u00fbt.","type":"string","enum":["taxable","none"]},"cost":{"description":"Co\u00fbt facultatif \u00e0 facturer pour le retrait.","type":"string"}},"additionalProperties":false,"required":false},"pickup_locations":{"title":"","description":"WooCommerce Local Pickup Locations","type":"array","items":{"type":"object","properties":{"name":{"type":"string"},"address":{"type":"object","properties":{"address_1":{"type":"string"},"city":{"type":"string"},"state":{"type":"string"},"postcode":{"type":"string"},"country":{"type":"string"}},"additionalProperties":false},"details":{"type":"string"},"enabled":{"type":"boolean"}},"additionalProperties":false},"required":false},"woocommerce_default_catalog_orderby":{"title":"Tri par d\u00e9faut des produits","description":"Comment les produits doivent-ils \u00eatre tri\u00e9s par d\u00e9faut dans le catalogue\u00a0?","type":"string","enum":["menu_order","popularity","rating","date","price","price-desc"],"required":false},"woocommerce_checkout_phone_field":{"title":"Num\u00e9ro de t\u00e9l\u00e9phone","description":"Contr\u00f4le l\u2019affichage du champ de num\u00e9ro de t\u00e9l\u00e9phone \u00e0 la validation de la commande.","type":"string","enum":["optional","required","hidden"],"required":false},"woocommerce_checkout_company_field":{"title":"Entreprise","description":"Contr\u00f4le l\u2019affichage du champ de soci\u00e9t\u00e9 \u00e0 la validation de la commande.","type":"string","enum":["optional","required","hidden"],"required":false},"woocommerce_checkout_address_2_field":{"title":"Adresse ligne 2","description":"Contr\u00f4le l\u2019affichage du champ d\u2019appartement (address_2) \u00e0 la validation de la commande.","type":"string","enum":["optional","required","hidden"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Limiter les r\u00e9sultats aux th\u00e8mes qui poss\u00e8dent un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"La feuille de style du th\u00e8me. Elle identifie le th\u00e8me de mani\u00e8re unique.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"status":{"description":"Limiter les r\u00e9sultats aux extensions ayant l\u2019\u00e9tat sp\u00e9cifi\u00e9.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Slug sur le r\u00e9pertoire des extensions WordPress.org.","pattern":"[\\w\\-]+","required":true},"status":{"description":"L\u2019\u00e9tat d\u2019activation de l\u2019extension.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"L\u2019\u00e9tat d\u2019activation de l\u2019extension.","type":"string","enum":["inactive","active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID d\u2019une colonne lat\u00e9rale enregistr\u00e9e","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Widgets imbriqu\u00e9s.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du type de widget.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"L\u2019ID du type de widget.","type":"string","required":true},"instance":{"description":"R\u00e9glages de l\u2019instance courante du widget.","type":"object","required":false},"form_data":{"description":"Les donn\u00e9es s\u00e9rialis\u00e9es du formulaire du widget \u00e0 encoder dans les r\u00e9glages de l\u2019instance.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"L\u2019ID du type de widget.","type":"string","required":true},"instance":{"description":"R\u00e9glages de l\u2019instance courante du widget.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"La colonne lat\u00e9rale pour laquelle renvoyer les widgets.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique du widget.","type":"string","required":false},"id_base":{"description":"Type de widget. Correspond \u00e0 l\u2019ID du point de terminaison widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"La colonne lat\u00e9rale \u00e0 laquelle appartient le widget.","type":"string","required":true},"instance":{"description":"R\u00e9glages de l\u2019instance du widget, si pris en charge.","type":"object","properties":{"encoded":{"description":"Repr\u00e9sentation des r\u00e9glages de l\u2019instance encod\u00e9e en base64.","type":"string","context":["edit"]},"hash":{"description":"Cl\u00e9 cryptographique hach\u00e9e des r\u00e9glages de l\u2019instance.","type":"string","context":["edit"]},"raw":{"description":"R\u00e9glages de l\u2019instance non encod\u00e9s, si pris en charge.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Donn\u00e9e de formulaire encod\u00e9e dans une URL pour le formulaire de l\u2019administration des widgets. Utilis\u00e9 pour mettre \u00e0 jour un widget qui ne prend pas en charge les instances. En \u00e9criture uniquement.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique du widget.","type":"string","required":false},"id_base":{"description":"Type de widget. Correspond \u00e0 l\u2019ID du point de terminaison widget-types.","type":"string","required":false},"sidebar":{"description":"La colonne lat\u00e9rale \u00e0 laquelle appartient le widget.","type":"string","required":false},"instance":{"description":"R\u00e9glages de l\u2019instance du widget, si pris en charge.","type":"object","properties":{"encoded":{"description":"Repr\u00e9sentation des r\u00e9glages de l\u2019instance encod\u00e9e en base64.","type":"string","context":["edit"]},"hash":{"description":"Cl\u00e9 cryptographique hach\u00e9e des r\u00e9glages de l\u2019instance.","type":"string","context":["edit"]},"raw":{"description":"R\u00e9glages de l\u2019instance non encod\u00e9s, si pris en charge.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Donn\u00e9e de formulaire encod\u00e9e dans une URL pour le formulaire de l\u2019administration des widgets. Utilis\u00e9 pour mettre \u00e0 jour un widget qui ne prend pas en charge les instances. En \u00e9criture uniquement.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Indique s\u2019il faut forcer la suppression du widget ou le d\u00e9placer vers la colonne lat\u00e9rale inactive.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Limiter les r\u00e9sultats aux blocs correspondant au terme de recherche.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","minLength":1,"required":false},"category":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 l\u2019identifiant d\u2019une cat\u00e9gorie.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 un identifiant de mot-cl\u00e9.","type":"integer","minimum":1,"required":false},"slug":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une composition (slug).","type":"array","required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"L\u2019URL \u00e0 traiter.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Un identificateur alphanum\u00e9rique pour l\u2019emplacement de menu.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]}},"site_logo":0,"site_icon":229,"site_icon_url":"https:\/\/www.la-traction-universelle.org\/wp-content\/uploads\/2025\/11\/favico.jpg","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/www.la-traction-universelle.org\/wp-json\/wp\/v2\/media\/229"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
